[HowTo] have Manjaro insult you whenever you do something dumb
Difficulty: ★★★☆☆
Have sudo insult you:
Whenever you use sudo and typing the wrong password, you can have the sudo application insult you:
fab-user@fab-manjaro:~
$ sudo ls /
[sudo] password for fab-user:
Hold it up to the light --- not a brain in sight!
It can only be attributed to human error.
sudo: 3 incorrect password attempts
  • To activate this feature:
    sudo visudo
  • At the end of the file before the #includedir /etc/sudoers.d type:
    Defaults insults
  • save and quit
  • Done!
Have any wrongly typed command insult you
(Credits @chomsky and hbakke, the author of this package)
  • Execute:
    pamac install bash-zsh-insulter
  • Add the following to /etc/bash.bashrc or any of the other locations where you can configure your shell automatically during login:
    if [ -f /etc/bash.command-not-found ]; then
        . /etc/bash.command-not-found
    fi
  • exit the terminal
  • open the terminal again
  • try it out
    $ cdd /home
      Your application for reduced salary has been sent!
    /bin/bash: cdd: command not found
    $ oops
      What if I told you... it is possible to type valid commands.
    /bin/bash: oops: command not found
    $ lf
      Fake it till you make it!
    /bin/bash: lf: command not found
P.S. 3★ difficulty because we’re changing the sudoers file here and if done incorrectly, no more sudo for you!!! :man_shrugging:
I thought the standard way was to use sudoedit? :man_shrugging:/:woman_shrugging:
Anyhow :+1::wink:
You can also install bash-zsh-insulter if you like being insulted with every wrong command you type in the terminal.
Better it is moving changes in /etc/sudoers to separated files in /etc/sudoers.d dir. Add @includedir /etc/sudoers.d
The line was commented by a @ and after uncommenting I got the following error:
/etc/sudoers:96: syntax error, unexpected COMMAND
What makes it even weirder is that I do have the following changes in a custom conf:
[manjaro sudoers.d]# cat 20-chomsky
Defaults	insults
Defaults	timestamp_timeout=20
Defaults	timestamp_type=global
Everything is working as it should though. Any thoughts on the @…?
it’s actually not a “comment”…
it’s how it have to be
@includedir .....
Ah I see, thanks for the reply.
sudoedit or sudo -e is standard for whenever you are making a system file edit.
except for editing sudoers
The funny thing is … its partially because visudo works a bit like sudoedit that you should.
But it does a little more - it wont allow you to create a malformed sudoers file.
see:
https://wiki.archlinux.org/index.php/Sudo#Using_visudo
I didn’t know that this existed. I love it so much!
Also you have package sl
Which will give you a choo-choo whenever you mistype ls
(PS … also package bash-zsh-insulter in AUR)
:sweat_smile:. +1 to have this as default setting in all Manjaro editions
While were at it…
Ahhh yes indeed you’re right: Configure sudo using drop-in files in /etc/sudoers.d
How would one fix this? What happens when you do that (not having the Defaults insults at the proper place)? I guess to fix it you would use command su then modify the sudoers file with visudo?
Actually the best place to put that “directive” is in a separate config piece under /etc/sudoers.d, eg. like /etc/sudoers.d/00_insults
When you use visudo it won’t allow you to make mistakes that render sudo to error-out due to syntax errors.
But mistakes in functionality can always happen and the last resort would be to boot with single kernel option to drop to a root shell on boot and fix stuff from there on…
My advice would be to never modify the /etc/sudoers file, but instead always work with separate config pieces under /etc/sudoers.d
You’d have to boot a Manjaro USB, chroot and overwrite your messed up version with the original but with visudo that’s very unlikely (though not 0)
:+1:
I messed up I was unable to have sudo privilege again (I could su - and visudo, then I removed the Defaults insult line, rebooted but no sudo for me despite the sudoers file back to its previous state, so I Timeshifted from a month old backup), but that is maybe because I have previously modified the sudoers file and have a line at the bottom to be able to execute some commands with sudo without password maybe, I don’t know, this is what I have at the very bottom of my sudoers file:
omano ALL= NOPASSWD: /usr/bin/command1, /usr/bin/command2, /usr/bin/command3
So two question, is it right to have placed this line at the very bottom? Should I move it somewhere else?
I’m not sure what would be the best thing to do. I’ll do another Timeshift backup now I have restored the system from previous backup and upgraded everything again, I think I might do the other approach and use the external file to add this as TriMoon suggested.
//EDIT: TriMoon suggestion worked like a charm, I don’t know why I messed up before, I think my line at the very bottom of sudoers file might be the culprit.
