@Keruskerfuerst Thanks.
Here are the contents of the file. Please let me know if you need any further information.
[ 346.722] (--) Log file renamed from "/var/log/Xorg.pid-1039.log" to "/var/log/Xorg.0.log"
[ 346.722]
X.Org X Server 1.21.1.4
[ 346.722] Current Operating System: Linux efinso-desktop 5.15.78-1-MANJARO #1 SMP PREEMPT Thu Nov 10 20:50:09 UTC 2022 x86_64
[ 346.722] Kernel command line: BOOT_IMAGE=/vmlinuz-5.15-x86_64 root=UUID=ab9d4bff-20a2-4461-8161-5f5cc88e80c2 rw quiet resume=UUID=f824d792-6424-4c78-80a0-c2d4b879ab98 udev.log_priority=3
[ 346.722]
[ 346.722] Current version of pixman: 0.42.2
[ 346.722] Before reporting problems, check http://wiki.x.org
[ 346.722] Markers: (--) probed, (**) from config file, (==) default setting,
[ 346.722] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Nov 17 10:44:33 2022
[ 346.722] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 346.722] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 346.722] (==) No Layout section. Using the first Screen section.
[ 346.722] (==) No screen section available. Using defaults.
[ 346.722] (**) |-->Screen "Default Screen Section" (0)
[ 346.722] (**) | |-->Monitor "<default monitor>"
[ 346.722] (==) No monitor specified for screen "Default Screen Section".
[ 346.722] (==) Automatically adding devices
[ 346.722] (==) Automatically enabling devices
[ 346.722] (==) Automatically adding GPU devices
[ 346.722] (==) Automatically binding GPU devices
[ 346.722] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 346.722] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 346.722] Entry deleted from font path.
[ 346.722] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 346.722] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 346.722] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 346.722] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 346.722] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 346.722] (II) The server relies on udev to provide the list of input devices.
[ 346.722] (II) Module ABI versions:
[ 346.722] X.Org ANSI C Emulation: 0.4
[ 346.722] X.Org Video Driver: 25.2
[ 346.722] X.Org XInput driver : 24.4
[ 346.722] X.Org Server Extension : 10.0
[ 346.723] (++) using VT number 1
[ 346.723] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 346.724] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 346.724] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card1
[ 346.724] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 346.724] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 346.726] (--) PCI: (0@0:2:0) 8086:0412:1458:d000 rev 6, Mem @ 0xf7400000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 346.726] (--) PCI:*(1@0:0:0) 10de:11c6:19da:5294 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/134217728, 0xe8000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 346.726] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 346.726] (II) LoadModule: "glx"
[ 346.726] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 346.727] (II) Module glx: vendor="X.Org Foundation"
[ 346.727] compiled for 1.21.1.4, module version = 1.0.0
[ 346.727] ABI class: X.Org Server Extension, version 10.0
[ 346.728] (==) Matched modesetting as autoconfigured driver 0
[ 346.728] (==) Matched fbdev as autoconfigured driver 1
[ 346.728] (==) Matched vesa as autoconfigured driver 2
[ 346.728] (==) Assigned the driver to the xf86ConfigLayout
[ 346.728] (II) LoadModule: "modesetting"
[ 346.728] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 346.728] (II) Module modesetting: vendor="X.Org Foundation"
[ 346.728] compiled for 1.21.1.4, module version = 1.21.1
[ 346.728] Module class: X.Org Video Driver
[ 346.728] ABI class: X.Org Video Driver, version 25.2
[ 346.728] (II) LoadModule: "fbdev"
[ 346.728] (WW) Warning, couldn't open module fbdev
[ 346.728] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 346.728] (II) LoadModule: "vesa"
[ 346.728] (WW) Warning, couldn't open module vesa
[ 346.728] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 346.728] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 346.728] (II) modeset(0): using drv /dev/dri/card1
[ 346.728] (II) modeset(G0): using drv /dev/dri/card0
[ 346.729] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 346.729] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 346.729] (==) modeset(0): RGB weight 888
[ 346.729] (==) modeset(0): Default visual is TrueColor
[ 346.729] (II) Loading sub module "glamoregl"
[ 346.729] (II) LoadModule: "glamoregl"
[ 346.729] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 346.731] (II) Module glamoregl: vendor="X.Org Foundation"
[ 346.731] compiled for 1.21.1.4, module version = 1.0.1
[ 346.731] ABI class: X.Org ANSI C Emulation, version 0.4
[ 346.754] (II) modeset(0): glamor X acceleration enabled on NVE6
[ 346.754] (II) modeset(0): glamor initialized
[ 346.754] (==) modeset(0): VariableRefresh: disabled
