Uninstall grub for other distro
#1
after several times my manjaro grub overwriten after updating other distro kernel i have idea to uninstall other distro grub and make manjaro grub as only one boot utility to handle my boot. is it even possible to do that.?
#2
This is a paculiarity of Manjaro
Boot in the other distribution and uninstall grub from the package manager, even better if you install them choose to not install the boot loader if possible
Should this be moved to #other-os category
#3
Is it save to uninstall other distro grub…?
#4
It is if you do it correctly. Do you know how to do so? If not, some research will tell you how. :slight_smile:
regards
#5
any clue to do that.?
i have searching but what i got is just simple article to uninstall linux and just use windows
#6
You have to build YOUR behavior!.. :joy: I mean:
  • Boot to Manjaro and install grub (use proper method, regarding it is UEFI or MDSOS Legacy system)
  • Do not install grub from any other dual-boot distro, or uninstall grub package of your other distro.
#7
ok i’ll try,… thank you guys…
closed #8
