After the latest update I cannot open the connection settings anymore. Going to System Settings and then clicking the Connections option kills the window and stops the process. Is there a known solution?
I need to access my network configuration to change some things but I’m unable to due to this. Anyone knows what package do I need to downgrade so that I can open my config again?
Not gonna lie, after using KDE for so long I’ve realized every new update is a gamble on whether something breaks or not. I’m at a point where I would consider switching because of this instability, but there’s not other desktop environment that looks as good.
Ran systemsettings5 through a terminal and got some error logs:
andrew@andrew-pc ~> systemsettings5
Cyclic dependency detected between "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml" and "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml"
file:///usr/share/kpackage/genericqml/org.kde.systemsettings.sidebar/contents/ui/CategoriesPage.qml:66:21: QML Action: LayoutDirection attached property only works with Items and Windows
file:///usr/share/kpackage/genericqml/org.kde.systemsettings.sidebar/contents/ui/SubCategoryPage.qml:129:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
file:///usr/lib/qt/qml/org/kde/kirigami.2/private/RefreshableScrollView.qml:137:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
QQmlEngine::setContextForObject(): Object already has a QQmlContext
file:///usr/share/kcm_networkmanagement/qml/ListItem.qml:41:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
file:///usr/lib/qt/qml/org/kde/kirigami.2/FormLayout.qml:337:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Selecting active connection: "8517cd22-0be0-350f-8348-c1612a3d608f"
fish: “systemsettings5” terminated by signal SIGSEGV (Address boundary error)
What should I do?
