Hello, I can’t use the buttons to shutdown and restart in the whisker menu after I suspended the machine one time. I have to use the command “shutdown now” to shutdown. The buttons appear but I can’t click on them.
I also can’t switch to the newest LTS kernel that I have installed for some reason. I’m using 6.6.90-1 and I want to use 6.12.28-1 and it doesn’t appear in the grub menu.
Kernel: 6.6.90-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=0b905aaa-f47a-433c-9c9b-036e6559c3b4 rw quiet apparmor=1
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: Gigabyte product: B550M K v: -CF
serial: <superuser required>
Mobo: Gigabyte model: B550M K v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F5
date: 03/22/2024
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
System RAM: total: 16 GiB available: 11.55 GiB used: 3.18 GiB (27.5%)
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: KF3200C16D4/8GX serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 5 5600GT with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
microcode: 0xA500011
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 400 min/max: 400/4668 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 86278
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
affected
Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1
empty: DP-1 bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 33.0 C
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: xfwm4 v: 4.20.0 driver: X: loaded: amdgpu
unloaded: modesetting,vesa alternate: fbdev dri: radeonsi gpu: amdgpu
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
s-diag: 584mm (22.99")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: IQ24H serial: <filter>
built: 2020 res: N/A dpi: 94 gamma: 1.2 chroma: red: x: 0.651 y: 0.337 green:
x: 0.282 y: 0.604 blue: x: 0.141 y: 0.071 white: x: 0.314 y: 0.329
size: 520x300mm (20.47x11.81") diag: 600mm (23.6") ratio: 16:9
modes: 1920x1080, 1600x1200, 1680x1050, 1600x900, 1280x1024, 1440x900,
1280x960, 1280x800, 1280x720, 1024x768, 800x600, 720x576, 720x480,
640x480, 720x400
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: gbm,wayland
API: OpenGL v: 4.6 vendor: amd mesa v: 25.2.0-devel glx-v: 1.4
direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir ACO DRM
3.54 6.6.90-1-MANJARO) device-ID: 1002:1638 memory: 3.91 GiB unified: no
API: Vulkan v: 1.4.313 layers: 6 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.0.5-arch1.1
device-ID: 1002:1638 surfaces: N/A
Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
x11: xdriinfo, xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6
chip-ID: 1022:15e3 class-ID: 0403
Device-3: Apple USB-C to 3.5mm Headphone Jack Adapter
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 05ac:110a class-ID: 0300
serial: <filter>
API: ALSA v: k6.6.90-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: br10 state: down mac: <filter>
IF-ID-2: virbr0 state: down mac: <filter>
Info: services: NetworkManager, nginx, systemd-timesyncd
Local Storage: total: 1.36 TiB used: 923.93 GiB (66.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S250G
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: ELFK0S.6 temp: 27.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: WDC WDS240G2G0A-00JH30
size: 223.58 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0000 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10SMZW-11Y0TS0 size: 931.48 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1021 scheme: GPT
Optical-1: /dev/sr0 vendor: ATAPI model: iHAS122 F rev: EL9M
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 50 GiB size: 48.16 GiB (96.33%) used: 43 GiB (89.3%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 0b905aaa-f47a-433c-9c9b-036e6559c3b4
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: AED9-11AC
ID-3: /mnt/Elements raw-size: 931.48 GiB size: 931.48 GiB (100.00%)
used: 789.12 GiB (84.7%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17 label: KAI
uuid: 32BE9B73BE9B2DFB
ID-4: /run/media/manjaro/40f6c76a-e547-41b1-b34b-2ea459c9eab4/Data
raw-size: 173.28 GiB size: 169.5 GiB (97.82%) used: 91.7 GiB (54.1%) fs: ext4
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 40f6c76a-e547-41b1-b34b-2ea459c9eab4
ID-5: /tmp/.mount_librewnBNJap raw-size: N/A size: 106.1 MiB
used: 106.1 MiB (100.0%) fs: fuse.librewolf.x86_64.appimage source: ERR-102
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 4473-8ED2
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 232.77 GiB fs: bitlocker
label: N/A uuid: 399c86f5-a210-4af8-907e-900277db7a25
Device-1: 1-2:2 info: Logitech Nano Receiver type: keyboard,mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c534 class-ID: 0301
Device-1: 3-1:2 info: Apple USB-C to 3.5mm Headphone Jack Adapter
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
chip-ID: 05ac:110a class-ID: 0300 serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-2:2 info: Holtek Gaming Mouse [Redragon M908]
type: mouse,keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 04d9:fc4d class-ID: 0300
Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Device-1: 6-1:2 info: Western Digital Elements 25A2 type: mass storage
driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 1058:25a2 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 42.6 C mobo: 28.0 C gpu: amdgpu temp: 33.0 C
Fan Speeds (rpm): N/A
Packages: 2298 pm: pacman pkgs: 2261 libs: 506 tools: pamac,yay pm: flatpak
pkgs: 21 pm: snap pkgs: 16
1: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
4: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
6: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
7: http://manjaro.mirror.ac.za/stable/$repo/$arch
8: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 326
1: cpu: 9.4% command: librewolf pid: 48623 mem: 518.0 MiB (4.3%)
2: cpu: 9.1% command: librewolf pid: 49002 mem: 361.8 MiB (3.0%)
3: cpu: 4.8% command: Xorg pid: 1526 mem: 136.1 MiB (1.1%)
4: cpu: 2.7% command: librewolf pid: 48920 mem: 344.1 MiB (2.9%)
5: cpu: 1.0% command: pipewire-pulse pid: 1776 mem: 13.8 MiB (0.1%)
Memory top: 5 of 326
1: mem: 518.0 MiB (4.3%) command: librewolf pid: 48623 cpu: 9.4%
2: mem: 361.8 MiB (3.0%) command: librewolf pid: 49002 cpu: 9.1%
3: mem: 344.1 MiB (2.9%) command: librewolf pid: 48920 cpu: 2.7%
4: mem: 244.5 MiB (2.0%) command: mariadbd pid: 1511 cpu: 0.0%
5: mem: 157.9 MiB (1.3%) command: manjaro-settings-manager pid: 49317
cpu: 0.2%
Processes: 326 Power: uptime: 2h 12m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 4.61 GiB services: upowerd,xfce4-power-manager
Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: Bash v: 5.2.37
running-in: xfce4-terminal inxi: 3.3.38
