Since yesterday evening, my graphical environment won’t start any more.
After boot, I get a 'starting version 249.7-2 Manjaro ’ prompt - then a black screen.
I can however with ctrl-alt-Fx start a console window, and there everything seems to be running (I see e.g. a /usr/lib/Xorg process running), but on the console where the graphical environment should be running I only have a black screen. In fact, my monitor starts searching for an input signal.
Now I have on this computer 3 partitions - 2 Manjaro, 1 Windows. And I have a bootable USB stick. ALL of them either present a black screen, or garbage. Which of course suggests that I’m dealing with a hardware problem.
Looking at the Xorg.0.log file, the ‘No enabled display devices found’ message sounds like my video card doesn’t detect that a monitor is attached - even while I’m reading that file on that monitor.
But before running to a store and spending a nice sum of money, what can I do to find out (or better yet, fix …)
Kernel: 5.4.163-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.4-x86_64
root=UUID=a6ebafb1-07e8-4428-9882-31eb3ef08aaa rw rootflags=subvol=@ quiet
resume=UUID=2e1a1768-0662-43e6-8062-020efb1303de
Console: tty 3 DM: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B450-A PRO (MS-7B86) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.00
date: 06/26/2018
RAM: total: 15.65 GiB used: 1.35 GiB (8.6%)
Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache:
L1: 576 KiB L2: 3 MiB L3: 16 MiB bogomips: 81616
Speed: 3643 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz):
1: 3643 2: 3647 3: 3647 4: 3647 5: 3649 6: 3649 7: 3621 8: 3624 9: 3641
10: 3474 11: 3649 12: 3649
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: NVIDIA GK106 [GeForce GTX 650 Ti] vendor: Micro-Star MSI
driver: nvidia v: 470.86 alternate: nouveau,nvidia_drm bus-ID: 1c:00.0
chip-ID: 10de:11c6 class-ID: 0300
Device-2: MacroSilicon MS210x Video Grabber [EasierCAP] type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 3-2:2
chip-ID: 534d:0021 class-ID: 0300 serial: <filter>
Display: server: X.org 1.21.1.1 driver: loaded: nvidia tty: 100x37
Device-1: NVIDIA GK106 HDMI Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 1c:00.1 chip-ID: 10de:0e0b
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 1e:00.3 chip-ID: 1022:1457
class-ID: 0403
Device-3: MacroSilicon MS210x Video Grabber [EasierCAP] type: USB
Sound Server-1: ALSA v: k5.4.163-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.40 running: no
vendor: Micro-Star MSI driver: r8168 v: 8.049.02-NAPI modules: r8169
port: f000 bus-ID: 18:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp24s0 state: up speed: 100 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-1:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 6.71 TiB used: 1.94 TiB (28.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB256HAHQ-000H1
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: EXD70H1Q scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2BW120H6
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: RG20 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD40EZRZ-00GXCB0
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 0A80 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD30EZRX-00D8PB0
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
ID-5: /dev/sdh maj-min: 8:112 type: USB model: USB 2.0 Flash Drive
size: 3.75 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 8.07 scheme: MBR
Optical-1: /dev/sr0 vendor: ASUS model: DRW-24F1MT rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 51.88 GiB size: 51.88 GiB (100.00%)
used: 41.98 GiB (80.9%) fs: btrfs dev: /dev/sda8 maj-min: 8:8 label: N/A
uuid: a6ebafb1-07e8-4428-9882-31eb3ef08aaa
used: 26.5 MiB (27.6%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 7E1B-369F
ID-3: /data raw-size: 1.9 TiB size: 1.87 TiB (98.38%) used: 1.67 TiB (89.5%)
fs: ext3 dev: /dev/sdb7 maj-min: 8:23 label: data
uuid: 1c7733ad-ec3a-40c3-af7a-eee84584eb21
ID-4: /home raw-size: 350 GiB size: 343.51 GiB (98.15%)
used: 235.47 GiB (68.5%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: home
uuid: 6d91f22d-267a-4f2f-b63d-45d74512fc84
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: 2e1a1768-0662-43e6-8062-020efb1303de
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 360 MiB fs: vfat label: SYSTEM
uuid: 74C2-82B8
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 213.87 GiB fs: ntfs label: Windows
uuid: 587239CA7239AD9E
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1.67 GiB fs: ntfs