[ 346.754] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 346.755] (II) modeset(0): Output DVI-D-1 has no monitor section
[ 346.789] (II) modeset(0): Output VGA-2 has no monitor section
[ 346.790] (II) modeset(0): Output HDMI-3 has no monitor section
[ 346.792] (II) modeset(0): EDID for output DVI-D-1
[ 346.826] (II) modeset(0): EDID for output VGA-2
[ 346.826] (II) modeset(0): Manufacturer: DEL Model: d053 Serial#: 843470932
[ 346.826] (II) modeset(0): Year: 2014 Week: 11
[ 346.826] (II) modeset(0): EDID Version: 1.3
[ 346.826] (II) modeset(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
[ 346.826] (II) modeset(0): Sync: Separate Composite SyncOnGreen
[ 346.826] (II) modeset(0): Max Image Size [cm]: horiz.: 48 vert.: 27
[ 346.826] (II) modeset(0): Gamma: 2.20
[ 346.826] (II) modeset(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
[ 346.826] (II) modeset(0): First detailed timing is preferred mode
[ 346.826] (II) modeset(0): redX: 0.641 redY: 0.337 greenX: 0.313 greenY: 0.623
[ 346.826] (II) modeset(0): blueX: 0.151 blueY: 0.070 whiteX: 0.313 whiteY: 0.329
[ 346.826] (II) modeset(0): Supported established timings:
[ 346.826] (II) modeset(0): 720x400@70Hz
[ 346.826] (II) modeset(0): 640x480@60Hz
[ 346.826] (II) modeset(0): 640x480@75Hz
[ 346.826] (II) modeset(0): 800x600@60Hz
[ 346.826] (II) modeset(0): 800x600@75Hz
[ 346.826] (II) modeset(0): 1024x768@60Hz
[ 346.826] (II) modeset(0): 1024x768@75Hz
[ 346.826] (II) modeset(0): 1280x1024@75Hz
[ 346.826] (II) modeset(0): Manufacturer's mask: 0
[ 346.826] (II) modeset(0): Supported standard timings:
[ 346.826] (II) modeset(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 346.826] (II) modeset(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 346.826] (II) modeset(0): #2: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 346.826] (II) modeset(0): Supported detailed timing:
[ 346.826] (II) modeset(0): clock: 148.5 MHz Image Size: 476 x 267 mm
[ 346.826] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 346.826] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 346.826] (II) modeset(0): Serial No: 1MVD143G2FXT
[ 346.826] (II) modeset(0): Monitor name: DELL S2240L
[ 346.826] (II) modeset(0): Ranges: V min: 56 V max: 76 Hz, H min: 30 H max: 83 kHz, PixClock max 175 MHz
[ 346.826] (II) modeset(0): EDID (in hex):
[ 346.826] (II) modeset(0): 00ffffffffffff0010ac53d054584632
[ 346.826] (II) modeset(0): 0b1801030e301b78ea16c5a456509f26
[ 346.826] (II) modeset(0): 125054a54b00714f8180d1c001010101
[ 346.826] (II) modeset(0): 010101010101023a801871382d40582c
[ 346.826] (II) modeset(0): 4500dc0b1100001e000000ff00314d56
[ 346.826] (II) modeset(0): 4431343347324658540a000000fc0044
[ 346.826] (II) modeset(0): 454c4c2053323234304c0a20000000fd
[ 346.826] (II) modeset(0): 00384c1e5311000a20202020202000ad
[ 346.826] (II) modeset(0): Not using default mode "1440x810" (bad mode clock/interlace/doublescan)
[ 346.826] (II) modeset(0): Not using default mode "1600x900" (bad mode clock/interlace/doublescan)
[ 346.826] (II) modeset(0): Not using default mode "1920x1080" (bad mode clock/interlace/doublescan)
[ 346.826] (II) modeset(0): Printing probed modes for output VGA-2
[ 346.826] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 346.826] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 346.826] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 346.826] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 346.826] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 346.826] (II) modeset(0): Modeline "1400x1050"x74.8 155.80 1400 1464 1784 1912 1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
[ 346.826] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 346.826] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 346.826] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 346.826] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 346.826] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 346.826] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 346.826] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 346.826] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 346.826] (II) modeset(0): Modeline "1440x810"x60.0 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 346.826] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 346.826] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 346.826] (II) modeset(0): Modeline "1280x800"x60.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 346.826] (II) modeset(0): Modeline "1280x800"x60.0 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 346.826] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 346.826] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 346.826] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 346.826] (II) modeset(0): Modeline "1280x720"x60.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 346.826] (II) modeset(0): Modeline "1280x720"x60.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 346.826] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 346.826] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 346.826] (II) modeset(0): Modeline "1024x768"x75.0 170.24 1024 1108 1220 1416 768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
