Unable to update system: corrupted packages and missing/incomplete metadata
update
package
#1
Hi all,
I committed a grave sin and didn’t run pacman for a couple months. I’ve learned in my research into the problem that weekly updates (at least) are recommended. :persevere: Welp. I learned my lesson. Hopefully someone can help.
I followed the steps for dealing with invalid or corrupted packages. All of the commands completed except pacman -Syyu. I also tried the errors about keys, but the problem persists.
Here is the output of pacman -Syyu:
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
error: could not open file /var/lib/pacman/local/flatpak-1.1.0-1/desc: No such file or directory
warning: lib32-systemd: local (239.303-1) is newer than multilib (239.6-2)
warning: libsystemd: local (239.303-1) is newer than core (239.6-2)
warning: systemd: local (239.303-1) is newer than core (239.6-2)
warning: systemd-sysvcompat: local (239.303-1) is newer than core (239.6-2)
warning: zeitgeist: local (1.0+1+g1bcc8585-1) is newer than extra (1.0.1-1)
resolving dependencies...
warning: could not fully load metadata for package flatpak-1.1.0-1
error: failed to prepare transaction (invalid or corrupted package)
Thanks in advance!
#2
See reference from here:
So, you will have to:
sudo cp /var/lib/pacman/local/systemd-239.303-1/desc /var/lib/pacman/local/flatpak-1.1.0-1/desc
and then
sudo pacman -Syyuu
that will solve all the issues mentioned.
#3
Thanks for the speedy response!
sudo pacman -Syyuu
First command appears to work. Second command gives a similar error message, but now it looks like there are even more errors:
error: local database is inconsistent: name mismatch on package flatpak
error: local database is inconsistent: version mismatch on package flatpak
warning: lib32-systemd: downgrading from version 239.303-1 to version 239.6-2
warning: libsystemd: downgrading from version 239.303-1 to version 239.6-2
warning: systemd: downgrading from version 239.303-1 to version 239.6-2
warning: systemd-sysvcompat: downgrading from version 239.303-1 to version 239.6-2
warning: zeitgeist: downgrading from version 1.0+1+g1bcc8585-1 to version 1.0.1-1
error: could not open file /var/lib/pacman/local/flatpak-1.1.0-1/files: No such file or directory
Are there any steps missing? The thread you linked also mentions copying mtree files over.
#4
And now, following the same logic, as you can read:
So, while before the desc file was corrupted and we copy it from elsewhere, same with the files that is missing.
sudo cp /var/lib/pacman/local/systemd-239.303-1/files /var/lib/pacman/local/flatpak-1.1.0-1/files
then again
sudo pacman -Syyuu
#5
I copied the files, then ran the update.
After the upgrade Y/n prompt, it spits several screenfuls of <package>: <path-to-file> exists in the system.
error: failed to commit transaction (conflicting files)
pipewire: /etc/pipewire/pipewire.conf exists in filesystem
pipewire: /usr/bin/pipewire exists in filesystem
pipewire: /usr/bin/pipewire-cli exists in filesystem
flatpak: /usr/share/locale/sv/LC_MESSAGES/flatpak.mo exists in filesystem
flatpak: /usr/share/locale/tr/LC_MESSAGES/flatpak.mo exists in filesystem
flatpak: /usr/share/locale/uk/LC_MESSAGES/flatpak.mo exists in filesystem
flatpak: /usr/share/locale/zh_TW/LC_MESSAGES/flatpak.mo exists in filesystem
#6
Now try to:
sudo pacman -Suy --overwrite
If that fails, follow this tutorial
On future updates ALWAYS make sure that the mirrors you are using are updated, or switch to one that is fully updated
#7
--overwrite requires an argument
Do I run the command with every path in the error message as part of the glob it takes?
I followed the tutorial, but ran into similar issues. I tested pacman -Qo /path/to/file on a few of them and got No package owns /path/to/file.
The other command given is pacman -S $PACKAGE --overwrite path/to/*. How should I make the string at the end if there are so many ownerless files in different directories? Is it safe to put /* or at least /etc/*,/usr/*?
