When running winecfg
or wineboot
, or anything else to do with wine
I get the following error:
wine: Unhandled page fault on execute access to 00007FF680AD49F0 at address 00007FF680AD49F0 (thread 00fc), starting debugger...
However, when I run it when using the NVIDIA GPU, or in hybrid mode, it runs fine.
I was recently uninstalled my NVIDIA driver for it to be reinstalled, and decided to run wine
on the intel GPU, and it worked fine!
So I have a feeling it’s got something to do with my GPU drivers…I don’t know.
I would appreciate any help, thanks.
System info
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=ee069653-05a6-40d7-911d-edad961c95f4 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 80TU v: Lenovo ideapad 310-14IKB
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 310-14IKB
Mobo: LENOVO model: Torronto 4C2 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: 3JCN21WW date: 09/23/2016
ID-1: BAT0 charge: 20.2 Wh (100.0%) condition: 20.2/30.0 Wh (67.3%)
volts: 8.5 min: 7.4 model: SMP L15M2PB2 type: Li-poly serial: <filter>
status: full
RAM: total: 19.44 GiB used: 4.14 GiB (21.3%)
RAM Report:
Info: model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xEC
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3500 high: 3501 min/max: 400/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 3500 2: 3500 3: 3500
4: 3501 bogomips: 23209
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel ports:
active: DP-1,eDP-1 empty: HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5916 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 920MX] vendor: Lenovo driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s
lanes: 4 link-max: gen: 3 speed: 8 GT/s bus-ID: 03:00.0 chip-ID: 10de:134f
class-ID: 0302
Device-3: Chicony EasyCamera type: USB driver: uvcvideo bus-ID: 1-4:4
chip-ID: 04f2:b57d class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3280x1050 s-dpi: 97 s-size: 862x276mm (33.94x10.87")
s-diag: 905mm (35.63")
Monitor-1: DP-1 pos: top-right res: 1680x1050 hz: 60 size: N/A modes:
max: 1024x768 min: 640x480
Monitor-2: eDP-1 pos: primary,bottom-l model: BOE Display 0x0698
built: 2015 res: 1600x900 hz: 60 dpi: 132 gamma: 1.2
size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-7:7
chip-ID: 0cf3:e500 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 372.62 GiB used: 303.64 GiB (81.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0102 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST9160412AS
size: 149.05 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: HPM1 scheme: MBR
ID-1: / raw-size: 223.27 GiB size: 218.71 GiB (97.96%)
used: 189.09 GiB (86.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
