Kicks me to grub, I get unkown file system, not even installed.
Sounds like some sort of malformed DVD.
What ISO did you use and how did you write it?
I burned the mate version, right clicked in windows 10 & chose burn image (windows native), wish there was a net install version, I have a 1.5 Gig flash.
I doubt that would work …
A tool like ventoy, rufus, etcher, or even a simple dd
would work though.
EDIT.
Well … according to the wiki, the windoze right-click actually should work
https://wiki.manjaro.org/index.php/Burn_an_ISO_File#Burning_to_a_CD.2FDVD_in_Windows
That’s not enough for the available mate ISOs.
Min. version requires 2.2 GiB, normal mate version 2.9 GiB.
I had another USB, I burned mate to just now. Yesterday it didn’t want to boot. Will try in a min.
