Hello, Im trying to install Broadcom Wi-Fi drivers but I keep getting an error saying “unable to satisfy dependency linux54 required by linux54-Broadcom-wl”, is there any way to fix? My computer is a MacbookAir7,2
Hi,
You haven’t provided any details about your current system, so at a guess you may be better installing broadcom-wl-dkms
which should be kernel agnostic.
Or perhaps not
This, but you have to install the kernel headers first:
pamac install $(pamac list --quiet --installed | grep "^linux[0-9]*[-rt]*$" | awk '{print $1"-headers"}' ORS=' ')
This will install the headers for all installed kernels.
I tried the driver you sent, but it did not work
I do not have an internet connection on this computer
Error: target not found: Linux515-headers
You need an internet connection to install almost anything. The packages are downloaded from the internet after all.
See above
I think you’ll have to:
- Get that machine connected to the internet; or
- take a look at Offline installation of packages - ArchWiki
I have a machine with internet, but it has windows on it.
My point is the same…
So? How do I get the headers?
Very shortly:
- Download the headers:
wget https://mirror.dkm.cz/manjaro/stable/core/x86_64/linux515-headers-5.15.41-1-x86_64.pkg.tar.zst -o ~/Downloads/
- Install them:
pacman -U ~/Downloads/linux515-headers-5.15.41-1-x86_64.pkg.tar.zst
_There might be, in fact there are likely to be other steps as well, that’s why this is a very short, very basic example.
You can download the packages from a mirror of your choosing, for the links see:
Then see above posts from @Mirdarthos on how to install them offline.
Connect to internet via cable from phone and enable tethering, then post output from: mhwd -l
Broadcom drivers should be available there…
It says that it detects a network driver, but the free driver is set to false
Copy the output from the command here
0000:03:00.0 (0280:14e4:43a0) Network controller Broadcom:
NAME VERSION FREEDRIVER TYPE
network-broadcom-wl 2018.10.07 false PCI
> 0000:00:02.0 (0300:8086:1626) Display controller Intel Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
Please provide the output of:
mhwd --listinstalled
Installed PCI configs:
Install it:
sudo mhwd -i pci network-broadcom-wl
Then reboot
it says “script failed”
