I removed (or uninstalled) homebrew from my laptop completely but I still keep seeing this line above the dollar sign on my terminal:
bash: /home/linuxbrew/.linuxbrew/bin/brew: No such file or directory
How do I remove it? Please and thank you.
You will likely need to remove any reference to Homebrew from either your ~/.bashrc
or ~/.bash_profile
files, or both.
grep ".linuxbrew/bin/brew" ~/.*
I got this output after running the command:
/home/privurity/.bash_history:(echo; echo 'eval "$(/home/linuxbrew/.linuxbrew/bin/brew shellenv)"') >> /home/privurity/.bashrc
/home/privurity/.bash_history: eval "$(/home/linuxbrew/.linuxbrew/bin/brew shellenv)"
/home/privurity/.bash_history:grep ".linuxbrew/bin/brew" ~/.*
/home/privurity/.bashrc:eval "$(/home/linuxbrew/.linuxbrew/bin/brew shellenv)"
grep: /home/privurity/.cache: Is a directory
grep: /home/privurity/.cert: Is a directory
grep: /home/privurity/.config: Is a directory
grep: /home/privurity/.dvdcss: Is a directory
grep: /home/privurity/.gnome: Is a directory
grep: /home/privurity/.gnupg: Is a directory
grep: /home/privurity/.hplip: Is a directory
grep: /home/privurity/.icons: Is a directory
grep: /home/privurity/.jak: Is a directory
grep: /home/privurity/.librewolf: Is a directory
grep: /home/privurity/.links: Is a directory
grep: /home/privurity/.local: Is a directory
grep: /home/privurity/.lyrics: Is a directory
grep: /home/privurity/.mozilla: Is a directory
grep: /home/privurity/.npm: Is a directory
grep: /home/privurity/.openjfx: Is a directory
grep: /home/privurity/.pki: Is a directory
grep: /home/privurity/.putty: Is a directory
grep: /home/privurity/.themes: Is a directory
grep: /home/privurity/.tldr: Is a directory
grep: /home/privurity/.var: Is a directory
And what does it tell you? Hint: Read my previous post.
Open that file
in an editor and remove or comment out that line
I removed this line eval “$(/home/linuxbrew/.linuxbrew/bin/brew shellenv)” from .bashrc.
Thank you.
Most welcome.