label: Windows RE tools uuid: 0ED2A5ADD2A59A0B
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 22.46 GiB fs: ntfs
label: Recovery Image uuid: C4B661E9B661DC84
ID-6: /dev/sda1 maj-min: 8:1 size: 499 MiB fs: ntfs label: Herstel
uuid: 583C19913C196B70
ID-7: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
ID-8: /dev/sda4 maj-min: 8:4 size: 56.38 GiB fs: ntfs label: N/A
uuid: 6E5E37D75E3796B5
ID-9: /dev/sda5 maj-min: 8:5 size: 831 MiB fs: ntfs label: N/A
uuid: 9C6A683B6A681474
ID-10: /dev/sda6 maj-min: 8:6 size: 128 MiB fs: vfat label: N/A
uuid: 27CD-4979
ID-11: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
ID-12: /dev/sdb2 maj-min: 8:18 size: 400 GiB fs: ntfs label: windows10
uuid: 55E541253C30B424
ID-13: /dev/sdb4 maj-min: 8:20 size: 200 GiB fs: ntfs label: oldwindows
uuid: 753C490A14619367
ID-14: /dev/sdb5 maj-min: 8:21 size: 100 GiB fs: ext4 label: N/A
uuid: c7dd8b5c-8b9a-418b-954d-5eb607982410
ID-15: /dev/sdb6 maj-min: 8:22 size: 733.4 GiB fs: ext3 label: N/A
uuid: 71af6a92-20c7-472d-a057-c2dc57143299
ID-16: /dev/sdc1 maj-min: 8:33 size: 97.65 GiB fs: ext4 label: N/A
uuid: 7e29a87b-e017-4567-a259-a6c363f4381f
ID-17: /dev/sdc2 maj-min: 8:34 size: 1 TiB fs: ext4 label: video
uuid: 57b7cea1-3592-46db-911a-bb2d87195547
ID-18: /dev/sdc3 maj-min: 8:35 size: 1.34 TiB fs: ext4 label: data
uuid: e3dd6bfe-0b14-43db-b1df-a0656e5534e0
ID-19: /dev/sdc5 maj-min: 8:37 size: 292.97 GiB fs: ext4 label: home
uuid: e3c2b65a-e093-447a-a529-43cc116807bf
ID-20: /dev/sdh1 maj-min: 8:113 size: 3.75 GiB fs: vfat label: NEW VOLUME
uuid: 6878-0E06
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-1:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
Device-2: 1-2:3 info: VASCO Data Security Digipass 905 SmartCard Reader
type: Smart Card driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 50mA chip-ID: 1a44:0001 class-ID: 0b00
Device-3: 1-6:4 info: Alcor Micro AU6477 Card Reader Controller
type: Mass Storage,HID driver: hid-generic,usb-storage,usbhid interfaces: 2
rev: 2.0 speed: 480 Mb/s power: 250mA chip-ID: 058f:6364 class-ID: 0300
serial: <filter>
Device-4: 1-8:5 info: Primax HP PR1101U / Primax PMX-KPR1101U Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 0461:0010 class-ID: 0300
Device-5: 1-9:6 info: Sunplus Innovation Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 98mA chip-ID: 1bcf:0007 class-ID: 0301
Device-6: 1-10:7 info: Alcor Micro Flash Drive type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 058f:6387 class-ID: 0806 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: MacroSilicon MS210x Video Grabber [EasierCAP]
type: Video,Audio,HID driver: hid-generic,snd-usb-audio,usbhid,uvcvideo
interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 534d:0021
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 85.5 C mobo: N/A
Processes: 296 Uptime: 1m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1784 lib: 468 flatpak: 0
Shell: Bash (login) v: 5.1.12 running-in: tty 3 inxi: 3.3.09
[ 7.276] (--) Log file renamed from "/var/log/Xorg.pid-1340.log" to "/var/log/Xorg.0.log"
[ 7.308]
This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at http://bugs.freedesktop.org/.
Select the "xorg" product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See http://wiki.x.org/wiki/GitPage for git access instructions.
[ 7.308]
X.Org X Server 1.21.1.1
[ 7.308] Current Operating System: Linux zeus 5.4.163-1-MANJARO #1 SMP PREEMPT Wed Dec 1 14:47:09 UTC 2021 x86_64
[ 7.308] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.4-x86_64 root=UUID=a6ebafb1-07e8-4428-9882-31eb3ef08aaa rw rootflags=subvol=@ quiet resume=UUID=2e1a1768-0662-43e6-8062-020efb1303de
[ 7.308]
[ 7.308] Current version of pixman: 0.40.0
[ 7.308] Before reporting problems, check http://wiki.x.org
[ 7.308] Markers: (--) probed, (**) from config file, (==) default setting,
[ 7.308] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Dec 16 14:02:23 2021
[ 7.310] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 7.310] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 7.310] (==) ServerLayout "layout"
[ 7.310] (**) |-->Screen "Screen0" (0)
[ 7.310] (**) | |-->Monitor "Monitor0"
[ 7.311] (**) | |-->Device "Device0"
[ 7.311] (==) Automatically adding devices
[ 7.311] (==) Automatically enabling devices
[ 7.311] (==) Automatically adding GPU devices
[ 7.311] (==) Automatically binding GPU devices
[ 7.311] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 7.312] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 7.312] Entry deleted from font path.
