Hello!
I am new to Manjaro and zsh and I’ve encountered something on the CLI that I’m unfamiliar with.
It is this [1] on the right side of the prompt after entering a command. By default it appears red and so too does the rightmost > of the prompt >>>.
My example command that does this is pacman -Ss informant.
I’m not sure but maybe it tells you that just one command line is stored you can retrieve with cursor keys? On my system output is zero as the package does not exists.