[ 346.826] (II) modeset(0): Modeline "1024x768"x60.0 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 346.826] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 346.826] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz d)
[ 346.826] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 346.826] (II) modeset(0): Modeline "960x720"x75.0 148.50 960 1032 1144 1320 720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
[ 346.826] (II) modeset(0): Modeline "960x720"x60.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 346.826] (II) modeset(0): Modeline "928x696"x75.0 144.00 928 992 1104 1280 696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
[ 346.826] (II) modeset(0): Modeline "928x696"x60.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 346.826] (II) modeset(0): Modeline "896x672"x75.0 130.50 896 944 1052 1228 672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
[ 346.826] (II) modeset(0): Modeline "896x672"x60.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 346.826] (II) modeset(0): Modeline "1024x576"x60.0 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 346.826] (II) modeset(0): Modeline "1024x576"x60.0 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 346.826] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 346.826] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 346.826] (II) modeset(0): Modeline "960x600"x59.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 346.826] (II) modeset(0): Modeline "960x600"x60.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 346.826] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz d)
[ 346.826] (II) modeset(0): Modeline "960x540"x60.0 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 346.826] (II) modeset(0): Modeline "960x540"x60.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 346.826] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 346.826] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 346.826] (II) modeset(0): Modeline "800x600"x75.0 101.25 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
[ 346.826] (II) modeset(0): Modeline "800x600"x70.0 94.50 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
[ 346.826] (II) modeset(0): Modeline "800x600"x65.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
[ 346.826] (II) modeset(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 346.826] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz d)
[ 346.826] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 346.826] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 346.826] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 346.826] (II) modeset(0): Modeline "840x525"x60.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 346.826] (II) modeset(0): Modeline "840x525"x59.9 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 346.826] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 346.826] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 346.826] (II) modeset(0): Modeline "700x525"x74.8 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
[ 346.826] (II) modeset(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 346.826] (II) modeset(0): Modeline "800x450"x59.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 346.826] (II) modeset(0): Modeline "800x450"x59.8 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 346.826] (II) modeset(0): Modeline "640x512"x75.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
[ 346.826] (II) modeset(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 346.826] (II) modeset(0): Modeline "700x450"x60.0 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 346.826] (II) modeset(0): Modeline "700x450"x59.9 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 346.826] (II) modeset(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 346.826] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 346.826] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz d)
[ 346.826] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz d)
[ 346.826] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 346.826] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 346.826] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 346.826] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 346.826] (II) modeset(0): Modeline "684x384"x59.9 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 346.826] (II) modeset(0): Modeline "684x384"x59.9 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 346.826] (II) modeset(0): Modeline "640x400"x59.9 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 346.826] (II) modeset(0): Modeline "640x400"x60.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 346.826] (II) modeset(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
