Unresolvable dependencies after switching to testing branch
It has been a while since the stable branch got updated so I wanted to try the testing branch.
As described in the Manjaro Wiki it should be straight forward.
Most packages got updated but these remain due to unresolvable dependencies:
sudo pacman -Syu
core is up to date
extra is up to date
multilib is up to date
:: Starting full system upgrade…
resolving dependencies…
warning: cannot resolve “libicuuc.so=78-64”, a dependency of “gspell”
warning: cannot resolve “libicuuc.so=78-64”, a dependency of “harfbuzz-icu”
warning: cannot resolve “audit=4.1.2”, a dependency of “lib32-audit”
warning: cannot resolve “expat=2.7.3”, a dependency of “lib32-expat”
warning: cannot resolve “libcap=2.77”, a dependency of “lib32-libcap”
warning: cannot resolve “libelf=0.194”, a dependency of “lib32-libelf”
warning: cannot resolve “pcre2=10.47”, a dependency of “lib32-pcre2”
warning: cannot resolve “libicuuc.so=78-64”, a dependency of “raptor”
:: The following packages cannot be upgraded due to unresolvable dependencies:
gspell  harfbuzz-icu  lib32-audit  lib32-expat  lib32-libcap  lib32-libelf  lib32-pcre2  raptor
:: Do you want to skip the above packages for this upgrade? \[y/N\]
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
When switching branch - you need to force fetching metadata by using a double -y
sudo pacman -Syyu
Thx, this solved the problem. May be this should be added to the Manjaro Wiki?
man pacman-mirrors
IMPORTANT
       After all operations ALWAYS syncronize and update your system with
              sudo pacman -Syyu