#8
Buddy …
is an example. in your case you have to replace it with the conflicting file:
pacman -Qo /usr/share/locale/sv/LC_MESSAGES/flatpak.mo
So, to fix it you have to run:
sudo pacman -S flatpack --overwrite usr/share/locale/sv/LC_MESSAGES/flatpak.mo
and do that for each file that already exists so you don’t overwrite something else and break the system.
Moved from #support-for-official-editions to #newbies for obvious reasons
#9
Sorry, I phrased myself badly. I mean I ran pacman -Qo for several filepaths in the list to test. What I’m stuck on is how to tell it to overwrite all of these files in different directories.
pipewire: /usr/bin/pipewire-monitor exists in filesystem
pipewire: /usr/bin/spa-inspect exists in filesystem
pipewire: /usr/bin/spa-monitor exists in filesystem
pipewire: /usr/include/pipewire/array.h exists in filesystem
pipewire: /usr/include/pipewire/client.h exists in filesystem
pipewire: /usr/include/pipewire/command.h exists in filesystem
pipewire: /usr/include/pipewire/control.h exists in filesystem
pipewire: /usr/include/pipewire/core.h exists in filesystem
pipewire: /usr/include/pipewire/data-loop.h exists in filesystem
pipewire: /usr/include/pipewire/extensions/client-node.h exists in filesystem
pipewire: /usr/include/pipewire/extensions/protocol-native.h exists in filesystem
pipewire: /usr/include/pipewire/factory.h exists in filesystem
pipewire: /usr/include/pipewire/global.h exists in filesystem
pipewire: /usr/include/pipewire/interfaces.h exists in filesystem
pipewire: /usr/include/pipewire/introspect.h exists in filesystem
pipewire: /usr/include/pipewire/link.h exists in filesystem
pipewire: /usr/include/pipewire/log.h exists in filesystem
pipewire: /usr/include/pipewire/loop.h exists in filesystem
pipewire: /usr/include/pipewire/main-loop.h exists in filesystem
pipewire: /usr/include/pipewire/map.h exists in filesystem
pipewire: /usr/include/pipewire/mem.h exists in filesystem
pipewire: /usr/include/pipewire/module.h exists in filesystem
pipewire: /usr/include/pipewire/node.h exists in filesystem
pipewire: /usr/include/pipewire/pipewire.h exists in filesystem
pipewire: /usr/include/pipewire/port.h exists in filesystem
pipewire: /usr/include/pipewire/properties.h exists in filesystem
pipewire: /usr/include/pipewire/protocol.h exists in filesystem
pipewire: /usr/include/pipewire/proxy.h exists in filesystem
pipewire: /usr/include/pipewire/remote.h exists in filesystem
pipewire: /usr/include/pipewire/resource.h exists in filesystem
pipewire: /usr/include/pipewire/stream.h exists in filesystem
pipewire: /usr/include/pipewire/thread-loop.h exists in filesystem
pipewire: /usr/include/pipewire/type.h exists in filesystem
pipewire: /usr/include/pipewire/utils.h exists in filesystem
pipewire: /usr/include/pipewire/version.h exists in filesystem
pipewire: /usr/include/pipewire/work-queue.h exists in filesystem
pipewire: /usr/include/spa/buffer/buffer.h exists in filesystem
pipewire: /usr/include/spa/buffer/meta.h exists in filesystem
pipewire: /usr/include/spa/clock/clock.h exists in filesystem
pipewire: /usr/include/spa/graph/graph.h exists in filesystem
pipewire: /usr/include/spa/monitor/monitor.h exists in filesystem
pipewire: /usr/include/spa/node/command.h exists in filesystem
pipewire: /usr/include/spa/node/event.h exists in filesystem
pipewire: /usr/include/spa/node/io.h exists in filesystem
pipewire: /usr/include/spa/node/node.h exists in filesystem
pipewire: /usr/include/spa/param/audio/format-utils.h exists in filesystem
pipewire: /usr/include/spa/param/audio/format.h exists in filesystem
pipewire: /usr/include/spa/param/audio/raw-utils.h exists in filesystem
pipewire: /usr/include/spa/param/audio/raw.h exists in filesystem
pipewire: /usr/include/spa/param/buffers.h exists in filesystem
pipewire: /usr/include/spa/param/format-utils.h exists in filesystem
pipewire: /usr/include/spa/param/format.h exists in filesystem
pipewire: /usr/include/spa/param/io.h exists in filesystem
pipewire: /usr/include/spa/param/meta.h exists in filesystem
pipewire: /usr/include/spa/param/param.h exists in filesystem
pipewire: /usr/include/spa/param/props.h exists in filesystem
pipewire: /usr/include/spa/param/video/chroma.h exists in filesystem
pipewire: /usr/include/spa/param/video/color.h exists in filesystem
pipewire: /usr/include/spa/param/video/encoded.h exists in filesystem
pipewire: /usr/include/spa/param/video/format-utils.h exists in filesystem
pipewire: /usr/include/spa/param/video/format.h exists in filesystem
pipewire: /usr/include/spa/param/video/multiview.h exists in filesystem
pipewire: /usr/include/spa/param/video/raw-utils.h exists in filesystem
pipewire: /usr/include/spa/param/video/raw.h exists in filesystem
pipewire: /usr/include/spa/pod/builder.h exists in filesystem
pipewire: /usr/include/spa/pod/command.h exists in filesystem
pipewire: /usr/include/spa/pod/event.h exists in filesystem
pipewire: /usr/include/spa/pod/iter.h exists in filesystem
pipewire: /usr/include/spa/pod/parser.h exists in filesystem
pipewire: /usr/include/spa/pod/pod.h exists in filesystem
pipewire: /usr/include/spa/support/log-impl.h exists in filesystem
pipewire: /usr/include/spa/support/log.h exists in filesystem
pipewire: /usr/include/spa/support/loop.h exists in filesystem
pipewire: /usr/include/spa/support/plugin.h exists in filesystem
pipewire: /usr/include/spa/support/type-map-impl.h exists in filesystem
pipewire: /usr/include/spa/support/type-map.h exists in filesystem
pipewire: /usr/include/spa/utils/defs.h exists in filesystem
pipewire: /usr/include/spa/utils/dict.h exists in filesystem
pipewire: /usr/include/spa/utils/hook.h exists in filesystem
pipewire: /usr/include/spa/utils/list.h exists in filesystem
pipewire: /usr/include/spa/utils/ringbuffer.h exists in filesystem
pipewire: /usr/include/spa/utils/type.h exists in filesystem
pipewire: /usr/lib/gstreamer-1.0/libgstpipewire.so exists in filesystem
pipewire: /usr/lib/libpipewire-0.2.so exists in filesystem
pipewire: /usr/lib/libpipewire-0.2.so.1 exists in filesystem
pipewire: /usr/lib/pipewire-0.2/libpipewire-module-audio-dsp.so exists in filesystem
pipewire: /usr/lib/pipewire-0.2/libpipewire-module-autolink.so exists in filesystem
pipewire: /usr/lib/pipewire-0.2/libpipewire-module-client-node.so exists in filesystem
pipewire: /usr/lib/pipewire-0.2/libpipewire-module-flatpak.so exists in filesystem
pipewire: /usr/lib/pipewire-0.2/libpipewire-module-link-factory.so exists in filesystem
pipewire: /usr/lib/pipewire-0.2/libpipewire-module-mixer.so exists in filesystem
pipewire: /usr/lib/pipewire-0.2/libpipewire-module-protocol-native.so exists in filesystem
pipewire: /usr/lib/pipewire-0.2/libpipewire-module-rtkit.so exists in filesystem
pipewire: /usr/lib/pipewire-0.2/libpipewire-module-spa-monitor.so exists in filesystem
pipewire: /usr/lib/pipewire-0.2/libpipewire-module-spa-node-factory.so exists in filesystem
pipewire: /usr/lib/pipewire-0.2/libpipewire-module-spa-node.so exists in filesystem
pipewire: /usr/lib/pipewire-0.2/libpipewire-module-suspend-on-idle.so exists in filesystem
pipewire: /usr/lib/pkgconfig/libpipewire-0.2.pc exists in filesystem
pipewire: /usr/lib/pkgconfig/libspa-0.1.pc exists in filesystem
pipewire: /usr/lib/spa/alsa/libspa-alsa.so exists in filesystem
pipewire: /usr/lib/spa/audiomixer/libspa-audiomixer.so exists in filesystem
pipewire: /usr/lib/spa/audiotestsrc/libspa-audiotestsrc.so exists in filesystem
pipewire: /usr/lib/spa/bluez5/libspa-bluez5.so exists in filesystem
pipewire: /usr/lib/spa/ffmpeg/libspa-ffmpeg.so exists in filesystem
pipewire: /usr/lib/spa/support/libspa-dbus.so exists in filesystem
pipewire: /usr/lib/spa/support/libspa-support.so exists in filesystem
pipewire: /usr/lib/spa/test/libspa-test.so exists in filesystem
pipewire: /usr/lib/spa/v4l2/libspa-v4l2.so exists in filesystem
pipewire: /usr/lib/spa/videotestsrc/libspa-videotestsrc.so exists in filesystem
pipewire: /usr/lib/spa/volume/libspa-volume.so exists in filesystem
pipewire: /usr/lib/systemd/user/pipewire.service exists in filesystem
pipewire: /usr/lib/systemd/user/pipewire.socket exists in filesystem
