previuosly I was a windows user then I often used to sleep or hibernate my laptop but when I started using manjaro suspend and hibernation no longer works.I want your help regarding this issue.
Hello and welcome,
In order to know what we are talking about, we need some information. Here is a tutorial for you to follow to know how to provide it.
You can either update your OP, or provide that information as another comment. After that someone might be able to guide you.
Kernel: 5.6.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.6-x86_64
root=UUID=82ee26ac-c6d3-4c36-8763-4b279fe5ac2e rw quiet apparmor=1
security=apparmor resume=UUID=82cf7862-bc70-47ec-94c2-83a933292a96
udev.log_priority=3
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Laptop System: Hewlett-Packard product: HP Pavilion dv6 Notebook PC
v: F.02 serial: <filter> Chassis: Quanta type: 10 serial: <filter>
Mobo: Quanta model: 3627 v: 18.0B serial: <filter> BIOS: Hewlett-Packard
v: F.02 date: 11/14/2008
ID-1: BAT0 charge: 23.5 Wh condition: 30.8/47.5 Wh (65%) volts: 12.1/10.8
model: Hewlett-Packard Primary type: NiMH serial: N/A status: Charging
Topology: Dual Core model: Intel Core2 Duo T6400 bits: 64 type: MCP
arch: Penryn family: 6 model-id: 17 (23) stepping: A (10) microcode: A0B
L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 bogomips: 7985
Speed: 1197 MHz min/max: 1200/2000 MHz Core speeds (MHz): 1: 1247 2: 1210
Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:2a42
Device-2: Chicony CNF8010 type: USB driver: uvcvideo bus ID: 2-4:2
chip ID: 04f2:b087 serial: <filter>
Display: x11 server: X.org 1.20.8 compositor: gnome-shell driver: intel
unloaded: modesetting alternate: fbdev,vesa resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa DRI Mobile Intel GM45 Express (CTG)
v: 2.1 Mesa 20.1.7 direct render: Yes
Device-1: Intel 82801I HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:293e
Sound Server: ALSA v: k5.6.15-1-MANJARO
Device-1: Broadcom and subsidiaries BCM4312 802.11b/g LP-PHY
vendor: Hewlett-Packard driver: wl v: kernel modules: ssb port: 7000
bus ID: 02:00.0 chip ID: 14e4:4315
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 5000 bus ID: 03:00.0 chip ID: 10ec:8136
Local Storage: total: 232.89 GiB used: 9.34 GiB (4.0%)
ID-1: /dev/sda vendor: Toshiba model: MK2555GSX size: 232.89 GiB block size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm
serial: <filter> rev: 2C scheme: MBR
ID-1: / raw size: 224.57 GiB size: 220.05 GiB (97.98%) used: 9.34 GiB (4.2%)
fs: ext4 dev: /dev/sda1
ID-1: swap-1 type: partition size: 8.31 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2
System Temperatures: cpu: 60.0 C mobo: N/A
Processes: 221 Uptime: 2h 09m Memory: 3.78 GiB used: 1.10 GiB (29.2%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1185 lib: 336
flatpak: 0 Shell: Bash v: 5.0.18 running in: gnome-terminal inxi: 3.1.05
[alnayeef@alif-hppaviliondv6notebookpc ~]$ sudo dmesg | grep usb
[sudo] password for alnayeef:
[ 0.640291] usbcore: registered new interface driver usbfs
[ 0.640291] usbcore: registered new interface driver hub
[ 0.640291] usbcore: registered new device driver usb
[ 0.925286] usbcore: registered new interface driver usbserial_generic
[ 0.925293] usbserial: USB Serial support registered for generic
[ 1.860197] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.06
[ 1.860200] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.860202] usb usb1: Product: EHCI Host Controller
[ 1.860204] usb usb1: Manufacturer: Linux 5.6.15-1-MANJARO ehci_hcd
[ 1.860205] usb usb1: SerialNumber: 0000:00:1a.7
[ 1.911427] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.06
[ 1.911437] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.911439] usb usb2: Product: EHCI Host Controller
[ 1.911441] usb usb2: Manufacturer: Linux 5.6.15-1-MANJARO ehci_hcd
[ 1.911443] usb usb2: SerialNumber: 0000:00:1d.7
[ 1.916083] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.06
[ 1.916085] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.916087] usb usb3: Product: UHCI Host Controller
[ 1.916089] usb usb3: Manufacturer: Linux 5.6.15-1-MANJARO uhci_hcd
[ 1.916091] usb usb3: SerialNumber: 0000:00:1a.0
