Hello friends.
2 days ago I bought a 500GB SSD Sata and try to clone to him my old 500GB HDD with Manjaro installation.
First I clone my old disk to another HDD using clonezilla but when I try to restore it to my new SSD, after 8 hours of working (96% done) it gives me some error. I don’t remember what was that error because I was so angry that I turn off my PC and go sleep.
Next day I decide to use Rescuezilla whit option clone. Everything go fast and was done but there was shown a message:
Cytat
Successfully restored image partition /dev/sdb1 to /dev/sda1
Resizing partition /dev/sda1 (btrfs) failed: Failed to run command: mount -t btrfs /dev/sda1 /mnt/…
mount: /mnt: wrong fs type, bad option, bad superblock on /dev/sda1, missing codepage or helper program, or other error.
Successfully restored image partition /dev/sdb2 to /dev/sda2
I run Manjaro Live and try to mount my SSD but there is the same error:
~ sudo mount -t btrfs /dev/sda1 /mnt ✔
I was looking for some solution but nothing match to my issue.
Pls help
~ lsblk -f INT ✘
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squashfs 4.0 0 100% /run/miso/sfs/livefs
loop1 squashfs 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squashfs 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squashfs 4.0 0 100% /run/miso/sfs/rootfs
sda
├─sda1 btrfs 619a3ee2-88a2-48cf-bd87-d34c3ce88064
└─sda2 swap 1 swap 6da3b062-f33a-45f5-8ace-ac17fccc6974
sdb
├─sdb1 btrfs 619a3ee2-88a2-48cf-bd87-d34c3ce88064
└─sdb2 swap 1 swap 6da3b062-f33a-45f5-8ace-ac17fccc6974
sdc
└─sdc1 btrfs Backup b25d1d8e-31be-4d80-82d2-f853013428c4
sdd
├─sdd1 exfat 1.0 Ventoy 4E21-0000
│ └─ventoy iso9660 Joliet Extension MANJARO_KDE_2125 2022-03-14-10-19-45-00 0 100% /run/miso/bootmnt
└─sdd2 vfat FAT16 VTOYEFI B336-78FD
sr0
~ sudo fdisk -l ✔
Disk /dev/sda: 476.94 GiB, 512110190592 bytes, 1000215216 sectors
Disk model: SSDPR-CX400-512-
Disklabel type: dos
Disk identifier: 0xe1244e6d
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 958313125 958311078 457G 83 Linux
/dev/sda2 958313126 976768064 18454939 8.8G 82 Linux swap / Solaris
Disk /dev/sdb: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: ST500DM002-1BD14
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
/dev/sdb1 * 2048 958313125 958311078 457G 83 Linux
/dev/sdb2 958313126 976768064 18454939 8.8G 82 Linux swap / Solaris
Partition 2 does not start on physical sector boundary.
Disk /dev/sdc: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: HGST HTS725050A7
Disklabel type: dos
Disk identifier: 0xbf8187ea
/dev/sdc1 2048 976766975 976764928 465.8G 83 Linux
Disk /dev/loop0: 18.94 MiB, 19861504 bytes, 38792 sectors
Disk /dev/loop1: 834.63 MiB, 875171840 bytes, 1709320 sectors
Disk /dev/loop2: 2.01 GiB, 2159173632 bytes, 4217136 sectors
Disk /dev/loop3: 642.82 MiB, 674045952 bytes, 1316496 sectors
Disk /dev/sdd: 7.28 GiB, 7811891200 bytes, 15257600 sectors
Disk model: Flash Disk
Disklabel type: dos
Disk identifier: 0x8f5137b8
/dev/sdd1 * 2048 15192063 15190016 7.2G 7 HPFS/NTFS/exFAT
/dev/sdd2 15192064 15257599 65536 32M ef EFI (FAT-12/16/32)
Disk /dev/mapper/ventoy: 3.54 GiB, 3805800448 bytes, 7433204 sectors
Disklabel type: dos
Disk identifier: 0x00000000
/dev/mapper/ventoy-part1 * 64 7425011 7424948 3.5G 0 Empty
/dev/mapper/ventoy-part2 7425012 7433203 8192 4M ef EFI (FAT-12/16/32)
