I have an issue with my instance of Vorta (AUR Install - Latest Version) in which the GUI window does not appear when launched by root on the terminal.
There doesn’t appear to be a /root/.config/vorta
folder.
At launch, the prior version’s backup tasks runs, but without the GUI:
root@MidnightStarSign:/home/sarah# vorta
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
2023-01-06 15:58:46,135 - vorta.i18n - DEBUG - Loading translation failed for ['en-GB', 'en-Latn-GB'].
kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DE
SKTOP
2023-01-06 15:58:46,217 - root - DEBUG - Expected error parsing file in .ssh: authorized_keys (You can saf
ely ignore this)
2023-01-06 15:58:46,277 - vorta.views.source_tab - DEBUG - Added item number 0 from 1
2023-01-06 15:58:46,278 - vorta.views.source_tab - DEBUG - Added item number 1 from 2
2023-01-06 15:58:46,384 - root - INFO - Using NetworkManagerMonitor NetworkStatusMonitor implementation.
2023-01-06 15:58:46,415 - vorta.borg.jobs_manager - DEBUG - Add job for site default
2023-01-06 15:58:46,415 - vorta.borg.jobs_manager - DEBUG - Start job on site: default
2023-01-06 15:58:46,417 - vorta.borg.borg_job - INFO - Running command /usr/bin/borg --version
2023-01-06 15:58:46,640 - vorta.borg.jobs_manager - DEBUG - Finish job for site: default
2023-01-06 15:58:46,640 - vorta.scheduler - DEBUG - Refreshing all scheduler timers
2023-01-06 15:58:46,640 - vorta.borg.jobs_manager - DEBUG - No more jobs for site: default
2023-01-06 15:58:46,642 - vorta.scheduler - INFO - Setting timer for profile 1
2023-01-06 15:58:46,643 - vorta.scheduler - DEBUG - Scheduling next run for 2023-01-07 12:00:00
Is there a way to reset vorta such that it works similar to how it does on a new install to reset the GUI (other users are able to launch vorta via CLI successfully on new installs)?
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=f11386cf-342d-47ac-84e6-484b7b2f377d rw rootflags=subvol=@
radeon.modeset=1 nvdia-drm.modeset=1 quiet
cryptdevice=UUID=059df4b4-5be4-44d6-a23a-de81135eb5b4:luks-disk
root=/dev/mapper/luks-disk apparmor=1 security=apparmor
resume=/dev/mapper/luks-swap udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4408
date: 10/27/2022
RAM: total: 62.71 GiB used: 42.24 GiB (67.4%)
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3921 high: 4100 min/max: 2200/6358 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4100 2: 4100
3: 4100 4: 4099 5: 4100 6: 4100 7: 4099 8: 4100 9: 4099 10: 2200 11: 4099
12: 4099 13: 4099 14: 4099 15: 2200 16: 4100 17: 4100 18: 4099 19: 4100
20: 4100 21: 4100 22: 4099 23: 4100 24: 4100 25: 2200 26: 4100 27: 4100
28: 4100 29: 4099 30: 4097 31: 4100 32: 4099 bogomips: 262516
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia
v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 0b:00.0 chip-ID: 10de:2484 class-ID: 0300
Device-2: AMD Cape Verde PRO [Radeon HD 7750/8740 / R7 250E]
vendor: VISIONTEK driver: radeon v: kernel alternate: amdgpu arch: GCN-1
code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports: active: DP-3,DP-4
empty: DP-1, DP-2, DP-5, DP-6 bus-ID: 0c:00.0 chip-ID: 1002:683f
class-ID: 0300 temp: 54.0 C
Device-3: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 9-2:3 chip-ID: 0c45:6367 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: radeonsi
gpu: radeon display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x2160 s-dpi: 80 s-size: 1829x686mm (72.01x27.01")
s-diag: 1953mm (76.91")
Monitor-1: DP-1 pos: 1-2 res: 1920x1080 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: DP-1-3 pos: 2-1 res: 1920x1080 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
Monitor-3: DP-1-4 pos: 1-1 res: 1920x1080 dpi: 93
Monitor-4: DP-3 pos: primary,2-2 res: 1920x1080 dpi: 82
Monitor-5: DP-4 pos: 2-4 res: 1920x1080 dpi: 82
Monitor-6: HDMI-0 pos: 1-3 res: 1920x1080 dpi: 93
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce RTX
3070/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel bus-ID: 5-1:9 v: kernel chip-ID: 30be:1019 pcie:
class-ID: 0102 gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 0b:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series] vendor: VISIONTEK driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 0c:00.1
chip-ID: 1002:aab0 class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Schiit Audio Unison Universal Dac type: USB driver: snd-usb-audio
Device-5: JMTek LLC. Plugable USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-2:3 chip-ID: 0c76:120b
class-ID: 0300 serial: <filter>
Device-6: ASUSTek ASUS AI Noise-Cancelling Mic Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-4:4 chip-ID: 0b05:194e
Device-7: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.63 running: yes
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
driver: btusb v: 0.8 bus-ID: 5-5.3:7 chip-ID: 0a12:0001 class-ID: e001
Device-1: luks-c847cf9f-c6b5-4624-a25e-4531e318851a maj-min: 254:2
type: LUKS dm: dm-2 size: 3.64 TiB
Components:
p-1: sda1 maj-min: 8:1 size: 3.64 TiB
Device-2: luks-swap maj-min: 254:1 type: LUKS dm: dm-1 size: 12 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 12 GiB
Device-3: luks-disk maj-min: 254:0 type: LUKS dm: dm-0 size: 919.01 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 919.01 GiB