pipewire: /usr/share/doc/pipewire/html/annotated.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/annotated_dup.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/array_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/array_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/array_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/array_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/array_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/array_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/array_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/array_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/array_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/array_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/bc_s.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/bdwn.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classes.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__client.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__client.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__command.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__command.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__control.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__core.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__core.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__data__loop.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__data__loop.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__factory.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__global.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__global.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__introspect.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__introspect.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__link.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__link.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__log.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__log.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__main__loop.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__main__loop.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__module.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__module.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__node.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__node.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__pipewire.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__pipewire.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__port.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__protocol.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__proxy.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__proxy.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__remote.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__remote.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__resource.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__stream.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__stream.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__thread__loop.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__thread__loop.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__utils.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__utils.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__work__queue.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/classpw__work__queue.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/client_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/client_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/client_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/client_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/client_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/client_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/client_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/client_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/client_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/client_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/client_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/client_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/client_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/client_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/client_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/client_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/client_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/closed.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/command_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/command_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/command_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/command_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/command_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/command_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/command_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/command_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/command_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/command_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/command_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/command_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/command_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/command_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/command_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/control_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/control_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/control_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/control_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/control_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/control_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/control_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/control_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/control_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/control_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/control_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/control_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/control_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/control_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/control_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/control_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/core_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/core_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/core_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/core_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/core_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/core_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/core_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/core_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/core_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/core_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/core_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/core_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/core_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/core_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/core_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/core_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/core_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/data-loop_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/data-loop_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/data-loop_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/data-loop_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/data-loop_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/data-loop_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/data-loop_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/data-loop_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/data-loop_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/data-loop_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/data-loop_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/data-loop_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/data-loop_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/data-loop_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/data-loop_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/dir_36c7502ebc2113ff06adcb60b2e38fc6.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/dir_3849c0dd7adf354181350d58c0278e16.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/dir_5ddfbdef6960356fef29933c5370cf28.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/doc.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/doxygen.css exists in filesystem
pipewire: /usr/share/doc/pipewire/html/doxygen.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/dynsections.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/factory_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/factory_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/factory_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/factory_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/factory_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/factory_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/factory_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/factory_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/factory_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/factory_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/factory_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/factory_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/factory_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/factory_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/factory_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/factory_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/factory_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/files.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/files_dup.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/folderclosed.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/folderopen.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_b.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_d.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_dup.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_e.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_enum.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_f.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_func.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_g.