[ 346.826] (II) modeset(0): Modeline "640x360"x59.9 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 346.826] (II) modeset(0): Modeline "640x360"x59.8 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 346.826] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 346.826] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 346.826] (II) modeset(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
[ 346.826] (II) modeset(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
[ 346.826] (II) modeset(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 346.826] (II) modeset(0): Modeline "512x288"x60.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 346.826] (II) modeset(0): Modeline "512x288"x59.9 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 346.827] (II) modeset(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
[ 346.827] (II) modeset(0): Modeline "480x270"x59.6 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 346.827] (II) modeset(0): Modeline "480x270"x59.8 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 346.827] (II) modeset(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
[ 346.827] (II) modeset(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
[ 346.827] (II) modeset(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 346.827] (II) modeset(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 346.827] (II) modeset(0): Modeline "432x243"x59.9 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 346.827] (II) modeset(0): Modeline "432x243"x59.6 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 346.827] (II) modeset(0): Modeline "320x240"x72.8 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
[ 346.827] (II) modeset(0): Modeline "320x240"x75.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
[ 346.827] (II) modeset(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 346.827] (II) modeset(0): Modeline "360x202"x59.5 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 346.827] (II) modeset(0): Modeline "360x202"x59.1 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 346.827] (II) modeset(0): Modeline "320x180"x59.8 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 346.827] (II) modeset(0): Modeline "320x180"x59.3 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 346.828] (II) modeset(0): EDID for output HDMI-3
[ 346.828] (II) modeset(0): Output DVI-D-1 disconnected
[ 346.828] (II) modeset(0): Output VGA-2 connected
[ 346.828] (II) modeset(0): Output HDMI-3 disconnected
[ 346.828] (II) modeset(0): Using exact sizes for initial modes
[ 346.828] (II) modeset(0): Output VGA-2 using initial mode 1920x1080 +0+0
[ 346.828] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 346.828] (==) modeset(0): DPI set to (96, 96)
[ 346.828] (II) Loading sub module "fb"
[ 346.828] (II) LoadModule: "fb"
[ 346.828] (II) Module "fb" already built-in
[ 346.828] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 346.828] (==) modeset(G0): RGB weight 888
[ 346.828] (==) modeset(G0): Default visual is TrueColor
[ 346.828] (II) Loading sub module "glamoregl"
[ 346.828] (II) LoadModule: "glamoregl"
[ 346.828] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 346.828] (II) Module glamoregl: vendor="X.Org Foundation"
[ 346.828] compiled for 1.21.1.4, module version = 1.0.1
[ 346.828] ABI class: X.Org ANSI C Emulation, version 0.4
[ 346.832] (II) modeset(G0): glamor X acceleration enabled on Mesa Intel(R) HD Graphics 4600 (HSW GT2)
[ 346.832] (II) modeset(G0): glamor initialized
[ 346.833] (II) modeset(G0): Output VGA-1-1 has no monitor section
[ 346.834] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[ 346.836] (II) modeset(G0): Output HDMI-1-2 has no monitor section
[ 346.837] (II) modeset(G0): EDID for output VGA-1-1
[ 346.838] (II) modeset(G0): EDID for output HDMI-1-1
[ 346.839] (II) modeset(G0): EDID for output HDMI-1-2
[ 346.839] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 346.839] (==) modeset(G0): DPI set to (96, 96)
[ 346.839] (II) Loading sub module "fb"
[ 346.839] (II) LoadModule: "fb"
[ 346.839] (II) Module "fb" already built-in
[ 346.846] (==) modeset(0): Backing store enabled
[ 346.846] (==) modeset(0): Silken mouse enabled
[ 346.846] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 346.846] (==) modeset(0): DPMS enabled
[ 346.846] (II) modeset(0): [DRI2] Setup complete
[ 346.846] (II) modeset(0): [DRI2] DRI driver: nouveau
[ 346.846] (II) modeset(0): [DRI2] VDPAU driver: nouveau
[ 346.851] (==) modeset(G0): Backing store enabled
[ 346.851] (==) modeset(G0): Silken mouse enabled
[ 346.851] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[ 346.851] (==) modeset(G0): DPMS enabled
[ 346.851] (II) modeset(G0): [DRI2] Setup complete
[ 346.851] (II) modeset(G0): [DRI2] DRI driver: crocus
[ 346.851] (II) modeset(G0): [DRI2] VDPAU driver: va_gl
[ 346.851] (II) modeset(G0): Disable reverse prime offload mode for i915.
