Hello there. Im quite new to the Linuxcommunity so i might require some extra patience.
(!)I´m running Dualboot with Manjaro KDE and Windows 10 - if thats of any importance.
Lets cut to the case:
I tried setting up a Steam Library Folder on my second drive via the Steam Storage Manager.
Simply selecting the second drive results in the error message “Failed to add library Steam folder”
However once i try to setup a custom directory via the Steam Storage Manager, i get restricted to only my system partition.
Ive manually mounted the drives before starting steam, plus i fondled under strict control of a more arch-experienced friend with the /etc/fstab in an attempt to automount the desired drive in an attempt to fix it.
/etc/fstab now looks like this:
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=5C18-8704 /boot/efi vfat umask=0077 0 2
UUID=1af2b394-f81a-4479-97e8-b7da21cc9ee6 / ext4 defaults,noatime 0 1
UUID=76A2-3078 /mnt/SSD exfat defaults,nofail,discard 0 0
I´am very thankfull for any suggestions on how to fix it.
Greetings,
cholarry
