I decided to play around with gnome boxes today to see if I could make a vm on an external hard drive. I use gnome boxes to download a live session of Ubuntu 20.10. After that, I found the vm in my .local file and cut and pasted it into my external hdd, then I ran the command
Now every time I startup gnome boxes it will open up for a second and then immediately close after that. I’ve tried to unlink the location and reinstalling gnome boxes but neither option has yielded any results. Honestly I’m not really sure what to do about this since all I did was make a symbolic link. Does anyone have any ideas how I can troubleshoot this?
In most virtual vm managers contain an option to add or import a VM - use that functionality to open the vm from the new location - maybe remove it from the system config before this action.
It might be. If you do not quote filenames with spaces in them or escape the spaces with a backslash (""), then those spaces are interpreted as separators, meaning that the word after the space is considered a separate filename. As such, you probably have some broken symlinks lingering around.
okay after some more research I found the solution. all I had to do was find where I pasted the virtual machine and put it back under .local. Honestly still not sure why gnome boxes would break because of this but now I know ¯_( ツ)_/¯