[ 1.917757] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.06
[ 1.917759] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.917761] usb usb4: Product: UHCI Host Controller
[ 1.917763] usb usb4: Manufacturer: Linux 5.6.15-1-MANJARO uhci_hcd
[ 1.917765] usb usb4: SerialNumber: 0000:00:1a.1
[ 1.919421] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.06
[ 1.919423] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.919425] usb usb5: Product: UHCI Host Controller
[ 1.919427] usb usb5: Manufacturer: Linux 5.6.15-1-MANJARO uhci_hcd
[ 1.919429] usb usb5: SerialNumber: 0000:00:1d.0
[ 1.921010] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.06
[ 1.921012] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.921014] usb usb6: Product: UHCI Host Controller
[ 1.921016] usb usb6: Manufacturer: Linux 5.6.15-1-MANJARO uhci_hcd
[ 1.921018] usb usb6: SerialNumber: 0000:00:1d.1
[ 1.923150] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.06
[ 1.923153] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.923155] usb usb7: Product: UHCI Host Controller
[ 1.923156] usb usb7: Manufacturer: Linux 5.6.15-1-MANJARO uhci_hcd
[ 1.923158] usb usb7: SerialNumber: 0000:00:1d.2
[ 1.924657] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.06
[ 1.924659] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.924661] usb usb8: Product: UHCI Host Controller
[ 1.924663] usb usb8: Manufacturer: Linux 5.6.15-1-MANJARO uhci_hcd
[ 1.924665] usb usb8: SerialNumber: 0000:00:1d.3
[ 2.187872] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 2.241280] usb 2-4: new high-speed USB device number 2 using ehci-pci
[ 2.345586] usb 1-1: New USB device found, idVendor=0bda, idProduct=0158, bcdDevice=58.87
[ 2.345591] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.345594] usb 1-1: Product: USB2.0-CRW
[ 2.345597] usb 1-1: Manufacturer: Generic
[ 2.345600] usb 1-1: SerialNumber: 20071114173400000
[ 2.355198] usbcore: registered new interface driver usb-storage
[ 2.361140] usbcore: registered new interface driver uas
[ 2.369165] scsi host6: usb-storage 1-1:1.0
[ 2.369359] usbcore: registered new interface driver ums-realtek
[ 2.425058] usb 2-4: New USB device found, idVendor=04f2, idProduct=b087, bcdDevice=67.80
[ 2.425063] usb 2-4: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[ 2.425066] usb 2-4: Product: CNF8010
[ 2.425070] usb 2-4: Manufacturer: Chicony Electronics Co., Ltd.
[ 2.425073] usb 2-4: SerialNumber: SN0001
[ 2.671252] usb 4-2: new full-speed USB device number 2 using uhci_hcd
[ 2.843278] usb 4-2: New USB device found, idVendor=25a7, idProduct=fa23, bcdDevice= 2.41
[ 2.843283] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.843287] usb 4-2: Product: 2.4G Receiver
[ 2.843290] usb 4-2: Manufacturer: Compx
[ 18.931056] usbcore: registered new interface driver usbhid
[ 18.931059] usbhid: USB HID core driver
[ 18.980778] input: Compx 2.4G Receiver as /devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.0/0003:25A7:FA23.0001/input/input16
[ 19.035473] hid-generic 0003:25A7:FA23.0001: input,hidraw0: USB HID v1.10 Keyboard [Compx 2.4G Receiver] on usb-0000:00:1a.1-2/input0
[ 19.036849] input: Compx 2.4G Receiver Mouse as /devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.1/0003:25A7:FA23.0002/input/input17
[ 19.037533] input: Compx 2.4G Receiver as /devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.1/0003:25A7:FA23.0002/input/input18
[ 19.037640] input: Compx 2.4G Receiver Consumer Control as /devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.1/0003:25A7:FA23.0002/input/input19
[ 19.091480] input: Compx 2.4G Receiver System Control as /devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.1/0003:25A7:FA23.0002/input/input20
[ 19.091763] hid-generic 0003:25A7:FA23.0002: input,hiddev0,hidraw1: USB HID v1.10 Mouse [Compx 2.4G Receiver] on usb-0000:00:1a.1-2/input1
[ 19.131769] input: CNF8010: HP Webcam as /devices/pci0000:00/0000:00:1d.7/usb2/2-4/2-4:1.0/input/input22
[ 19.131885] usbcore: registered new interface driver uvcvideo
[ 2921.730076] usb usb5: root hub lost power or was reset
[ 2921.730091] usb usb6: root hub lost power or was reset
[ 2921.730151] usb usb7: root hub lost power or was reset
[ 2921.730211] usb usb8: root hub lost power or was reset
[ 2921.730850] usb usb4: root hub lost power or was reset
[ 2921.730955] usb usb3: root hub lost power or was reset
[ 2922.080957] usb 4-2: reset full-speed USB device number 2 using uhci_hcd
[ 2924.711449] usb usb3: root hub lost power or was reset
[ 2924.711635] usb usb4: root hub lost power or was reset
[ 2924.711995] usb usb5: root hub lost power or was reset
[ 2924.712037] usb usb6: root hub lost power or was reset
[ 2924.712080] usb usb7: root hub lost power or was reset
[ 2924.712122] usb usb8: root hub lost power or was reset
[ 2925.060941] usb 4-2: reset full-speed USB device number 2 using uhci_hcd
[ 4642.661865] usb usb3: root hub lost power or was reset
[ 4642.662051] usb usb4: root hub lost power or was reset
[ 4642.662412] usb usb5: root hub lost power or was reset
[ 4642.662455] usb usb6: root hub lost power or was reset
[ 4642.662498] usb usb7: root hub lost power or was reset
[ 4642.662539] usb usb8: root hub lost power or was reset
[ 4643.010760] usb 4-2: reset full-speed USB device number 2 using uhci_hcd
[ 4645.466809] usb usb3: root hub lost power or was reset
[ 4645.466868] usb usb4: root hub lost power or was reset
[ 4645.467121] usb usb5: root hub lost power or was reset
[ 4645.467176] usb usb6: root hub lost power or was reset
[ 4645.467218] usb usb7: root hub lost power or was reset
[ 4645.467260] usb usb8: root hub lost power or was reset
[ 4645.820748] usb 4-2: reset full-speed USB device number 2 using uhci_hcd
[ 5854.148710] usb usb3: root hub lost power or was reset
[ 5854.148899] usb usb4: root hub lost power or was reset
[ 5854.149543] usb usb5: root hub lost power or was reset
[ 5854.149731] usb usb6: root hub lost power or was reset
[ 5854.149774] usb usb7: root hub lost power or was reset
[ 5854.149816] usb usb8: root hub lost power or was reset
[ 5854.493970] usb 4-2: reset full-speed USB device number 2 using uhci_hcd
[ 5856.999178] usb usb3: root hub lost power or was reset
[ 5856.999233] usb usb4: root hub lost power or was reset
[ 5856.999488] usb usb5: root hub lost power or was reset
[ 5856.999542] usb usb6: root hub lost power or was reset
[ 5856.999585] usb usb7: root hub lost power or was reset
[ 5856.999627] usb usb8: root hub lost power or was reset
[ 5857.350632] usb 4-2: reset full-speed USB device number 2 using uhci_hcd
[ 7065.704327] usb usb3: root hub lost power or was reset
[ 7065.704383] usb usb4: root hub lost power or was reset
[ 7065.704635] usb usb5: root hub lost power or was reset
[ 7065.704692] usb usb6: root hub lost power or was reset
[ 7065.704734] usb usb7: root hub lost power or was reset
[ 7065.704776] usb usb8: root hub lost power or was reset
[ 7066.057188] usb 4-2: reset full-speed USB device number 2 using uhci_hcd
[ 7068.526700] usb usb3: root hub lost power or was reset
[ 7068.526886] usb usb4: root hub lost power or was reset
[ 7068.527279] usb usb5: root hub lost power or was reset
[ 7068.527322] usb usb6: root hub lost power or was reset
[ 7068.527364] usb usb7: root hub lost power or was reset
[ 7068.527406] usb usb8: root hub lost power or was reset
[ 7068.883843] usb 4-2: reset full-speed USB device number 2 using uhci_hcd
[ 8213.193268] usb usb3: root hub lost power or was reset
[ 8213.193453] usb usb4: root hub lost power or was reset
[ 8213.193824] usb usb5: root hub lost power or was reset
[ 8213.193867] usb usb6: root hub lost power or was reset
[ 8213.193909] usb usb7: root hub lost power or was reset
[ 8213.193952] usb usb8: root hub lost power or was reset
[ 8213.543727] usb 4-2: reset full-speed USB device number 2 using uhci_hcd
[ 8216.090442] usb usb3: root hub lost power or was reset
[ 8216.090628] usb usb4: root hub lost power or was reset
[ 8216.091275] usb usb5: root hub lost power or was reset
[ 8216.091462] usb usb6: root hub lost power or was reset
[ 8216.091505] usb usb7: root hub lost power or was reset
[ 8216.091546] usb usb8: root hub lost power or was reset
[ 8216.440398] usb 4-2: reset full-speed USB device number 2 using uhci_hcd
[alnayeef@alif-hppaviliondv6notebookpc ~]$ sudo dmesg -l emerg,alert,crit,err,warn
[ 0.093708] DMAR: [Firmware Bug]: Your BIOS is broken; DMAR reported at address 0!
