uninstalling npm packages
Hello,
I am trying to uninstall npm packages to fix an error that occurs when installing a package:
npm: /usr/lib/node_modules/npm/node_modules/cacache/node_modules/glob/LICENSE already exists in filesystem
I have been following this thread
but when I run the npm uninstall commands the directory remains there, same thing if I try to manually remove it, or try to uninstall using pacman.
Any ideas?
Thank you
Try the package with the command "overwrite" to install.
sudo pacman -S packagename --overwrite "*"
What npm package? Have you check to see if it's available in the AUR?
