I’m trying to follow the wiki article to build a manjaro ISO with buildiso and it tells me to get manjaro-tools-iso git, but every time I try to get it, it gives me the following warning:
Warning: dependency cycle detected:
Warning: rubygems will be installed before its ruby dependency
I let it install for about 4 hours now. This is what I got thus far:
Warning: ruby-irb will be installed before its ruby dependency
Warning: ruby-reline will be installed before its ruby dependency
If this is normal, how long do I have to wait until it’s done?
Be sure you install the corresponding git version of all packages - if you want to use manjaro-tools-iso-git - you need to install the other git versions manually as well
manjaro-tools-base-git
manjaro-tools-yaml-git
The next one is technically not needed for iso building but the same rule apply
