I tried and the splash window opened, but except some complaints about a font size conversion problem (that came up for many month) nothing. The process soffice shows up in ps aux, but didn’t made any load on the system.
It might just be a hidden window if the process is there. Try clicking to open it, and immediately afterwards pressing the keyboard shortcutt to maximize it and see what happens. The shortcut for me was/is Meta + Up couple of times, I think two.
I cleaned up the hole screen and tried - no luck (META-PageUP in my case).
It might be related to the windows manager - I have plasma KDE.
Trying the flatpak was successful, no problems whatsoever. :-/ ??
hello marcus,
i had the same issue. none of the tips given to me figured out the problem. this is a problem of the packaging in manjaro-stable. switching to the unstable branch did it.
thanks a lot for the answer. I tried it and then LO just works. I reverted back to stable as this is my production machine and continue using flatpak LO.
I’m on XFCE/Xorg, but sometimes an application is running, icon is visible in the panel, but the application window is nowhere to be found. If I click “Show Desktop”/“Peek at Desktop” and then again, the application window is visible. Something to try…
