Hey everybody,
I’m struggling to get a reliable and working display configuration.
I’m using my laptop display as well as two additional displays. But as soon as i have unplugged the displays and plug them in again my display configuration starts to stop working reliably.
From then on my first monitor displays “no connection” altough it is plugged into my laptop and turned on. I then have to turn the monitor off via its power button, enable and reorder the monitor in my display configuration. I sometimes have to do this multiple days in a row until out of nowhere it just starts working on its own again. This even happens after i close the lid of my laptop or set the system to hibernate.
In the display configuration menu there is a hint that constantly switches between “a new output has been added” and “An output has been removed”.
Any ideas on how to fix this?
Which logs may be helpful?
Kernel: 5.12.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=163e42d1-cbd3-4d86-97a4-3d15fd258d5c rw quiet apparmor=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP ProBook 445 G7 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: HP model: 8730 v: KBC Version 13.21.00 serial: <filter> UEFI: HP
v: S79 Ver. 01.05.00 date: 05/05/2021
ID-1: BAT0 charge: 32.4 Wh (97.0%) condition: 33.4/45.2 Wh (73.8%)
volts: 12.2 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: Unknown cycles: 22
RAM: total: 30.83 GiB used: 11.15 GiB (36.2%)
Info: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64
type: MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600106 cache: L2: 4 MiB bogomips: 31953
Speed: 2071 MHz min/max: 1400/2000 MHz boost: enabled Core speeds (MHz):
1: 2071 2: 1855 3: 1852 4: 4169 5: 1397 6: 1412 7: 1404 8: 1397
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: disabled, RSB filling
Device-1: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-2: Chicony HP HD Camera type: USB driver: uvcvideo bus-ID: 3-4:3
chip-ID: 04f2:b66a class-ID: 0e02 serial: <filter>
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3841x2280 s-dpi: 96 s-size: 1014x602mm (39.9x23.7")
s-diag: 1179mm (46.4")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
Monitor-2: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
Monitor-3: DisplayPort-0 res: 1920x1200 hz: 60 dpi: 94
size: 518x324mm (20.4x12.8") diag: 611mm (24.1")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.12.19-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.12.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 01:00.0
IF: enp1s0 state: down mac: <filter>
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:c822 class-ID: 0280
IF-ID-1: br-5d08eb5b58a6 state: down mac: <filter>
IF-ID-2: br-89100c4c0b0a state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
IP v6: <filter> scope: link
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-3:2 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 132.84 GiB (27.9%)
model: PC SN520 SDAPNUW-512G-1006 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: 20120006 temp: 49.9 C scheme: GPT
ID-1: / raw-size: 250 GiB size: 245.08 GiB (98.03%) used: 132.77 GiB (54.2%)
fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: 163e42d1-cbd3-4d86-97a4-3d15fd258d5c
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 64 MiB (25.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: BCF7-1538
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 225.97 GiB fs: ntfs label: Windows
uuid: F07C76E47C76A4CE
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 713 MiB fs: ntfs label: N/A
uuid: 280862E70862B38A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-3:2 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA chip-ID: 0bda:b00c
Device-2: 1-4:3 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00d8
class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-3:2 info: Primax HP Wireless Keyboard Mouse Kit
type: Keyboard,HID,Mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0461:4e90 class-ID: 0301
Device-2: 3-4:3 info: Chicony HP HD Camera type: Video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b66a
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 84.9 C mobo: 0.0 C gpu: amdgpu temp: 68.0 C
Processes: 280 Uptime: 1h 7m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1503 lib: 426
flatpak: 0 Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.06