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_i.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_l.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_m.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_n.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_o.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_p.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_q.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_r.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_rela.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_s.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_t.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_type.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_u.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_v.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_b.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_d.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_e.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_f.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_g.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_i.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_l.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_m.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_n.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_o.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_p.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_q.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_r.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_s.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_t.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_u.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_vars_v.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/functions_w.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/global_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/global_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/global_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/global_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/global_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/global_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/global_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/global_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/global_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/global_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/global_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/global_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/global_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/global_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/global_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/global_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/global_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_a.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_d.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_defs.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_defs.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_defs_a.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_defs_c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_defs_d.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_defs_f.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_defs_l.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_defs_m.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_defs_n.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_defs_p.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_defs_r.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_defs_s.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_defs_t.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_defs_u.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_defs_v.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_dup.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_enum.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_eval.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_f.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_func.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_func.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_func_d.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_func_f.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_func_g.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_func_i.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_func_l.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_func_m.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_func_n.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_func_p.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_func_r.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_func_s.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_func_t.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_func_w.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_g.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_i.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_l.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_m.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_n.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_p.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_r.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_s.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_t.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_type.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_u.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_v.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_vars.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/globals_w.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/graph_legend.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/graph_legend.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/graph_legend.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/index.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/interfaces_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/interfaces_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/interfaces_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/interfaces_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/interfaces_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/interfaces_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/interfaces_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/interfaces_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/interfaces_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/interfaces_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/interfaces_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/introspect_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/introspect_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/introspect_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/introspect_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/introspect_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/introspect_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/introspect_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/introspect_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/introspect_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/introspect_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/introspect_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/introspect_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/introspect_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/introspect_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/introspect_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/introspect_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/jquery.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/link_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/link_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/link_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/link_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/link_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/link_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/link_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/link_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/link_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/link_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/link_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/link_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/link_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/link_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/link_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/link_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/link_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/log_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/log_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/log_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/log_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/log_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/log_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/log_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/log_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/log_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/log_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