I’m trying to remove my 5.10 kernel, which I no longer boot into, since 5.15 is installed and running great.
When I try to do it from the Manjaro kernels handling GUI, it reaches 100% and says “Changes were made successfully”, but the kernel is still there, and the aforementioned tool itself shows it as still installed.
I clicked on “show details”, which reveals an unreported (in the regular view) error:
:: removing linux510 breaks dependency 'linux510' required by linux-latest
Why is linux-latest pointing to 5.10 instead of 5.15? How do I fix it? Should I uninstall linux-latest?
Also, where do I report the bug where there’s an error, but the GUI shows it all worked without a hitch?
Ensure you have a recent kernel installed - using mhwd to install the kernel will install required packages e.g. nvidia and headers if present on your system.
sudo mhwd-kernel -i linux515
linux-latest is a deprecated package and you should remove it.
No - it is long time since the packages linux-latest and linux-lts was dropped. The idea was good - it just turned out to be a pain to maintain.
The removal of the kernel was a success - so there’s no error to report. Only the meta-package was not because it is no longer considered installed and thus not a concern for the settings app.
The kernel was only removed after uninstalling linux-latest manually… It was reporting a successful removal before that, even though it did nothing.
And I would expect the package manager to be aware of deprecated packages and automatically remove them if it doesn’t create conflicts - and output a warning if it does, so the situation can be resolved. Silently keeping deprecated packages which depend on other packages and prevent their removal sounds like a bug to me.
Reporting something has successfully happened, when doing nothing at all, and requiring an explicit removal of a deprecated package (only discoverable if one clicks on “Show Details”, where it doesn’t even mention this package is deprecated) is a subpar user experience.
