Switching (GNOME) from x-org to Wayland: Plank does not work in Wayland. Known issue.
Looking for alternative to have a SECOND Dock (two Docks needed).
Problem:
UHD-Monitor resolution: 3840 x 2160
Cairo / Latte-dock and all of the AUR Docks can not be convinced to open on the right side of the screen -
best is in the middle of the screen. Plank is on the right side using x-org.
cairo dock can be setup to open - almost - where ever you want.
Also cairo-dock can have several panels or docks
– but not on a screen with 3840 x 2160 pixels
…Seems to be limited to NOT UHD Monitors…
on 1920 x 1080 it is o.k.
I suppose you use mutter as wm - gnome default - you could try if compiz works better for the specific use case.
