[Unstable Update] 2017-01-12 - Xorg 1.19, gcc, Pacman-mirrors
unstable
update
#21
Ok well steam now works for some odd reason. Alls good on my end now.
#22
like as some said. I think the verbose option should be the default or maybe not. :wink:
and I would change the text
Using mirrors in xxx
by
Ranking mirrors in xxx
or
Testing mirrors in xxx.
or something else
#23
Btw, what does -i option use for gui? Gtk3? Would it be feasible to add ncurses interface? It would be nice when integrating it into cli-installer. Not a must have though.
#24
TBH it is a must have. It’s a functionality for a »command line« tool that does not work on a (TTY) command line
I like it anyways :sunny: :smile:
#25
Hi, I’m new here, hope it’s the right place for this. Got Minimal Kde alpha 17 on VB.
Running todays update I get:
xorg-server and xf86-input-acecad are in conflict (X-ABI-XINPUT_VERSION). Remove xf86-input-acecad? [y/N] y
Remove xf86-input-joystick [y/N] y
Completes without further errors.
#26
I removed, re-booted and all was well, but I am in a VM. More discussion here:
#27
Yes, it’s ok to remove these two packages. Their functionality should now be covered by the new xorg-server package.
#28
@BS86 @xircon @scachemaille the verbose option has been replaced by a quiet option. :wink:
@Tids we are trying to resolve your issue (at least the error message).
#29
@Tids
Did a little test on the source in an TTY (Ctrl+F4). The app, pacman-mirrors, is now ignoring -i since it has no function when no display exists.
#30
