Understanding the cause of sudden reboot
Its been about a month since installation of Manjaro on ThinkPad X220. Just now experienced sudden reboot. Can you please assist to understand the cause of it?
  Kernel: 5.14.7-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
  root=UUID=e25bf92b-dc28-49e2-a3e4-14007fc6fc21 rw quiet apparmor=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
  Type: Laptop System: LENOVO product: 4291WGC v: ThinkPad X220
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: LENOVO model: 4291WGC serial: <filter> UEFI-[Legacy]: LENOVO
  v: 8DET76WW (1.46 ) date: 06/21/2018
  ID-1: BAT0 charge: 2.7 Wh (96.4%) condition: 2.8/57.7 Wh (4.8%) volts: 12.4
  min: 11.1 model: SANYO 42T4861 type: Li-ion serial: <filter> status: Unknown
  Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
  status: N/A
  RAM: total: 7.65 GiB used: 2.3 GiB (30.0%)
  Info: Dual Core model: Intel Core i5-2520M bits: 64 type: MT MCP
  arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
  cache: L2: 3 MiB bogomips: 19941
  Speed: 944 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 944 2: 1967
  3: 897 4: 839
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
  constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
  flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear
  mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
  pebs pge pln pni popcnt pse pse36 pti pts rdtscp sep smx ssbd sse sse2
  sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer
  vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
  Type: l1tf
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0126
  class-ID: 0300
  Device-2: Chicony Lenovo Integrated Camera (0.3MP) type: USB
  driver: uvcvideo bus-ID: 1-1.6:5 chip-ID: 04f2:b217 class-ID: 0e02
  Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
  loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3286x1080 s-dpi: 96 s-size: 869x285mm (34.2x11.2")
  s-diag: 915mm (36")
  Monitor-1: LVDS-1 res: 1366x768 hz: 60 dpi: 125 size: 277x156mm (10.9x6.1")
  diag: 318mm (12.5")
  Monitor-2: DP-1 res: 1920x1080 hz: 60 dpi: 96 size: 510x287mm (20.1x11.3")
  diag: 585mm (23")
  OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2)
  v: 3.3 Mesa 21.2.2 compat-v: 3.0 direct render: Yes
  vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  chip-ID: 8086:1c20 class-ID: 0403
  Sound Server-1: ALSA v: k5.14.7-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.37 running: no
  Device-1: Intel 82579LM Gigabit Network vendor: Lenovo ThinkPad T520
  driver: e1000e v: kernel port: 5080 bus-ID: 00:19.0 chip-ID: 8086:1502
  class-ID: 0200
  IF: enp0s25 state: down mac: <filter>
  Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
  v: kernel port: efa0 bus-ID: 03:00.0 chip-ID: 8086:0085 class-ID: 0280
  IF-ID-1: wwp0s29u1u4i6 state: down mac: <filter>
  Device-1: Broadcom BCM2045B (BDC-2.1) type: USB driver: btusb v: 0.8
  bus-ID: 1-1.4:4 chip-ID: 0a5c:217f class-ID: fe01 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 223.57 GiB used: 44.76 GiB (20.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
  size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: R013 scheme: MBR
  ID-1: / raw-size: 223.57 GiB size: 219 GiB (97.96%) used: 44.76 GiB (20.4%)
  fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: e25bf92b-dc28-49e2-a3e4-14007fc6fc21
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
  file: /swapfile
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Hub-3: 1-1.2:3 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  chip-ID: 0bda:5411 class-ID: 0900
  Device-1: 1-1.2.2:6 info: China Resource Semico Usb Mouse type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
  power: 98mA chip-ID: 1a2c:0042 class-ID: 0301
  Device-2: 1-1.2.3:7 info: China Resource Semico Keyboard type: Keyboard,HID
  power: 100mA chip-ID: 1a2c:2d23 class-ID: 0300
  Device-3: 1-1.4:4 info: Broadcom BCM2045B (BDC-2.1) type: Bluetooth
  driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:217f
  Device-4: 1-1.6:5 info: Chicony Lenovo Integrated Camera (0.3MP) type: Video
  driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 200mA
  Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
  Hub-5: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 2-1.1:3 info: Apple iPhone 5/5C/5S/6/SE type: Still Imaging
  driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
  chip-ID: 05ac:12a8 class-ID: 0601 serial: <filter>
  Device-2: 2-1.4:4 info: Ericsson Business Mobile Networks BV F5521gw
  type: Communication,Abstract (modem),CDC-Data
  driver: cdc_acm,cdc_ncm,cdc_wdm interfaces: 11 rev: 2.0 speed: 480 Mb/s
  chip-ID: 0bdb:1911 class-ID: 0202 serial: <filter>
  System Temperatures: cpu: 62.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 3486
  Processes: 189 Uptime: 6m wakeups: 3 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: 1244 pacman: 1232 lib: 331 flatpak: 0
  snap: 12 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
[    0.000000] microcode: microcode updated early to revision 0x2f, date = 2019-02-17
[    0.000000] Linux version 5.14.7-2-MANJARO (builduser@fv-az121-187) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Wed Sep 22 12:22:56 UTC 2021
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64 root=UUID=e25bf92b-dc28-49e2-a3e4-14007fc6fc21 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[    0.000000] Disabled fast string operations
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[    0.000000] signal: max sigframe size: 1776
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000020200000-0x000000003fffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000040000000-0x00000000401fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000040200000-0x00000000da99efff] usable
[    0.000000] BIOS-e820: [mem 0x00000000da99f000-0x00000000dae9efff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000dae9f000-0x00000000daf9efff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000daf9f000-0x00000000daffefff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000dafff000-0x00000000daffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000db000000-0x00000000df9fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed08000-0x00000000fed08fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.140410] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.140492]  #2
[    0.143799]  #3
[    0.147860] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    3.279998] systemd-journald[276]: File /var/log/journal/f0c23e94d2b544deaf01a46dbde1ee50/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    3.687393] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[    3.828750] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\_SB.PCI0.LPC.PMIO) (20210604/utaddress-204)
[    3.828761] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPC.LPIO) (20210604/utaddress-204)
[    3.828767] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPC.LPIO) (20210604/utaddress-204)
[    3.828773] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPC.LPIO) (20210604/utaddress-204)
[    3.828778] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    4.131407] iwlwifi 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[    4.614686] at24 0-0050: supply vcc not found, using dummy regulator
[    4.707315] at24 0-0051: supply vcc not found, using dummy regulator
[    5.537718] kauditd_printk_skb: 79 callbacks suppressed
[   11.335122] kauditd_printk_skb: 17 callbacks suppressed
There is nothing in your information above that would explain a sudden reboot, but spontaneous reboots are rare and are often caused by a bad (connection to the) power supply. An intermittent contact for instance.
In some cases, overheating could possibly also trigger that, but this is really specific to the processor manufacturers ─ i.e. AMD and Intel handle those things differently.
:man_shrugging:
Please read this:
Especially the Linux has multiple kernels section, then try an LTS kernel and hopefully the problem will go away “automagically”. :grin:
:crossed_fingers:
