Hi.
My problem is the same with Live ISO, or installed Manjaro Qonos 21.2.
When trying to play audio from anywhere (browser or mediaplayer), or video (VLC, no sound, Youtube, freeze), my NUC is unable to decode audio.
Here are the details: Apologies, the system is using fr-CH locale
aplay -l
**** Liste des périphériques matériels PLAYBACK ****
carte 0 : Audio [Intel HDMI/DP LPE Audio], périphérique 0 : HdmiLpeAudio [Intel HDMI/DP LPE Audi]
Sous-périphériques : 1/1
Sous-périphérique #0 : subdevice #0
carte 0 : Audio [Intel HDMI/DP LPE Audio], périphérique 1 : HdmiLpeAudio [Intel HDMI/DP LPE Audi]
carte 0 : Audio [Intel HDMI/DP LPE Audio], périphérique 2 : HdmiLpeAudio [Intel HDMI/DP LPE Audi]
Sous-périphériques : 0/1
pacmd dump
### Configuration dump generated at Fri Mar 18 22:21:14 2022
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="0" name="pci-0000_00_02.0-platform-hdmi-lpe-audio" card_name="alsa_card.pci-0000_00_02.0-platform-hdmi-lpe-audio" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_00_02.0-platform-hdmi-lpe-audio.hdmi-stereo-extra2 0x10000
set-sink-mute alsa_output.pci-0000_00_02.0-platform-hdmi-lpe-audio.hdmi-stereo-extra2 no
suspend-sink alsa_output.pci-0000_00_02.0-platform-hdmi-lpe-audio.hdmi-stereo-extra2 no
set-source-volume alsa_output.pci-0000_00_02.0-platform-hdmi-lpe-audio.hdmi-stereo-extra2.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_02.0-platform-hdmi-lpe-audio.hdmi-stereo-extra2.monitor no
suspend-source alsa_output.pci-0000_00_02.0-platform-hdmi-lpe-audio.hdmi-stereo-extra2.monitor no
set-card-profile alsa_card.pci-0000_00_02.0-platform-hdmi-lpe-audio output:hdmi-stereo-extra2
set-default-sink alsa_output.pci-0000_00_02.0-platform-hdmi-lpe-audio.hdmi-stereo-extra2
set-default-source alsa_output.pci-0000_00_02.0-platform-hdmi-lpe-audio.hdmi-stereo-extra2.monitor
### EOF
mhwd -l -d
> PCI Device: /devices/pci0000:00/0000:00:1c.2/0000:03:00.0 (0200:10ec:8168)
Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
> AVAILABLE:
ATTACHED: PCI
VERSION: 2016.04.20
INFO: RealTek RTL-8168 Gigabit Ethernet driver
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0200
VENDORIDS: 1186 10ec
> PCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:22b1)
Display controller Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics Controller
> INSTALLED:
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
> AVAILABLE:
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
INFO: X.org modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
INFO: X.org vesa video driver.
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
Warning: no configs for USB devices found!