/log_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/log_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/log_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/log_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/log_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/loop_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/loop_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/loop_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/loop_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/loop_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/loop_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/loop_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/loop_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/loop_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/loop_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/loop_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/loop_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/loop_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/loop_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/loop_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/loop_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/main-loop_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/main-loop_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/main-loop_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/main-loop_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/main-loop_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/main-loop_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/main-loop_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/main-loop_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/main-loop_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/main-loop_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/main-loop_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/main-loop_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/main-loop_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/main-loop_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/main-loop_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/map_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/map_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/map_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/map_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/map_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/map_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/map_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/map_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/map_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/map_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/mem_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/mem_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/mem_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/mem_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/mem_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/mem_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/mem_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/mem_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/mem_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/mem_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/mem_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/mem_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/mem_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/mem_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/mem_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/menu.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/menudata.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/module_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/module_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/module_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/module_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/module_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/module_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/module_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/module_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/module_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/module_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/module_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/module_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/module_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/module_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/module_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/module_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/module_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/nav_f.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/nav_g.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/nav_h.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/navtree.css exists in filesystem
pipewire: /usr/share/doc/pipewire/html/navtree.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/navtreedata.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/navtreeindex0.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/navtreeindex1.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/navtreeindex2.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/navtreeindex3.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/navtreeindex4.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/navtreeindex5.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/node_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/node_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/node_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/node_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/node_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/node_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/node_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/node_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/node_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/node_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/node_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/node_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/node_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/node_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/node_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/node_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/node_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/open.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_client.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_control.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_core.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_core_api.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_core_api.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_global.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_iface_pw_core.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_link.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_node.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_pipewire_protocol.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_pipewire_protocol.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_port.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_proxy.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_registry.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_remote_api.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_remote_api.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_resource.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_streams.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/page_thread_loop.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pages.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pipewire_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pipewire_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pipewire_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pipewire_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pipewire_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pipewire_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pipewire_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pipewire_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pipewire_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pipewire_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pipewire_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pipewire_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pipewire_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pipewire_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pipewire_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pipewire_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/pipewire_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/port_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/port_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/port_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/port_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/port_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/port_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/port_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/port_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