1610 MB is required to download ungoogled-chromium from aur
I don’t understand where the problem comes from that it has so much volume?
Do you mean the one to compile or the one already compiled?
With or without the (build) dependencies?
I used this command to install
yay -S ungoogled-chromium
Seems you tried installing the version that needs compiling.
Try installing the binary package (one that has “-bin”): see aur for an overview on the available packages.
However, I advise to not just instlling an aur package without searching the aur website first. Often there are different packages.
As OP uses yay, it is also possible to use
yay ungoogled-chromium
that is, without the -S option, in the search list there are also short descriptions. Just in case, somebody is too lazy to open the AUR website (as I usually am).