inxi -SMAa
Host: planque-virtuelle Kernel: 5.15.28-1-MANJARO x86_64 bits: 64
compiler: gcc v: 11.2.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
root=UUID=28be2eaf-83b7-4574-a1cf-958b6cbd0810 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Intel model: NUC5PPYB v: H76558-108
serial: <superuser required> UEFI: Intel
v: PYBSWCEL.86A.0057.2016.1012.1134 date: 10/12/2016
Device-1: Intel HDMI/DP LPE Audio driver: HdmiLpeAudio
message: bus/chip ids unavailable
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
lspci
00:00.0 Host bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SoC Transaction Register (rev 21)
00:02.0 VGA compatible controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics Controller (rev 21)
00:12.0 SD Host controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SD Controller (rev 21)
00:13.0 SATA controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SATA Controller (rev 21)
00:14.0 USB controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series USB xHCI Controller (rev 21)
00:18.0 DMA controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO2 DMA Controller (rev 21)
00:18.6 Serial bus controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO2 I2C Controller #6 (rev 21)
00:18.7 Serial bus controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO2 I2C Controller #7 (rev 21)
00:1a.0 Encryption controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Trusted Execution Engine (rev 21)
00:1c.0 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port #1 (rev 21)
00:1c.1 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port #2 (rev 21)
00:1c.2 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port #3 (rev 21)
00:1f.0 ISA bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCU (rev 21)
00:1f.3 SMBus: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx SMBus Controller (rev 21)
02:00.0 Network controller: Intel Corporation Wireless 3165 (rev 81)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
In DMESG I can see this kind of messages, yet I have no idea if this gives any indication of what is happening:
[ 1067.362087] x86/PAT: pulseaudio:8001 map pfn RAM range req uncached-minus for [mem 0x36c00000-0x36c56fff], got write-combining
[ 1096.982489] x86/PAT: alsa-sink-HdmiL:8003 map pfn RAM range req uncached-minus for [mem 0x36c00000-0x36c56fff], got write-combining
[ 1882.259946] x86/PAT: pulseaudio:8001 map pfn RAM range req uncached-minus for [mem 0x36c00000-0x36c95fff], got write-combining
[ 1912.535205] x86/PAT: pulseaudio:8001 map pfn RAM range req uncached-minus for [mem 0x36c00000-0x36c95fff], got write-combining
[ 1912.581269] x86/PAT: alsa-sink-HdmiL:13233 map pfn RAM range req uncached-minus for [mem 0x36c00000-0x36c95fff], got write-combining
[ 1915.761864] x86/PAT: pulseaudio:8001 map pfn RAM range req uncached-minus for [mem 0x36c00000-0x36c56fff], got write-combining
[ 1915.804950] x86/PAT: alsa-sink-HdmiL:13251 map pfn RAM range req uncached-minus for [mem 0x36c00000-0x36c56fff], got write-combining
Trying to play sound with aplay on card 0 device 0 sub 0 gives this result:
aplay -v -D plughw:0,0 /usr/share/sounds/alsa/Front_Center.wav
Lecture WAVE '/usr/share/sounds/alsa/Front_Center.wav' : Signed 16 bit Little Endian, Fréquence 48000 Hz, Mono
Plug PCM: Route conversion PCM (sformat=S16_LE)
Transformation table:
0 <- 0
1 <- 0
Its setup is:
stream : PLAYBACK
access : RW_INTERLEAVED
format : S16_LE
subformat : STD
channels : 1
rate : 48000
exact rate : 48000 (48000/1)
msbits : 16
buffer_size : 24000
period_size : 6000
period_time : 125000
tstamp_mode : NONE
tstamp_type : MONOTONIC
period_step : 1
avail_min : 6000
period_event : 0
start_threshold : 24000
stop_threshold : 24000
silence_threshold: 0
silence_size : 0
boundary : 6755399441055744000
Slave: Hardware PCM card 0 'Intel HDMI/DP LPE Audio' device 0 subdevice 0
Its setup is:
stream : PLAYBACK
access : MMAP_INTERLEAVED
format : S16_LE
subformat : STD
channels : 2
rate : 48000
msbits : 16
buffer_size : 24000
period_size : 6000
tstamp_mode : NONE
period_step : 1
avail_min : 6000
period_event : 0
silence_size : 0
appl_ptr : 0
hw_ptr : 0
perte!!! (au moins longue de 0.083 ms)
État :
state : XRUN
trigger_time: 3217.964387
tstamp : 0.000000
delay : 0
avail : 0
avail_max : 0
perte!!! (au moins longue de 0.008 ms)
État :
state : XRUN
trigger_time: 3217.964839
tstamp : 0.000000
delay : 0
avail : 0
avail_max : 0
and gave a new entry in dmesg:
[ 3217.590326] x86/PAT: aplay:20437 map pfn RAM range req uncached-minus for [mem 0x01200000-0x01217fff], got write-combining
I get the same result on card 0 device 1, however card 0 device 2 returns Device or resource is busy
Any lead to troubleshoot and fix this problem is very welcome. Any more details you need please let me know