/port_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/port_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/port_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/port_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/port_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/port_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/port_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/port_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/port_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/properties_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/properties_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/properties_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/properties_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/properties_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/properties_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/properties_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/properties_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/properties_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/properties_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/properties_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/properties_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/properties_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/properties_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/properties_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/properties_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/protocol_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/protocol_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/protocol_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/protocol_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/protocol_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/protocol_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/protocol_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/protocol_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/protocol_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/protocol_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/protocol_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/protocol_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/protocol_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/protocol_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/protocol_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/protocol_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/protocol_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/proxy_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/proxy_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/proxy_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/proxy_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/proxy_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/proxy_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/proxy_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/proxy_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/proxy_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/proxy_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/proxy_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/proxy_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/proxy_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/proxy_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/proxy_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/proxy_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/proxy_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/remote_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/remote_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/remote_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/remote_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/remote_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/remote_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/remote_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/remote_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/remote_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/remote_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/remote_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/remote_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/remote_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/remote_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/remote_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/remote_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/remote_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resize.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resource_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resource_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resource_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resource_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resource_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resource_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resource_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resource_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resource_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resource_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resource_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resource_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resource_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resource_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resource_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resource_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/resource_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/splitbar.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/stream_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/stream_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/stream_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/stream_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/stream_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/stream_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/stream_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/stream_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/stream_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/stream_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/stream_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/stream_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/stream_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/stream_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/stream_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/stream_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/stream_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structimpl.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structimpl.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structimpl__coll__graph.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structimpl__coll__graph.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structimpl__coll__graph.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structinterface.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structinterface.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structmemblock.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structmemblock.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structmemblock__coll__graph.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structmemblock__coll__graph.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structmemblock__coll__graph.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structparam__filter.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structparam__filter.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structparam__filter__coll__graph.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structparam__filter__coll__graph.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structparam__filter__coll__graph.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpermission.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpermission.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpermissions__update.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpermissions__update.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpermissions__update__coll__graph.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpermissions__update__coll__graph.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpermissions__update__coll__graph.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__array.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__array.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__buffer.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__buffer.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__client__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__client__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__client__info.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__client__info.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__client__proxy__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__client__proxy__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__control__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__control__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__core__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__core__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__core__info.