BIOS vendor: Hewlett-Packard; Ver: F.02; Product Version: F.02
[ 0.398398] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.907369] [Firmware Bug]: Invalid critical threshold (0)
[ 0.910604] ahci 0000:00:1f.2: BIOS update required for suspend/resume
[ 1.034746] clocksource: timekeeping watchdog on CPU1: Marking clocksource 'tsc-early' as unstable because the skew is too large:
[ 1.034749] clocksource: 'hpet' wd_now: e8020b wd_last: 79ce94 mask: ffffffff
[ 1.034752] clocksource: 'tsc-early' cs_now: b783acbda cs_last: b4f771d52 mask: ffffffffffffffff
[ 1.034763] TSC found unstable after boot, most likely due to broken BIOS. Use 'tsc=unstable'.
[ 1.532073] Unstable clock detected, switching default tracing clock to "global"
If you want to keep using the local clock, then add:
"trace_clock=local"
on the kernel command line
[ 12.964098] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMBA) (20200110/utaddress-204)
[ 12.964110] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000050F (\GPIO) (20200110/utaddress-204)
[ 12.964162] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 13.392078] rc rc0: nonsensical timing event of duration 0
[ 13.392080] rc rc0: two consecutive events of type space
[ 14.459744] i801_smbus 0000:00:1f.3: BIOS is accessing SMBus registers
[ 14.459747] i801_smbus 0000:00:1f.3: Driver SMBus register access inhibited
[ 14.517050] wl: loading out-of-tree module taints kernel.
[ 14.517058] wl: module license 'MIXED/Proprietary' taints kernel.
[ 14.517059] Disabling lock debugging due to kernel taint
[ 15.184988] wlan0: Broadcom BCM4315 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
[ 15.434295] kauditd_printk_skb: 6 callbacks suppressed
[ 19.131640] uvcvideo 2-4:1.0: Entity type for entity Extension 5 was not initialized!
[ 19.131644] uvcvideo 2-4:1.0: Entity type for entity Extension 4 was not initialized!
[ 19.131646] uvcvideo 2-4:1.0: Entity type for entity Processing 3 was not initialized!
[ 19.131649] uvcvideo 2-4:1.0: Entity type for entity Camera 1 was not initialized!
[ 20.470429] kauditd_printk_skb: 2 callbacks suppressed
[ 25.618305] kauditd_printk_skb: 5 callbacks suppressed
[ 30.968770] kauditd_printk_skb: 4 callbacks suppressed
[ 68.651085] kauditd_printk_skb: 4 callbacks suppressed
[ 2921.729594] ahci 0000:00:1f.2: BIOS update required for suspend/resume
[ 2921.729605] PM: pci_pm_suspend(): ahci_pci_device_suspend+0x0/0x40 returns -5
[ 2921.729610] PM: dpm_run_callback(): pci_pm_suspend+0x0/0x160 returns -5
[ 2921.729616] PM: Device 0000:00:1f.2 failed to suspend async: error -5
[ 2921.729641] PM: Some devices failed to suspend, or early wake event detected
[ 2921.768990] ERROR @wl_wowl_ind_wake_reason :
[ 2921.768992] Unable to get wake reason, err = -95
[ 2924.710589] ahci 0000:00:1f.2: BIOS update required for suspend/resume
[ 2924.710598] PM: pci_pm_suspend(): ahci_pci_device_suspend+0x0/0x40 returns -5
[ 2924.710602] PM: dpm_run_callback(): pci_pm_suspend+0x0/0x160 returns -5
[ 2924.710607] PM: Device 0000:00:1f.2 failed to suspend async: error -5
[ 2924.710619] PM: Some devices failed to suspend, or early wake event detected
[ 2924.728839] ERROR @wl_wowl_ind_wake_reason :
[ 2924.728841] Unable to get wake reason, err = -95
[ 2925.245605] done.