Local Storage: total: 9.13 TiB used: 3.39 TiB (37.1%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
rev: 111110WD temp: 56.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
rev: 211070WD temp: 47.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD4005FZBX-00K5WB0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: ASolid model: USB
size: 29.3 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 0000 scheme: MBR
ID-1: / raw-size: 919.01 GiB size: 919.01 GiB (100.00%)
used: 717.25 GiB (78.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-disk label: N/A uuid: N/A
used: 39.5 MiB (7.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
uuid: 8922-E04D
ID-3: /home raw-size: 919.01 GiB size: 919.01 GiB (100.00%)
ID-4: /mnt/System_Root raw-size: 919.01 GiB size: 919.01 GiB (100.00%)
ID-5: /run/media/sarah/ConvergentRefuge raw-size: 3.64 TiB
size: 3.64 TiB (100.00%) used: 2.17 TiB (59.6%) fs: btrfs dev: /dev/dm-2
maj-min: 254:2 mapped: luks-c847cf9f-c6b5-4624-a25e-4531e318851a
label: ConvergentRefuge uuid: 7d295e73-4143-4eb1-9d22-75a06b1d2984
ID-6: /run/media/sarah/MSS_EXtended raw-size: 731.51 GiB
size: 731.16 GiB (99.95%) used: 529.35 GiB (72.4%) fs: xfs
dev: /dev/nvme1n1p1 maj-min: 259:5 label: MSS EXtended
uuid: 20339e0b-8343-433e-9209-ac67e31d9d73
ID-1: swap-1 type: partition size: 12 GiB used: 1.2 MiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1 mapped: luks-swap label: SWAP
uuid: c8991364-85a7-4e6c-8380-49cd5bd7a873
ID-1: /dev/nvme1n1p2 maj-min: 259:6 size: 16 MiB fs: <superuser required>
ID-2: /dev/nvme1n1p3 maj-min: 259:7 size: 199.98 GiB fs: ntfs label: N/A
uuid: E658FD3258FD025B
ID-3: /dev/sdb1 maj-min: 8:17 size: 3.64 TiB fs: ntfs
label: JerichoVariance uuid: 1AB22D5664889CBD
ID-4: /dev/sdc1 maj-min: 8:33 size: 3.32 GiB fs: iso9660
ID-5: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
uuid: C80E-8B3F
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 1-2:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 045b:0209 class-ID: 0900
Device-1: 1-2.4:5 info: Microsoft Xbox One Controller (Firmware 2015)
type: <vendor specific> driver: xpad interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 045e:02dd class-ID: ff00 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-4: 2-2:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 045b:0210 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 3-1:2 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 2109:3431 class-ID: 0900
Hub-7: 3-1.2:3 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2813 class-ID: 0900
Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-9: 4-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2109:0813 class-ID: 0900
Hub-10: 5-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 5-1:9 info: Schiit Audio Unison Universal Dac type: Audio
driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 30be:1019 class-ID: 0102
Device-2: 5-2:3 info: JMTek LLC. Plugable USB Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0c76:120b class-ID: 0300
serial: <filter>
Device-3: 5-4:4 info: ASUSTek ASUS AI Noise-Cancelling Mic Adapter
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0b05:194e class-ID: 0300
serial: <filter>
Hub-11: 5-5:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 5-5.3:7 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Hub-12: 5-6:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-13: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-14: 7-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 7-4:2 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Hub-15: 8-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 8-1:2 info: ASolid USB_0114 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 144mA
chip-ID: 24a9:205a class-ID: 0806 serial: <filter>
Hub-16: 9-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-17: 9-1:2 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 1a40:0201 class-ID: 0900
Device-1: 9-1.1:11 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 98mA chip-ID: 1bcf:08a0 class-ID: 0301
Device-2: 9-1.5:5 info: Microdia Backlit Gaming Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 400mA chip-ID: 0c45:652f class-ID: 0301
Device-3: 9-1.6:6 info: HUION H420 type: Mouse,HID driver: uclogic,usbhid
interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 256c:006e
class-ID: 0300
Hub-18: 9-1.7:7 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 9-1.7.4:8 info: Texas Instruments TI-Nspire Calculator
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 0451:e012 class-ID: 0000
Device-2: 9-2:3 info: Microdia USB 2.0 Camera type: Video,Audio
power: 500mA chip-ID: 0c45:6367 class-ID: 0102 serial: <filter>
Hub-19: 10-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.0 C mobo: 42.0 C
Fan Speeds (RPM): fan-1: 874 fan-2: 785 fan-3: 1011 fan-4: 978 fan-5: 3139
fan-6: 0 fan-7: 0
GPU: device: nvidia screen: :0.0 temp: 56 C fan: 0% device: radeon
temp: 52.0 C
Processes: 885 Uptime: 2d 3h 7m wakeups: 0 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 alt: 10/11
clang: 14.0.6 Packages: 2159 pm: pacman pkgs: 2119 libs: 497 tools: pamac,yay
pm: flatpak pkgs: 23 pm: snap pkgs: 17 Shell: Bash v: 5.1.16
running-in: yakuake inxi: 3.3.24
