Hi,
it is about a new install on a clevo NL51RU notebook (Ryzen 4500U with Radeon Graphics)
I obtaind this notebook new with xubuntu preinstalled. This is working good, but i would prefere manjaro. i want to keep the xubuntu until manjaro is working well.
Manjaro istallation "XFCE minimal) via usb-stick works out of the box, both with free drivers or proprietary.
I use the same /home partition with xubuntu.
First boot into manjaro is doing well, login via lightdm works fine. system is perfectly usable.
After updating the system with Pamac, like suggested, the system is booting into a black screen. It is possible to log in as root on TTY… and start lightdm to log in as user, but not with full functionality like shutdown, use Pamac etc.
Sometimes it was possible to log in as user, but not to “startx” → “no screen found”…
Sometimes it is even not possible to log in as user also shutdown as root does not bring the System to halt.
What do you think about this?
Is the problem the /home directory i also use with xubuntu or do you have another idea?
Thank you in advance!