[ 4642.661005] ahci 0000:00:1f.2: BIOS update required for suspend/resume
[ 4642.661013] PM: pci_pm_suspend(): ahci_pci_device_suspend+0x0/0x40 returns -5
[ 4642.661017] PM: dpm_run_callback(): pci_pm_suspend+0x0/0x160 returns -5
[ 4642.661022] PM: Device 0000:00:1f.2 failed to suspend async: error -5
[ 4642.661034] PM: Some devices failed to suspend, or early wake event detected
[ 4642.701734] ERROR @wl_wowl_ind_wake_reason :
[ 4642.701736] Unable to get wake reason, err = -95
[ 4645.466023] ahci 0000:00:1f.2: BIOS update required for suspend/resume
[ 4645.466032] PM: pci_pm_suspend(): ahci_pci_device_suspend+0x0/0x40 returns -5
[ 4645.466036] PM: dpm_run_callback(): pci_pm_suspend+0x0/0x160 returns -5
[ 4645.466042] PM: Device 0000:00:1f.2 failed to suspend async: error -5
[ 4645.466054] PM: Some devices failed to suspend, or early wake event detected
[ 4645.484652] ERROR @wl_wowl_ind_wake_reason :
[ 4645.484655] Unable to get wake reason, err = -95
[ 5854.148376] ahci 0000:00:1f.2: BIOS update required for suspend/resume
[ 5854.148387] PM: pci_pm_suspend(): ahci_pci_device_suspend+0x0/0x40 returns -5
[ 5854.148392] PM: dpm_run_callback(): pci_pm_suspend+0x0/0x160 returns -5
[ 5854.148399] PM: Device 0000:00:1f.2 failed to suspend async: error -5
[ 5854.148410] PM: Some devices failed to suspend, or early wake event detected
[ 5854.170148] ERROR @wl_wowl_ind_wake_reason :
[ 5854.170151] Unable to get wake reason, err = -95
[ 5856.998377] ahci 0000:00:1f.2: BIOS update required for suspend/resume
[ 5856.998386] PM: pci_pm_suspend(): ahci_pci_device_suspend+0x0/0x40 returns -5
[ 5856.998390] PM: dpm_run_callback(): pci_pm_suspend+0x0/0x160 returns -5
[ 5856.998395] PM: Device 0000:00:1f.2 failed to suspend async: error -5
[ 5856.998408] PM: Some devices failed to suspend, or early wake event detected
[ 5857.016447] ERROR @wl_wowl_ind_wake_reason :
[ 5857.016449] Unable to get wake reason, err = -95
[ 7065.703494] ahci 0000:00:1f.2: BIOS update required for suspend/resume
[ 7065.703504] PM: pci_pm_suspend(): ahci_pci_device_suspend+0x0/0x40 returns -5
[ 7065.703509] PM: dpm_run_callback(): pci_pm_suspend+0x0/0x160 returns -5
[ 7065.703517] PM: Device 0000:00:1f.2 failed to suspend async: error -5
[ 7065.703532] PM: Some devices failed to suspend, or early wake event detected
[ 7065.738780] ERROR @wl_wowl_ind_wake_reason :
[ 7065.738783] Unable to get wake reason, err = -95
[ 7068.525843] ahci 0000:00:1f.2: BIOS update required for suspend/resume
[ 7068.525852] PM: pci_pm_suspend(): ahci_pci_device_suspend+0x0/0x40 returns -5
[ 7068.525856] PM: dpm_run_callback(): pci_pm_suspend+0x0/0x160 returns -5
[ 7068.525861] PM: Device 0000:00:1f.2 failed to suspend async: error -5
[ 7068.525879] PM: Some devices failed to suspend, or early wake event detected
[ 7068.546738] ERROR @wl_wowl_ind_wake_reason :
