Hello! I’m running 6.0.2-3-MANJARO-ARM on a RockPro64 board. I had been logged in remotely via ssh when I got this error:
/bin/bash: error while loading shared libraries: /usr/lib/libncursesw.so.6: unsupported version 4097 of Verneed record
That error meant less than nothing to me so I ran “sudo reboot now” and successfully rebooted, still remote. When I tried to ssh back in with the same account I’d been logged in as before, I got this:
Last login: Fri Feb 24 14:57:22 2023 from xyz
-bash: /usr/lib/libncursesw.so.6: unsupported version 8193 of Verdef record
-bash: error while loading shared libraries: /usr/lib/libncursesw.so.6: unsupported version 4097 of Verneed record
Connection to abc closed.
So I’m unable to ssh in. I schlepped down to the basement and hooked up a monitor/keyboard (this box is normally headless) and attempted to login locally as my user account and as root. Both scroll some info on the screen too fast to read (I assume a similar error as when ssh’ing, but I can’t be sure) and then unceremoniously return me to my original login prompt.
So, no updates or installs were performed between working and broken, and I’m now completely unable to login. I’m at a loss as to what could have happened here. The boot disk is an industrial type SD card, so I can remove that to work on it in my Mac if there’s anything to be done that way.
Thanks for any assistance!
