Uninstalling snapcraft
#1
Hi, i’m struggling to install Spotify and Discord through Canonical’s Snap, the problem is that I’ve done so many wrong things that I don’t know where I ended up but I get an error that snap cannot communicate with server, and the snapd.service status it’s failed.
I followed the steps from their website, but I couldn’t find spotify anywhere in the launcher so I removed it, then I tried to remove snap and install it through pacman.
The way I removed snap first time is deleting snapd folder from /var/lib.
No I’m in a loophole and I don’t know what to do, can you explain me how to reinstall snapcraft, and then properly get Spotify and maybe make it appear in launcher?
[SOLVED] Snapd - Completely uninstall
#2
how did you install? you followed these directions?
https://docs.snapcraft.io/installing-snap-on-manjaro-linux/6807
deleting a folder is not the same as uninstalling. try and manually disable snapd.socket and uninstalling with pacman
sudo systemctl stop snapd.socket
sudo systemctl disable snapd.socket
sudo pacman -R snapd
given, that works without issue, you can now install snapd and enable snapd.socket
sudo pacman -S snapd
sudo systemctl enable --now snapd.socket
sudo ln -s /var/lib/snapd/snap /snap
install spotify:
sudo snap install spotify
closed #3
