Unable to set meta+ctrl+2 as custom shortcut
I had set my capslock as ctrl,
I'm trying to set a global shortcut for kwin, Window to Desktop with "meta + ctrl + 2". But it won't register on the input. Others are working fine "meta + ctr1 +1", "meta + ctr1 + 3" etc.
I also noticed that
But if I just use the "meta + left ctrl + 2" works just fine.
While using "meta + left ctrl + 1" like using "meta+ ctrl + 1".
So it looked to me that it is just "meta + ctrl +2" that is not working
System:    Host: T480 Kernel: 4.19.45-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.3.0 Desktop: KDE Plasma 5.15.5
           Distro: Manjaro Linux
Machine:   Type: Laptop System: LENOVO product: 20L5CTO1WW v: ThinkPad T480 serial: <filter>
           Mobo: LENOVO model: 20L5CTO1WW v: SDK0J40700 WIN serial: <filter> UEFI: LENOVO v: N24ET49W (1.24 ) date: 04/19/2019
Battery:   ID-1: BAT0 charge: 1.3 Wh condition: 24.4/24.0 Wh (102%) model: SMP 01AV421 status: Unknown
           ID-2: BAT1 charge: 40.7 Wh condition: 47.5/47.5 Wh (100%) model: LGC 01AV491 status: Discharging
CPU:       Topology: Quad Core model: Intel Core i5-8350U bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 6144 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 30344
           Speed: 801 MHz min/max: 400/3600 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Graphics:  Device-1: Intel UHD Graphics 620 vendor: Lenovo ThinkPad T480 driver: i915 v: kernel bus ID: 00:02.0
           Device-2: NVIDIA GP108M [GeForce MX150] driver: N/A bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.4 driver: intel resolution: 1366x768~60Hz
           OpenGL: renderer: Mesa DRI Intel UHD Graphics 620 (Kabylake GT2) v: 4.5 Mesa 19.0.4 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad T480 driver: snd_hda_intel v: kernel
           bus ID: 00:1f.3
           Sound Server: ALSA v: k4.19.45-1-MANJARO
Network:   Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: 3.2.6-k port: efa0 bus ID: 00:1f.6
           IF: enp0s31f6 state: down mac: <filter>
           Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: efa0 bus ID: 03:00.0
           IF-ID-1: br-40a5ff81801f state: up speed: N/A duplex: N/A mac: <filter>
           IF-ID-2: br-affd62d49a0d state: down mac: <filter>
           IF-ID-3: docker0 state: down mac: <filter>
           IF-ID-4: veth3f2ba28 state: up speed: 10000 Mbps duplex: full mac: <filter>
           IF-ID-5: veth499a270 state: up speed: 10000 Mbps duplex: full mac: <filter>
           IF-ID-6: vethd409c20 state: up speed: 10000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 476.94 GiB used: 134.96 GiB (28.3%)
           ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN720 SDAQNTW-512G-1001 size: 476.94 GiB
Partition: ID-1: / size: 343.96 GiB used: 134.94 GiB (39.2%) fs: ext4 dev: /dev/nvme0n1p5
Sensors:   System Temperatures: cpu: 44.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 249 Uptime: 11h 19m Memory: 15.41 GiB used: 2.07 GiB (13.4%) Init: systemd Compilers: gcc: 8.3.0
           Shell: zsh v: 5.7.1 inxi: 3.0.34