[ 346.851] (II) Initializing extension Generic Event Extension
[ 346.851] (II) Initializing extension SHAPE
[ 346.851] (II) Initializing extension MIT-SHM
[ 346.852] (II) Initializing extension XInputExtension
[ 346.852] (II) Initializing extension XTEST
[ 346.852] (II) Initializing extension BIG-REQUESTS
[ 346.852] (II) Initializing extension SYNC
[ 346.852] (II) Initializing extension XKEYBOARD
[ 346.852] (II) Initializing extension XC-MISC
[ 346.852] (II) Initializing extension SECURITY
[ 346.852] (II) Initializing extension XFIXES
[ 346.852] (II) Initializing extension RENDER
[ 346.852] (II) Initializing extension RANDR
[ 346.852] (II) Initializing extension COMPOSITE
[ 346.852] (II) Initializing extension DAMAGE
[ 346.852] (II) Initializing extension MIT-SCREEN-SAVER
[ 346.853] (II) Initializing extension DOUBLE-BUFFER
[ 346.853] (II) Initializing extension RECORD
[ 346.853] (II) Initializing extension DPMS
[ 346.853] (II) Initializing extension Present
[ 346.853] (II) Initializing extension DRI3
[ 346.853] (II) Initializing extension X-Resource
[ 346.853] (II) Initializing extension XVideo
[ 346.853] (II) Initializing extension XVideo-MotionCompensation
[ 346.853] (II) Initializing extension GLX
[ 346.856] (II) AIGLX: Loaded and initialized nouveau
[ 346.856] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 346.856] (II) Initializing extension XFree86-VidModeExtension
[ 346.856] (II) Initializing extension XFree86-DGA
[ 346.856] (II) Initializing extension XFree86-DRI
[ 346.856] (II) Initializing extension DRI2
[ 346.856] (II) modeset(G0): Damage tracking initialized
[ 346.856] (II) modeset(0): Damage tracking initialized
[ 346.856] (II) modeset(0): Setting screen physical size to 508 x 285
[ 346.888] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 346.888] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 346.888] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 346.888] (**) Power Button: Applying InputClass "system-keyboard"
[ 346.888] (II) LoadModule: "libinput"
[ 346.888] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 346.890] (II) Module libinput: vendor="X.Org Foundation"
[ 346.890] compiled for 1.21.1.3, module version = 1.2.1
[ 346.890] Module class: X.Org XInput Driver
[ 346.890] ABI class: X.Org XInput driver, version 24.4
[ 346.890] (II) Using input driver 'libinput' for 'Power Button'
[ 346.890] (**) Power Button: always reports core events
[ 346.890] (**) Option "Device" "/dev/input/event1"
[ 346.891] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 346.891] (II) event1 - Power Button: device is a keyboard
[ 346.891] (II) event1 - Power Button: device removed
[ 346.909] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 346.909] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 346.909] (**) Option "xkb_layout" "us"
[ 346.909] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 346.909] (II) event1 - Power Button: device is a keyboard
[ 346.910] (II) config/udev: Adding input device Video Bus (/dev/input/event8)
[ 346.910] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 346.910] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 346.910] (**) Video Bus: Applying InputClass "system-keyboard"
[ 346.910] (II) Using input driver 'libinput' for 'Video Bus'
[ 346.910] (**) Video Bus: always reports core events
[ 346.910] (**) Option "Device" "/dev/input/event8"
[ 346.910] (II) event8 - Video Bus: is tagged by udev as: Keyboard
[ 346.910] (II) event8 - Video Bus: device is a keyboard
[ 346.910] (II) event8 - Video Bus: device removed
[ 346.972] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input9/event8"
[ 346.972] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 346.972] (**) Option "xkb_layout" "us"
[ 346.973] (II) event8 - Video Bus: is tagged by udev as: Keyboard
