[UPDATE] different conditions
Hi all,
after the 2026-08-12 stable update, for two days in a row I experienced this strange behaviour:
after leaving unattended the machine for more than 1 hour (lunch break) I found the machine powered off.
I disabled in plasma everything related to power saving.
Looking alt the logs I don’t see anything strange (but maybe I don’t know what to look for)
I’ll verify if in the next days the problem reappear
What can I look for?
BTW inxi says:
[mirto@bianco500 ~]$ inxi -zv8
Kernel: 7.1.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-7.1-x86_64
root=UUID=95b01923-1bed-4694-bb66-72e635384b04 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A info: frameworks v: 6.28.0
wm: kwin_wayland vt: 2 dm: N/A Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MAG X570 TOMAHAWK WIFI (MS-7C84)
v: 1.0 serial: <superuser required> uuid: <superuser required>
Firmware: UEFI vendor: American Megatrends LLC. v: 1.H0 date: 07/16/2024
System RAM: total: 64 GiB available: 62.71 GiB used: 5.21 GiB (8.3%)
(unregistered) size: 16 GiB speed: 2667 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: N/A
part-no: 3600 C18 Series serial: <filter>
Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102E
desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1754 min/max: 556/4854 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 1754 2: 1754 3: 1754
4: 1754 5: 1754 6: 1754 7: 1754 8: 1754 9: 1754 10: 1754 11: 1754 12: 1754
13: 1754 14: 1754 15: 1754 16: 1754 bogomips: 121604
xsaves xtopology
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 33 [Radeon RX 7600/7600
XT/7600M XT/7600S/7700S / PRO W7600] vendor: Sapphire driver: amdgpu
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8 ports:
active: DP-1,HDMI-A-2 empty: DP-2,HDMI-A-1,Writeback-1 bus-ID: 2f:00.0
chip-ID: 1002:7480 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
compositors: 1: kwin_wayland 2: Tabby driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 5760x2160 display-ID: 0
Monitor-1: DP-1 pos: primary,left model: LG (GoldStar) HDR 4K
serial: <filter> built: 2024 res: mode: 3840x2160 hz: 60 scale: 150% (1.5)
to: 2560x1440 dpi: 139 gamma: 1.2 chroma: red: x: 0.682 y: 0.310 green:
x: 0.267 y: 0.663 blue: x: 0.149 y: 0.047 white: x: 0.314 y: 0.329
size: 697x392mm (27.44x15.43") diag: 806mm (31.7") ratio: 16:9
modes: 3840x2160, 2560x1440, 1920x1080, 1280x720, 1024x768, 800x600,
720x480, 640x480
Monitor-2: HDMI-A-2 pos: right model: Sony TV 00 serial: <filter>
built: 2015 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 51 gamma: 1.2
chroma: red: x: 0.627 y: 0.341 green: x: 0.278 y: 0.596 blue: x: 0.153
y: 0.071 white: x: 0.282 y: 0.298 size: 952x535mm (37.48x21.06")
diag: 1092mm (43") ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900,
1280x1024, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
640x480
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.6-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 7600 XT (radeonsi navi33 ACO DRM
3.64 7.1.8-1-MANJARO) device-ID: 1002:7480 memory: 15.62 GiB unified: no
display-ID: :0.0
API: Vulkan v: 1.4.357 layers: 2 device: 0 type: discrete-gpu name: AMD
Radeon RX 7600 XT (RADV NAVI33) driver: mesa radv v: 26.1.6-arch1.1
device-ID: 1002:7480 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: lact wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
bus-ID: 2f:00.1 chip-ID: 1002:ab30 class-ID: 0403
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k7.1.8-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE driver: r8169 v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: e000 bus-ID: 25:00.0 chip-ID: 10ec:8125
class-ID: 0200
IF: enp37s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 26:00.0
IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 28:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlo1 state: down mac: <filter>
IF-ID-1: br0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
IF-ID-2: virbr0 state: down mac: <filter>
