Unlocking KDEVault starts LibreOffice
This might be one of the strangest bugs I ever had. I’ve been using KDEs Vaults feature for quite some time now, to encrypt some important documents. But since a few weeks ago, everytime I unlock a vault LibreOffice starts and I have no idea why. It doesn’t do much, just showing the welcome screen where I could select a document to open. Besides from that the vault unlocks just fine and is mounted. However it does not open a file browser automatically.
Any idea what is going on there?
Sounds to me like it should open a file browser?
Perhapts the default action for directories got changed, it should be set like this:
$ xdg-mime query default inode/directory
org.kde.dolphin.desktop
If it doesn’t look like this on a plasma system you can (re)set it:
$ xdg-mime default org.kde.dolphin.desktop inode/directory
Thank you, yes - that solved the problem!