[ 346.973] (II) event8 - Video Bus: device is a keyboard
[ 346.973] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 346.973] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 346.973] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 346.973] (**) Power Button: Applying InputClass "system-keyboard"
[ 346.973] (II) Using input driver 'libinput' for 'Power Button'
[ 346.973] (**) Power Button: always reports core events
[ 346.973] (**) Option "Device" "/dev/input/event0"
[ 346.974] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 346.974] (II) event0 - Power Button: device is a keyboard
[ 346.974] (II) event0 - Power Button: device removed
[ 347.002] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 347.002] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 347.002] (**) Option "xkb_layout" "us"
[ 347.003] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 347.003] (II) event0 - Power Button: device is a keyboard
[ 347.003] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event14)
[ 347.003] (II) No input driver specified, ignoring this device.
[ 347.003] (II) This device may have been added with another device file.
[ 347.004] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event15)
[ 347.004] (II) No input driver specified, ignoring this device.
[ 347.004] (II) This device may have been added with another device file.
[ 347.004] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event16)
[ 347.004] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event17)
[ 347.005] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event18)
[ 347.005] (II) No input driver specified, ignoring this device.
[ 347.005] (II) This device may have been added with another device file.
[ 347.005] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event9)
[ 347.005] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event10)
[ 347.006] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event11)
[ 347.006] (II) No input driver specified, ignoring this device.
[ 347.006] (II) This device may have been added with another device file.
[ 347.006] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=9 (/dev/input/event12)
[ 347.006] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=10 (/dev/input/event13)
[ 347.007] (II) config/udev: Adding input device SEMICO USB Keyboard (/dev/input/event2)
[ 347.007] (**) SEMICO USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 347.007] (**) SEMICO USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 347.007] (**) SEMICO USB Keyboard: Applying InputClass "system-keyboard"
[ 347.007] (II) Using input driver 'libinput' for 'SEMICO USB Keyboard'
[ 347.007] (**) SEMICO USB Keyboard: always reports core events
[ 347.007] (**) Option "Device" "/dev/input/event2"
[ 347.007] (II) event2 - SEMICO USB Keyboard: is tagged by udev as: Keyboard
[ 347.007] (II) event2 - SEMICO USB Keyboard: device is a keyboard
[ 347.008] (II) event2 - SEMICO USB Keyboard: device removed
[ 347.025] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-7/3-7:1.0/0003:1A2C:45E8.0001/input/input2/event2"
[ 347.025] (II) XINPUT: Adding extended input device "SEMICO USB Keyboard" (type: KEYBOARD, id 9)
[ 347.025] (**) Option "xkb_layout" "us"
[ 347.026] (II) event2 - SEMICO USB Keyboard: is tagged by udev as: Keyboard
[ 347.026] (II) event2 - SEMICO USB Keyboard: device is a keyboard
[ 347.027] (II) config/udev: Adding input device SEMICO USB Keyboard Consumer Control (/dev/input/event3)
[ 347.027] (**) SEMICO USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 347.027] (**) SEMICO USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 347.027] (**) SEMICO USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 347.027] (II) Using input driver 'libinput' for 'SEMICO USB Keyboard Consumer Control'
