Undoing dkms install
kernel
#1
In order to get the touchpad on my Lenovo Ideapad 130 - 15IKB, I did dkms install as suggested here. Even after that, the touchpad was not working.
I, now, want to ‘undo’ the dkms install command. I read man dkms and think that the correct thing to do is to sudo dkms remove module-name. But being a newbie, I thought of asking here before trying it out.
Is that what I do to remove undo dkms install module-name command?
#2
No, use pacman:
sudo pacman -Rs dkms
reboot
For future references use this wiki page
#3
I guess I did not provide adequate information in the question. I do not want to remove dkms. I want to remove a module installed using dkms command. Please see the updated question.
#4
Fair enough :slight_smile:
yes
closed #5
