I have an unmountable, unfixable Btrfs filesystem after a power failure during write.
It’s a backup itself, so nothing critical, but I am not comfortable using Btrfs, if a single power failure can completely trash a filesystem beyond repair. I though CoW is rugged exactly against that…
Whatever I try - I get the same output:
# btrfs check --repair --init-extent-tree /dev/sdc
enabling repair mode
Opening filesystem to check...
parent transid verify failed on 1634923266048 wanted 1530 found 1532
Ignoring transid failure
Couldn't setup extent tree
Couldn't setup device tree
ERROR: cannot open file system
I’ve tried everything so far, except for btrfs-zero-log, but I don’t have that tool!
I have btrfs-progs 4.20 installed, and no btrfs-zero-log to be found.
Where did it go? Where can I get it?
I’ve tried installing btrfs-progs-git from AUR, but it failed:
==> ERROR: One or more files did not pass the validity check!
==> ERROR: Makepkg was unable to build btrfs-progs-git.
For the sake of completness:
# mount /dev/sdc backup
mount: /mnt/backup: wrong fs type, bad option, bad superblock on /dev/sdc, missing codepage or helper program, or other error.
# btrfs restore -xmSvi /dev/sdc .
Could not open root, trying backup super
# btrfs check --repair /dev/sdc
# btrfs check --repair --init-csum-tree /dev/sdc
Creating a new CRC tree
# btrfs-image /dev/sdc image
ERROR: open ctree failed
ERROR: create failed: Success
# btrfs-select-super -s 1 /dev/sdc
Open ctree failed
# btrfs rescue super-recover -v /dev/sdc
All Devices:
        Device: id = 1, name = /dev/sdc
Before Recovering:
        [All good supers]:
                device name = /dev/sdc
                superblock bytenr = 65536
                superblock bytenr = 67108864
                superblock bytenr = 274877906944
        [All bad supers]:
All supers are valid, no need to recover
EDIT:
I just found btrfs-zero-log. It’s in btrfs rescue zero-log - but it didn’t work either:
# btrfs rescue zero-log /dev/sdc
ERROR: could not open ctree
I’ve also asked about it on Stack Exchange:
I hear you.
Similar experience here in my brief foray into butter fs, when it fails it fails big time, unrecoverable file system implosion in my case.
There is a reason it was banished from RHEL.
Wasn’t that RHEL exclusion 5years ago or something?
It is my understanding that it is resilient if you are using its raid10 capabilities. With a single device, not that much.
More like 1 or 2 I think.
