Hi. I really want to use Budgie on my Pinebook Pro. Everything seems to work just fine when I install it via the manjaro-arm-installer, but I can’t for the life of me figure out how to enable “tap to click.” Anyone have any inside info on how I can get that to work? The option doesn’t appear in the gnome settings like it does on other builds.
Wonder if you reverse the tap in post #6 here. This guy wanted to turn it off.
https://forum.endeavouros.com/t/solved-tap-to-click-on-touchpad/13597/6