[ 347.027] (**) SEMICO USB Keyboard Consumer Control: always reports core events
[ 347.027] (**) Option "Device" "/dev/input/event3"
[ 347.028] (II) event3 - SEMICO USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 347.028] (II) event3 - SEMICO USB Keyboard Consumer Control: device is a keyboard
[ 347.028] (II) event3 - SEMICO USB Keyboard Consumer Control: device removed
[ 347.069] (II) libinput: SEMICO USB Keyboard Consumer Control: needs a virtual subdevice
[ 347.069] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-7/3-7:1.1/0003:1A2C:45E8.0002/input/input3/event3"
[ 347.069] (II) XINPUT: Adding extended input device "SEMICO USB Keyboard Consumer Control" (type: MOUSE, id 10)
[ 347.069] (**) Option "AccelerationScheme" "none"
[ 347.069] (**) SEMICO USB Keyboard Consumer Control: (accel) selected scheme none/0
[ 347.069] (**) SEMICO USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 347.069] (**) SEMICO USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[ 347.070] (II) event3 - SEMICO USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 347.071] (II) event3 - SEMICO USB Keyboard Consumer Control: device is a keyboard
[ 347.072] (II) config/udev: Adding input device SEMICO USB Keyboard System Control (/dev/input/event4)
[ 347.072] (**) SEMICO USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 347.072] (**) SEMICO USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 347.072] (**) SEMICO USB Keyboard System Control: Applying InputClass "system-keyboard"
[ 347.072] (II) Using input driver 'libinput' for 'SEMICO USB Keyboard System Control'
[ 347.072] (**) SEMICO USB Keyboard System Control: always reports core events
[ 347.072] (**) Option "Device" "/dev/input/event4"
[ 347.073] (II) event4 - SEMICO USB Keyboard System Control: is tagged by udev as: Keyboard
[ 347.073] (II) event4 - SEMICO USB Keyboard System Control: device is a keyboard
[ 347.073] (II) event4 - SEMICO USB Keyboard System Control: device removed
[ 347.102] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-7/3-7:1.1/0003:1A2C:45E8.0002/input/input4/event4"
[ 347.102] (II) XINPUT: Adding extended input device "SEMICO USB Keyboard System Control" (type: KEYBOARD, id 11)
[ 347.102] (**) Option "xkb_layout" "us"
[ 347.103] (II) event4 - SEMICO USB Keyboard System Control: is tagged by udev as: Keyboard
[ 347.103] (II) event4 - SEMICO USB Keyboard System Control: device is a keyboard
[ 347.104] (II) config/udev: Adding input device SEMICO USB Keyboard (/dev/input/event5)
[ 347.104] (**) SEMICO USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 347.104] (**) SEMICO USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 347.104] (**) SEMICO USB Keyboard: Applying InputClass "system-keyboard"
[ 347.104] (II) Using input driver 'libinput' for 'SEMICO USB Keyboard'
[ 347.104] (**) SEMICO USB Keyboard: always reports core events
[ 347.104] (**) Option "Device" "/dev/input/event5"
[ 347.104] (II) event5 - SEMICO USB Keyboard: is tagged by udev as: Keyboard
[ 347.105] (II) event5 - SEMICO USB Keyboard: device is a keyboard
[ 347.105] (II) event5 - SEMICO USB Keyboard: device removed
[ 347.133] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-7/3-7:1.1/0003:1A2C:45E8.0002/input/input6/event5"
[ 347.133] (II) XINPUT: Adding extended input device "SEMICO USB Keyboard" (type: KEYBOARD, id 12)
[ 347.133] (**) Option "xkb_layout" "us"
[ 347.136] (II) event5 - SEMICO USB Keyboard: is tagged by udev as: Keyboard
[ 347.136] (II) event5 - SEMICO USB Keyboard: device is a keyboard
[ 347.138] (II) config/udev: Adding input device PixArt Lenovo USB Optical Mouse (/dev/input/event6)
[ 347.138] (**) PixArt Lenovo USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[ 347.138] (**) PixArt Lenovo USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[ 347.138] (II) Using input driver 'libinput' for 'PixArt Lenovo USB Optical Mouse'