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__core__info.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__core__proxy__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__core__proxy__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__core__proxy__methods.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__core__proxy__methods.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__data__loop__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__data__loop__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__factory__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__factory__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__factory__implementation.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__factory__implementation.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__factory__info.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__factory__info.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__factory__proxy__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__factory__proxy__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__global__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__global__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__link__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__link__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__link__info.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__link__info.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__link__proxy__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__link__proxy__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__loop.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__loop.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__main__loop__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__main__loop__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__map.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__map.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__map__coll__graph.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__map__coll__graph.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__map__coll__graph.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__map__range.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__map__range.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__memblock.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__memblock.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__module__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__module__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__module__info.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__module__info.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__module__proxy__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__module__proxy__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__node__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__node__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__node__info.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__node__info.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__node__proxy__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__node__proxy__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__node__proxy__methods.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__node__proxy__methods.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__port__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__port__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__port__info.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__port__info.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__port__proxy__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__port__proxy__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__port__proxy__methods.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__port__proxy__methods.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__properties.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__properties.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__client.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__client.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__client__coll__graph.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__client__coll__graph.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__client__coll__graph.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__implementaton.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__implementaton.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__implementaton__coll__graph.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__implementaton__coll__graph.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__implementaton__coll__graph.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__marshal.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__marshal.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__server.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__server.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__server__coll__graph.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__server__coll__graph.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__protocol__server__coll__graph.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__proxy__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__proxy__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__registry__proxy__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__registry__proxy__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__registry__proxy__methods.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__registry__proxy__methods.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__remote__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__remote__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__resource__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__resource__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__stream__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__stream__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__thread__loop__events.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__thread__loop__events.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__time.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__time.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__type.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structpw__type.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structregistry.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structregistry.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structresource__data.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/structresource__data.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/svgpan.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/sync_off.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/sync_on.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/tab_a.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/tab_b.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/tab_h.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/tab_s.png exists in filesystem
pipewire: /usr/share/doc/pipewire/html/tabs.css exists in filesystem
pipewire: /usr/share/doc/pipewire/html/thread-loop_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/thread-loop_8c.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/thread-loop_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/thread-loop_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/thread-loop_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/thread-loop_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/thread-loop_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/thread-loop_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/thread-loop_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/thread-loop_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/thread-loop_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/thread-loop_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/thread-loop_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/thread-loop_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/thread-loop_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/thread-loop_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/type_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/type_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/type_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/type_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/type_8c__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/type_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/type_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/type_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/type_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/type_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/type_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/type_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/type_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/type_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/type_8h__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/type_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/unionpw__map__item.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/unionpw__map__item.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/utils_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/utils_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/utils_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/utils_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/utils_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/utils_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/utils_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/utils_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/utils_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/utils_8h__dep__incl_org.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/utils_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/utils_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/utils_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/utils_8h_source.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/work-queue_8c.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/work-queue_8c__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/work-queue_8c__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/work-queue_8c__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/work-queue_8h.html exists in filesystem