[ 7068.546740] Unable to get wake reason, err = -95
[ 8213.192412] ahci 0000:00:1f.2: BIOS update required for suspend/resume
[ 8213.192421] PM: pci_pm_suspend(): ahci_pci_device_suspend+0x0/0x40 returns -5
[ 8213.192425] PM: dpm_run_callback(): pci_pm_suspend+0x0/0x160 returns -5
[ 8213.192429] PM: Device 0000:00:1f.2 failed to suspend async: error -5
[ 8213.192441] PM: Some devices failed to suspend, or early wake event detected
[ 8213.218952] ERROR @wl_wowl_ind_wake_reason :
[ 8213.218955] Unable to get wake reason, err = -95
[ 8216.089535] ahci 0000:00:1f.2: BIOS update required for suspend/resume
[ 8216.089546] PM: pci_pm_suspend(): ahci_pci_device_suspend+0x0/0x40 returns -5
[ 8216.089551] PM: dpm_run_callback(): pci_pm_suspend+0x0/0x160 returns -5
[ 8216.089557] PM: Device 0000:00:1f.2 failed to suspend async: error -5
[ 8216.089584] PM: Some devices failed to suspend, or early wake event detected
[ 8216.110953] ERROR @wl_wowl_ind_wake_reason :
[ 8216.110955] Unable to get wake reason, err = -95
[ 8216.612443] done.
[ 8525.218553] atkbd serio0: Unknown key pressed (translated set 2, code 0x94 on isa0060/serio0).
[ 8525.218557] atkbd serio0: Use 'setkeycodes e014 <keycode>' to make it known.
[ 8525.224073] atkbd serio0: Unknown key released (translated set 2, code 0x94 on isa0060/serio0).
[ 8525.224076] atkbd serio0: Use 'setkeycodes e014 <keycode>' to make it known.
[ 8525.602007] atkbd serio0: Unknown key pressed (translated set 2, code 0x94 on isa0060/serio0).
[ 8525.602011] atkbd serio0: Use 'setkeycodes e014 <keycode>' to make it known.
[ 8525.607834] atkbd serio0: Unknown key released (translated set 2, code 0x94 on isa0060/serio0).
[ 8525.607838] atkbd serio0: Use 'setkeycodes e014 <keycode>' to make it known.
[ 8525.661867] atkbd serio0: Unknown key pressed (translated set 2, code 0x94 on isa0060/serio0).
[ 8525.661871] atkbd serio0: Use 'setkeycodes e014 <keycode>' to make it known.
[ 8525.667509] atkbd serio0: Unknown key released (translated set 2, code 0x94 on isa0060/serio0).
[ 8525.667513] atkbd serio0: Use 'setkeycodes e014 <keycode>' to make it known.
[ 8527.561777] atkbd serio0: Unknown key pressed (translated set 2, code 0x94 on isa0060/serio0).
[ 8527.561780] atkbd serio0: Use 'setkeycodes e014 <keycode>' to make it known.
[ 8527.567620] atkbd serio0: Unknown key released (translated set 2, code 0x94 on isa0060/serio0).
[ 8527.567624] atkbd serio0: Use 'setkeycodes e014 <keycode>' to make it known.
[ 8528.309763] atkbd serio0: Unknown key pressed (translated set 2, code 0x94 on isa0060/serio0).
[ 8528.309767] atkbd serio0: Use 'setkeycodes e014 <keycode>' to make it known.
[ 8528.315382] atkbd serio0: Unknown key released (translated set 2, code 0x94 on isa0060/serio0).
[ 8528.315385] atkbd serio0: Use 'setkeycodes e014 <keycode>' to make it known.