IF-ID-3: virbr1 state: down mac: <filter>
IF-ID-4: virbr2 state: down mac: <filter>
Info: services: NetworkManager, nfsd, sshd, systemd-timesyncd,
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 20.92 TiB used: 9.91 TiB (47.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 Plus
lanes: 4 tech: SSD serial: <filter> fw-rev: RKT4P1.3 temp: 27.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Sabrent model: Rocket 4.0 Plus
lanes: 4 tech: SSD serial: <filter> fw-rev: R4PB47.2 temp: 26.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST18000NM000J-2TV103
size: 16.37 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SC02 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 199.09 GiB (21.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 95b01923-1bed-4694-bb66-72e635384b04
ID-2: /BIANCO-COPIA raw-size: 16.37 TiB size: 16.3 TiB (99.60%)
used: 8.25 TiB (50.6%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
label: BIANCO-COPIA uuid: 9d0a6e10-7fee-4f13-8b63-780f10d5eaa8
ID-3: /BIANCO-SATA1 raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 795.46 GiB (43.4%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
label: BIANCO-SATA1 uuid: 9141152e-23a1-4727-a159-3cca321152cc
ID-4: /BIANCO-SSD2 raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 703.46 GiB (38.4%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:4
label: BIANCO-SSD2 uuid: 42c9201d-2d84-4197-b0aa-e45e907be1bd
ID-5: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 328 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: BD29-5527
Device-1: 1-4:2 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-5:2 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c84 class-ID: 0300
serial: <filter>
Hub-4: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-7: 5-3:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Hub-8: 5-3.4:3 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
Device-1: 5-3.4.2:4 info: Holtek Gaming Mouse [Redragon M908]
type: mouse,keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 04d9:fc4d class-ID: 0300
Device-2: 5-3.4.3:5 info: Winbond Drevo keyboard type: keyboard,mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 400mA chip-ID: 0416:a0f8 class-ID: 0301
serial: <filter>
Hub-9: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-10: 6-3:2 info: Realtek Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-11: 6-3.4:3 info: Realtek Hub ports: 4 rev: 3.1
System Temperatures: cpu: 45.2 C mobo: 38.0 C gpu: amdgpu temp: 46.0 C
mem: 62.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Packages: pm: pacman pkgs: 2034 libs: 461 tools: pamac pm: rpm pkgs: 0
pm: flatpak pkgs: 0
1: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
2: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
3: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
4: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
5: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
6: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
7: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
8: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 436
1: cpu: 7.7% command: zen pid: 1971 mem: 582.3 MiB (0.9%)
2: cpu: 7.1% command: dolphin pid: 2012 mem: 1234.2 MiB (1.9%)
3: cpu: 6.1% command: thunderbird pid: 1988 mem: 557.7 MiB (0.8%)
4: cpu: 3.5% command: kwin_wayland pid: 1417 mem: 306.5 MiB (0.4%)
5: cpu: 3.2% command: plasmashell pid: 1629 mem: 382.4 MiB (0.5%)
Memory top: 5 of 436
1: mem: 1234.2 MiB (1.9%) command: dolphin pid: 2012 cpu: 7.1%
2: mem: 582.3 MiB (0.9%) command: zen pid: 1971 cpu: 7.7%
3: mem: 557.7 MiB (0.8%) command: thunderbird pid: 1988 cpu: 6.1%
4: mem: 382.4 MiB (0.5%) command: plasmashell pid: 1629 cpu: 3.2%
5: mem: 306.5 MiB (0.4%) command: kwin_wayland pid: 1417 cpu: 3.5%
Processes: 436 Power: uptime: 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.03 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
tool: systemctl
Compilers: clang: 22.1.8 gcc: 16.1.1 Shell: Bash v: 5.3.15
running-in: tabby inxi: 3.3.41
