Can these files be manually deleted without any problems in the future?
If you are not sure if a file with {filename} is used for a package being installed use the command:
pacman -Qo {filename}
Replace {filename} by the real filename incl. path. If nothing shows up and the filename is linked to a package you have already removed you can delete it.
Wanted to delete the entire anbox folder as it uses approximately 300MB
You could rename it first, wait if you get in trouble in the next two weeks, if nothing happens - delete it. If you are brave - delete it right away.
Thanks for the suggestion, I changed the folder name and took a look at the weekend. All good: , then delete completely.