[alnayeef@alif-hppaviliondv6notebookpc ~]$ journalctl -x -p3 -b1
-- Logs begin at Mon 2020-09-14 23:14:43 +06, end at Tue 2020-09-15 12:32:49 +0>
Sep 14 23:15:40 alif-hppaviliondv6notebookpc gdm-password][1363]: gkr-pam: unab>
Sep 14 23:18:15 alif-hppaviliondv6notebookpc kernel: ERROR @wl_cfg80211_scan :
Sep 14 23:19:08 alif-hppaviliondv6notebookpc kernel: ERROR @wl_cfg80211_scan :
Sep 14 23:19:20 alif-hppaviliondv6notebookpc wpa_supplicant[891]: bgscan simple>
Sep 14 23:34:33 alif-hppaviliondv6notebookpc kernel: ahci 0000:00:1f.2: BIOS up>
Sep 14 23:34:33 alif-hppaviliondv6notebookpc kernel: PM: pci_pm_suspend(): ahci>
Sep 14 23:34:33 alif-hppaviliondv6notebookpc kernel: PM: dpm_run_callback(): pc>
Sep 14 23:34:33 alif-hppaviliondv6notebookpc kernel: PM: Device 0000:00:1f.2 fa>
Sep 14 23:34:33 alif-hppaviliondv6notebookpc kernel: PM: Some devices failed to>
Sep 14 23:34:33 alif-hppaviliondv6notebookpc kernel: ERROR @wl_wowl_ind_wake_re>
Sep 14 23:34:34 alif-hppaviliondv6notebookpc wpa_supplicant[891]: bgscan simple>
Sep 14 23:34:36 alif-hppaviliondv6notebookpc kernel: ahci 0000:00:1f.2: BIOS up>
Sep 14 23:34:36 alif-hppaviliondv6notebookpc kernel: PM: pci_pm_suspend(): ahci>
Sep 14 23:34:36 alif-hppaviliondv6notebookpc kernel: PM: dpm_run_callback(): pc>
Sep 14 23:34:36 alif-hppaviliondv6notebookpc kernel: PM: Device 0000:00:1f.2 fa>
Sep 14 23:34:36 alif-hppaviliondv6notebookpc kernel: PM: Some devices failed to>
Sep 14 23:34:36 alif-hppaviliondv6notebookpc kernel: ERROR @wl_wowl_ind_wake_re>
Sep 14 23:34:36 alif-hppaviliondv6notebookpc systemd-sleep[2989]: Failed to sus>
â–‘â–‘ Subject: System sleep state suspend left
â–‘â–‘ Defined-By: systemd
â–‘â–‘ Support: https://forum.manjaro.org/c/support
â–‘â–‘
ESCOC
+06, end at Tue 2020-09-15 12:32:49 +06. --
okpc gdm-password][1363]: gkr-pam: unable to locate daemon control file
okpc wpa_supplicant[891]: bgscan simple: Failed to enable signal strength monit>
okpc kernel: ahci 0000:00:1f.2: BIOS update required for suspend/resume
okpc kernel: PM: pci_pm_suspend(): ahci_pci_device_suspend+0x0/0x40 returns -5
okpc kernel: PM: dpm_run_callback(): pci_pm_suspend+0x0/0x160 returns -5
okpc kernel: PM: Device 0000:00:1f.2 failed to suspend async: error -5
okpc kernel: PM: Some devices failed to suspend, or early wake event detected
okpc kernel: ERROR @wl_wowl_ind_wake_reason :
okpc systemd-sleep[2989]: Failed to suspend system. System resumed again: Input>
eft
support
ESCOC
Failed to enable signal strength monitoring
son :
son :
end system. System resumed again: Input/output error
ESCOD
eft
support
ESCOC
son :
son :
ESCOD
eft
support
ESCOD
â–‘â–‘
ESCOD
â–‘â–‘
ESCOD
Sir, I think solve for suspend problem deffers from device to device, i’m also following this thread to learn more
I’we done some reading about this and probably you have to create the following file:
/etc/systemd/system/sleep.conf
[Sleep]
HibernateMode=shutdown
This file tells Systemd to write shutdown
instead of platform
to /sys/power/disk
before writing disk
to /sys/power/state
Taken from here:
https://wiki.archlinux.org/index.php/Laptop/HP
Have you tried this?
Sir, thanks for your reply…in your reply you asked me to create a file, and I tried to do it accordingly(I may have made any mistake)after creating the file, I tried to hibernate my laptop but my srceen remained off or blank for about 3 minutes while the fan was still on then I moved the mouse and after a while the screen again waked up. Then I went through the ACPI Kernel Argument and tried to do what was instructed but it also didn’t work. whenever I try to sleep or hibernate my laptop the screen automatically wakes up. I am looking forward to your reply and hope that my problem will be solved…
How much RAM do you have?
Probably you need give more disc memory to “swap” partition. it has to be 1.5 or 2 times the total amount of RAM.
