The alsamixer settings are not saved even by the “alsactl store” command. I am using a Creative Sound Blaster X G6 external sound card. Before manually reconnecting the card to the usb port - the system fixed the alsa sound frequency output at 48kHz. Also no audio recording devices are available, because the “Line In” value is fixed. Changes in alsamixer with saving do not work. I try to play the file through VLC with output to alsa - sample rate is always static at 48000. Here are stream0 values before reconnecting the card:
cat /proc/asound/G6/stream0
Creative Technology Ltd Sound BlasterX G6 at usb-0000:13:00.0-6, full speed : USB Audio
Playback:
Status: Running
Interface = 1
Altset = 1
Packet Size = 294
Momentary freq = 48005 Hz (0x30.0130)
Feedback Format = 10.14
Interface 1
Altset 1
Format: S24_3LE
Channels: 2
Endpoint: 0x01 (1 OUT) (ASYNC)
Rates: 48000
Bits: 24
Channel map: FL FR
Sync Endpoint: 0x81 (1 IN)
Sync EP Interface: 1
Sync EP Altset: 1
Implicit Feedback Mode: No
Capture:
Status: Stop
Interface 2
Altset 1
Format: S24_3LE
Channels: 2
Endpoint: 0x82 (2 IN) (ASYNC)
Rates: 48000
Bits: 24
Channel map: FL FR
Here are after:
cat /proc/asound/G6/stream0 ✔
Creative Technology Ltd Sound BlasterX G6 at usb-0000:13:00.0-6, high speed : USB Audio
Playback:
Status: Running
Interface = 1
Altset = 2
Packet Size = 72
Momentary freq = 44103 Hz (0x5.834d)
Feedback Format = 16.16
Interface 1
Altset 1
Format: S24_3LE
Channels: 2
Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000
Data packet interval: 125 us
Bits: 24
Channel map: FL FR
Sync EP Altset: 1
Interface 1
Altset 2
Format: S32_LE
Channels: 2
Bits: 32
Channel map: FL FR
Sync EP Altset: 2
Capture:
Status: Stop
Interface 2
Altset 1
Format: S24_3LE
Channels: 2
Bits: 24
Channel map: FL FR
Interface 2
Altset 2
Format: S32_LE
Channels: 2
Bits: 32
Channel map: FL FR
Both results were obtained during sound playback. After reconnecting, the settings in alsamixer are also not saving, but there is an additional slider (which was always there once) - Speaker Clock Source (enable/disable DSP). I am using a fresh system with kernel 6.7.4-2.
