Hi, I’m pretty desperate here. Here are the details
Ran a large system upgrade today, the 21st of march. 270ish packages. Was away from computer for a half week. npm/js node bullshit prevented this upgrade, so I removed them and upgraded. No issues.
Reboot.
I then removed some crypto mining software from computer, which had required the npm/node js. No problems yet.
I remembered that I had downloaded keybase (an encryption chat gui) and that it ran on start up, so I checked how to delete it and disable the daemon.
Ran:
systemctl disable --user keybase
All okay thus far…
Found keybase in the manjaro package manager gui and removed it there. Woulda just used terminal with pacman/yay, but couldn’t locate keybase anywhere. I had built it prior using aur or source or something, I don’t remember.
10 seconds after removing it via gui, internet connection is suddenly gone. No connections to be found anywhere. Checked networkmanager in its various forms (nmtui, nmcli etc), connections are gone. Computer is slow as hell for a minute or so when even clicking the plasma nm-applet.
ip link
1: lo:…
2: enp0s31f6: <NO-CARRIER, BROADCAST, MULTICAST, UP>… state DOWN…
Say screw it, reboot into grub, then main arch partition (dual boot). Internet is also broken in this partition…
The internet has broken in 2 seperate partitions on a dual boot ssd. My computer has been rendered useless.
I don’t know where to find the broken link in the chain, please help.
Haven’t ran timeshift from before big update as I want to diagnose beforehand.
Will be sleeping soon, respond in the morning. Thank you for reading this wall of text.
