Libplist-2.0.so.3: cannot open shared object file
hi,
I cannot login after this update.
I am seeing a broken sddm screen with this warning:
The current theme cannot be loaded due to the errors below, please select another theme.
file://usr/share/sddm/themes/breath/Main.qml:26:1: plugin
cannot be loaded for module “org.kde.plasma.core”: Cannot load library /usr/lib/qt/qml/org/kde/plasma/core/libcorebindingsplugin.so: (libplist-2.0.so.3: cannot open shared object file: No such file or directory)
Make sure you have libplist 2.2.0-6 installed from the extra repo, not libplist-git or something from the AUR.
yes, the problem is exactly that. I think a pamac update command (libimobiledevice installation) is responsible. thank you.