pipewire: /usr/share/doc/pipewire/html/work-queue_8h.js exists in filesystem
pipewire: /usr/share/doc/pipewire/html/work-queue_8h__dep__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/work-queue_8h__dep__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/work-queue_8h__dep__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/work-queue_8h__incl.map exists in filesystem
pipewire: /usr/share/doc/pipewire/html/work-queue_8h__incl.md5 exists in filesystem
pipewire: /usr/share/doc/pipewire/html/work-queue_8h__incl.svg exists in filesystem
pipewire: /usr/share/doc/pipewire/html/work-queue_8h_source.html exists in filesystem
pipewire: /usr/share/man/man1/pipewire-cli.1.gz exists in filesystem
pipewire: /usr/share/man/man1/pipewire-monitor.1.gz exists in filesystem
pipewire: /usr/share/man/man1/pipewire.1.gz exists in filesystem
pipewire: /usr/share/man/man5/pipewire.conf.5.gz exists in filesystem
flatpak: /etc/profile.d/flatpak-bindir.sh exists in filesystem
flatpak: /etc/profile.d/flatpak.sh exists in filesystem
flatpak: /usr/bin/flatpak exists in filesystem
flatpak: /usr/bin/flatpak-bisect exists in filesystem
flatpak: /usr/bin/flatpak-coredumpctl exists in filesystem
flatpak: /usr/include/flatpak/flatpak-bundle-ref.h exists in filesystem
flatpak: /usr/include/flatpak/flatpak-enum-types.h exists in filesystem
flatpak: /usr/include/flatpak/flatpak-error.h exists in filesystem
flatpak: /usr/include/flatpak/flatpak-installation.h exists in filesystem
flatpak: /usr/include/flatpak/flatpak-installed-ref.h exists in filesystem
flatpak: /usr/include/flatpak/flatpak-instance.h exists in filesystem
flatpak: /usr/include/flatpak/flatpak-portal-error.h exists in filesystem
flatpak: /usr/include/flatpak/flatpak-ref.h exists in filesystem
flatpak: /usr/include/flatpak/flatpak-related-ref.h exists in filesystem
flatpak: /usr/include/flatpak/flatpak-remote-ref.h exists in filesystem
flatpak: /usr/include/flatpak/flatpak-remote.h exists in filesystem
flatpak: /usr/include/flatpak/flatpak-transaction.h exists in filesystem
flatpak: /usr/include/flatpak/flatpak-version-macros.h exists in filesystem
flatpak: /usr/include/flatpak/flatpak.h exists in filesystem
flatpak: /usr/lib/flatpak-portal exists in filesystem
flatpak: /usr/lib/flatpak-session-helper exists in filesystem
flatpak: /usr/lib/flatpak-system-helper exists in filesystem
flatpak: /usr/lib/girepository-1.0/Flatpak-1.0.typelib exists in filesystem
flatpak: /usr/lib/libflatpak.so exists in filesystem
flatpak: /usr/lib/libflatpak.so.0 exists in filesystem
flatpak: /usr/lib/pkgconfig/flatpak.pc exists in filesystem
flatpak: /usr/lib/systemd/system/flatpak-system-helper.service exists in filesystem
flatpak: /usr/lib/systemd/user/dbus.service.d/flatpak.conf exists in filesystem
flatpak: /usr/lib/systemd/user/flatpak-portal.service exists in filesystem
flatpak: /usr/lib/systemd/user/flatpak-session-helper.service exists in filesystem
flatpak: /usr/share/bash-completion/completions/flatpak exists in filesystem
flatpak: /usr/share/dbus-1/interfaces/org.freedesktop.Flatpak.xml exists in filesystem
flatpak: /usr/share/dbus-1/interfaces/org.freedesktop.portal.Flatpak.xml exists in filesystem
flatpak: /usr/share/dbus-1/services/org.freedesktop.Flatpak.service exists in filesystem
flatpak: /usr/share/dbus-1/services/org.freedesktop.portal.Flatpak.service exists in filesystem
flatpak: /usr/share/dbus-1/system-services/org.freedesktop.Flatpak.SystemHelper.service exists in filesystem
flatpak: /usr/share/dbus-1/system.d/org.freedesktop.Flatpak.SystemHelper.conf exists in filesystem
flatpak: /usr/share/doc/flatpak/docbook.css exists in filesystem
flatpak: /usr/share/doc/flatpak/flatpak-docs.html exists in filesystem
flatpak: /usr/share/flatpak/flathub.flatpakrepo exists in filesystem
flatpak: /usr/share/flatpak/triggers/desktop-database.trigger exists in filesystem
flatpak: /usr/share/flatpak/triggers/gtk-icon-cache.trigger exists in filesystem
flatpak: /usr/share/flatpak/triggers/mime-database.trigger exists in filesystem
flatpak: /usr/share/gdm/env.d/flatpak.env exists in filesystem
flatpak: /usr/share/gir-1.0/Flatpak-1.0.gir exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/FlatpakBundleRef.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/FlatpakInstallation.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/FlatpakInstalledRef.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/FlatpakInstance.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/FlatpakRef.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/FlatpakRelatedRef.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/FlatpakRemote.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/FlatpakRemoteRef.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/FlatpakTransaction.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/FlatpakTransactionOperation.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/FlatpakTransactionProgress.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/annotation-glossary.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/ch01.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/flatpak-Error-codes.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/flatpak-Version-information.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/flatpak.devhelp2 exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/full-api-index.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/home.png exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/index.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/left-insensitive.png exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/left.png exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/object-tree.html exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/right-insensitive.png exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/right.png exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/style.css exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/up-insensitive.png exists in filesystem
flatpak: /usr/share/gtk-doc/html/flatpak/up.png exists in filesystem
flatpak: /usr/share/locale/cs/LC_MESSAGES/flatpak.mo exists in filesystem
flatpak: /usr/share/locale/de/LC_MESSAGES/flatpak.mo exists in filesystem
flatpak: /usr/share/locale/es/LC_MESSAGES/flatpak.mo exists in filesystem
flatpak: /usr/share/locale/gl/LC_MESSAGES/flatpak.mo exists in filesystem
flatpak: /usr/share/locale/hu/LC_MESSAGES/flatpak.mo exists in filesystem
flatpak: /usr/share/locale/id/LC_MESSAGES/flatpak.mo exists in filesystem
flatpak: /usr/share/locale/pl/LC_MESSAGES/flatpak.mo exists in filesystem
flatpak: /usr/share/locale/pt_BR/LC_MESSAGES/flatpak.mo exists in filesystem
flatpak: /usr/share/locale/ru/LC_MESSAGES/flatpak.mo exists in filesystem
flatpak: /usr/share/locale/sk/LC_MESSAGES/flatpak.mo exists in filesystem
flatpak: /usr/share/locale/sv/LC_MESSAGES/flatpak.mo exists in filesystem
flatpak: /usr/share/locale/tr/LC_MESSAGES/flatpak.mo exists in filesystem
flatpak: /usr/share/locale/uk/LC_MESSAGES/flatpak.mo exists in filesystem
flatpak: /usr/share/locale/zh_TW/LC_MESSAGES/flatpak.mo exists in filesystem
That’s why I asked whether it’s safe to use /* or /etc/*,/usr/* as the argument for pacman -S flatpak --overwrite. I’m not sure how to construct the command, because it seems like I need to overwrite all of the files for flatpak in one go, and all of the files for pipewire in another.
I may be a newbie, but I’m not so new I’d actually blindly copy /path/to/example! :rofl:
I appreciate your patience!
#10
Try this way:
but also read the next comments … :slight_smile:
I honestly don’t want your system to break … i never experienced such issue on any of my installs, so, recommending to use /* or /etc/*,/usr/* as the argument is not safe for me …
#11
No; you don’t include the leading /.
For example,
sudo pacman -S pipewire --overwrite etc/pipewire/* usr/bin/* usr/include/pipewire/*
#12
Thanks for clarifying this. Now i see also my error (that i will correct now) and why the OP became confused … Much obliged!!!