[ 347.138] (**) PixArt Lenovo USB Optical Mouse: always reports core events
[ 347.138] (**) Option "Device" "/dev/input/event6"
[ 347.140] (II) event6 - PixArt Lenovo USB Optical Mouse: is tagged by udev as: Mouse
[ 347.140] (II) event6 - PixArt Lenovo USB Optical Mouse: device is a pointer
[ 347.141] (II) event6 - PixArt Lenovo USB Optical Mouse: device removed
[ 347.215] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-8/3-8:1.0/0003:17EF:608D.0003/input/input7/event6"
[ 347.215] (II) XINPUT: Adding extended input device "PixArt Lenovo USB Optical Mouse" (type: MOUSE, id 13)
[ 347.216] (**) Option "AccelerationScheme" "none"
[ 347.216] (**) PixArt Lenovo USB Optical Mouse: (accel) selected scheme none/0
[ 347.216] (**) PixArt Lenovo USB Optical Mouse: (accel) acceleration factor: 2.000
[ 347.216] (**) PixArt Lenovo USB Optical Mouse: (accel) acceleration threshold: 4
[ 347.218] (II) event6 - PixArt Lenovo USB Optical Mouse: is tagged by udev as: Mouse
[ 347.218] (II) event6 - PixArt Lenovo USB Optical Mouse: device is a pointer
[ 347.219] (II) config/udev: Adding input device PixArt Lenovo USB Optical Mouse (/dev/input/mouse0)
[ 347.219] (II) No input driver specified, ignoring this device.
[ 347.219] (II) This device may have been added with another device file.
[ 347.219] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event19)
[ 347.220] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event20)
[ 347.220] (II) No input driver specified, ignoring this device.
[ 347.220] (II) This device may have been added with another device file.
[ 347.220] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event21)
[ 347.220] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event22)
[ 347.220] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event23)
[ 347.221] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event24)
[ 347.221] (II) No input driver specified, ignoring this device.
[ 347.221] (II) This device may have been added with another device file.
[ 347.221] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event25)
[ 347.221] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event26)
[ 347.221] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[ 347.225] (**) SEMICO USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 347.225] (**) SEMICO USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 347.225] (**) SEMICO USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 347.225] (II) Using input driver 'libinput' for 'SEMICO USB Keyboard Consumer Control'
[ 347.225] (**) SEMICO USB Keyboard Consumer Control: always reports core events
[ 347.225] (**) Option "Device" "/dev/input/event3"
[ 347.225] (II) libinput: SEMICO USB Keyboard Consumer Control: is a virtual subdevice
[ 347.225] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-7/3-7:1.1/0003:1A2C:45E8.0002/input/input3/event3"
[ 347.225] (II) XINPUT: Adding extended input device "SEMICO USB Keyboard Consumer Control" (type: KEYBOARD, id 14)
[ 347.226] (**) Option "xkb_layout" "us"
[ 355.899] (II) event1 - Power Button: device removed
[ 355.922] (II) event8 - Video Bus: device removed
[ 355.972] (II) event0 - Power Button: device removed
[ 356.002] (II) event2 - SEMICO USB Keyboard: device removed
[ 356.025] (II) event4 - SEMICO USB Keyboard System Control: device removed
[ 356.055] (II) event5 - SEMICO USB Keyboard: device removed
[ 356.078] (II) event6 - PixArt Lenovo USB Optical Mouse: device removed
[ 356.134] (II) event3 - SEMICO USB Keyboard Consumer Control: device removed
[ 356.162] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 510.644] (II) UnloadModule: "libinput"
[ 510.645] (II) UnloadModule: "libinput"
[ 510.646] (II) Server terminated successfully (0). Closing log file.
