Building python-pep517...
==> Making package: python-pep517 0.13.0-1 (Sat 23 Sep 2023 10:34:42)
==> Retrieving sources...
-> Found python-pep517-0.13.0.tar.gz
-> Found a29513a03d60a90c048ad9281dd7e897bd6f40b1.patch
python-pep517-0.13.0.tar.gz ... Passed
a29513a03d60a90c048ad9281dd7e897bd6f40b1.patch ... Passed
==> Extracting sources...
-> Extracting python-pep517-0.13.0.tar.gz with bsdtar
==> Starting prepare()...
/var/tmp/pamac-build-tracy/python-pep517/PKGBUILD: line 19: patch: command not found
==> ERROR: A failure occurred in prepare().
Aborting...
Apparently it is needed by one of the few AUR packages I have installed, and this is an update for the existing package.
Which one? There are very few that still require it as the PEP517 project is deprecated now in favor of pyproject-hooks (python-pyproject-hooks
pacman -Qi python-pep517 | grep 'Required By\|Optional For'
I don’t know. I’ll have a look. But if it’s deprecated that probably explains the missing commands needed to build it.
EDIT:
Nothing depends on it apparently. It’s gone.
dmt
24 September 2023 17:20
4
For future reference, you seem to be missing base-devel
dmt:
base-devel
That doesn’t appear to affect any other AUR packages. Mullvad VPN, for example, updates with no issues. So not going to worry at this time.
zbe
24 September 2023 21:01
6
It affects every PKGBUILD that uses patch
command. Same for anything else in base-devel.
Interesting.
That would indicate that the AUR packages, like Mullvad VPN, that I care about, don’t use the ‘patch’ command.
Good to know.
zbe
24 September 2023 21:09
8
Don’t see how it’s interesting.
It’s like you have 3 scripts, one of them has htop
in them and the other two don’t and you don’t have htop
installed. Is it interesting that other two scripts ran fine because they don’t have htop
in them?
New information is always interesting.
@tracyanne base-devel
is a prerequisite for using the AUR. Period. No ands, ifs or buts.
Please see:
