Hi,
pinxi:
System: Kernel: 5.14.0-0-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Console: tty pts/1 wm: kwin_x11 DM: SDDM
Machine: Type: Laptop System: MEDION product: P6645 MD61379 v: 5.13_VEB_1AUOK026 serial: <filter>
Mobo: MEDION model: M15WKN v: 0.2 serial: <filter> UEFI: American Megatrends v: 206 date: 10/30/2018
Battery: ID-1: BAT0 charge: 39.4 Wh (100.0%) condition: 39.4/41.6 Wh (94.6%) volts: 12.8 min: 11.4 model: M153137
type: Unknown serial: <filter> status: Full cycles: 81
CPU: Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP arch: Kaby Lake note: check rev: B cache:
L1: 256 KiB L2: 6 MiB L3: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28808
Speed: 900 MHz min/max: 400/3900 MHz volts: 0.7 V ext-clock: 100 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900
5: 900 6: 900 7: 900 8: 900
Graphics: Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0
class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Pegatron driver: nvidia v: 470.63.01 bus-ID: 02:00.0
chip-ID: 10de:1d10 class-ID: 0302
Display: server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting resolution: 1920x1080~60Hz
s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.2.1 direct render: Yes
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Pegatron driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.14.0-0-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Network: Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel port: 4000 bus-ID: 00:14.3
chip-ID: 8086:9df0 class-ID: 0280
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8 bus-ID: 1-10:4
Drives: Local Storage: total: 357.72 GiB used: 180.83 GiB (50.6%)
ID-1: /dev/nvme0n1 vendor: Phison model: E12-256G-SSD-B3-BB1 size: 238.47 GiB speed: 31.6 Gb/s lanes: 4
rotation: SSD serial: <filter> rev: ECFM12.1 temp: 30 (303 Kelvin) C scheme: GPT
ID-2: /dev/sda vendor: Samsung model: SSD 840 PRO Series size: 119.24 GiB speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 6B0Q scheme: MBR
Partition: ID-1: / size: 233.43 GiB used: 114.04 GiB (48.9%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: file size: 4 GiB used: 4 MiB (0.1%) priority: -2 file: /swapfile
Sensors: System Temperatures: cpu: 42.0 C mobo: N/A
Info: Processes: 243 Uptime: 5h 29m wakeups: 1 Memory: 7.66 GiB used: 2.91 GiB (38.0%) Init: systemd v: 248 Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1461 Shell: Bash (sudo) v: 5.1.8 running-in: yakuake pinxi: 3.3.03-2
Just noticed, in System Settings > Hardware Configuration,
under Serial bus controller:
SPI contr.
Unknown device name
Serial IO I2C contr.
USB 3.1 xHCI contr.
SMBus contr.
I looked at dmesg but noticed nothing.
Any idea how to find out which device this is?
Thanks.