[ 7.312] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 7.312] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[ 7.312] (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[ 7.312] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[ 7.312] (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[ 7.312] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 7.312] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 7.312] (**) Extension "COMPOSITE" is enabled
[ 7.312] (II) The server relies on udev to provide the list of input devices.
[ 7.313] (II) Module ABI versions:
[ 7.313] X.Org ANSI C Emulation: 0.4
[ 7.313] X.Org Video Driver: 25.2
[ 7.313] X.Org XInput driver : 24.4
[ 7.313] X.Org Server Extension : 10.0
[ 7.314] (++) using VT number 1
[ 7.314] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 7.314] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 7.314] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:1c:00.0/drm/card0
[ 7.316] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 7.316] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 7.317] (--) PCI:*(28@0:0:0) 10de:11c6:1462:2805 rev 161, Mem @ 0xf6000000/16777216, 0xe8000000/134217728, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 7.317] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 7.317] (II) LoadModule: "glx"
[ 7.318] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 7.325] (II) Module glx: vendor="X.Org Foundation"
[ 7.325] compiled for 1.21.1.1, module version = 1.0.0
[ 7.325] ABI class: X.Org Server Extension, version 10.0
[ 7.325] (II) LoadModule: "nvidia"
[ 7.325] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 7.337] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 7.337] compiled for 1.6.99.901, module version = 1.0.0
[ 7.337] Module class: X.Org Video Driver
[ 7.337] (II) NVIDIA dlloader X Driver 470.86 Tue Oct 26 21:53:29 UTC 2021
[ 7.337] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 7.337] (II) Loading sub module "fb"
[ 7.337] (II) LoadModule: "fb"
[ 7.337] (II) Module "fb" already built-in
[ 7.337] (II) Loading sub module "wfb"
[ 7.337] (II) LoadModule: "wfb"
[ 7.342] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 7.343] (II) Module wfb: vendor="X.Org Foundation"
[ 7.343] compiled for 1.21.1.1, module version = 1.0.0
[ 7.343] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.343] (II) Loading sub module "ramdac"
[ 7.343] (II) LoadModule: "ramdac"
[ 7.343] (II) Module "ramdac" already built-in
[ 7.344] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 7.344] (==) NVIDIA(0): RGB weight 888
[ 7.344] (==) NVIDIA(0): Default visual is TrueColor
[ 7.344] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 7.344] (**) Option "AllowNVIDIAGpuScreens"
[ 7.344] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 7.344] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 7.344] (**) NVIDIA(0): Enabling 2D acceleration
[ 7.344] (II) Loading sub module "glxserver_nvidia"
[ 7.344] (II) LoadModule: "glxserver_nvidia"
[ 7.344] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 7.443] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 7.443] compiled for 1.6.99.901, module version = 1.0.0
[ 7.443] Module class: X.Org Server Extension
[ 7.443] (II) NVIDIA GLX Module 470.86 Tue Oct 26 21:51:04 UTC 2021
[ 7.443] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 9.475] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:28:0:0
[ 9.475] (--) NVIDIA(0): CRT-0
[ 9.475] (--) NVIDIA(0): DFP-0 (boot)
[ 9.475] (--) NVIDIA(0): DFP-1
[ 9.475] (--) NVIDIA(0): DFP-2
[ 9.476] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce GTX 650 Ti (GK106) at PCI:28:0:0
[ 9.476] (II) NVIDIA(0): (GPU-0)
[ 9.476] (--) NVIDIA(0): Memory: 1048576 kBytes
[ 9.476] (--) NVIDIA(0): VideoBIOS: 80.06.21.00.37
[ 9.476] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 9.480] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 9.480] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 9.483] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 9.483] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 9.483] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 9.483] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 9.483] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 9.483] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 9.483] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 9.483] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 9.483] (--) NVIDIA(GPU-0): DFP-2: 330.0 MHz maximum pixel clock
[ 9.483] (==) NVIDIA(0):
[ 9.483] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 9.484] (==) NVIDIA(0): will be used as the requested mode.
[ 9.484] (--) NVIDIA(0): No enabled display devices found; starting anyway because
[ 9.484] (--) NVIDIA(0): AllowEmptyInitialConfiguration is enabled
[ 9.484] (II) NVIDIA(0): Validated MetaModes:
[ 9.484] (II) NVIDIA(0): "NULL"
[ 9.484] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 9.484] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 9.484] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 9.484] (II) NVIDIA: Reserving 6144.00 MB of virtual memory for indirect memory
[ 9.484] (II) NVIDIA: access.
[ 9.486] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 9.486] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 9.486] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 9.486] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 9.486] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 9.486] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 9.486] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 9.486] (II) NVIDIA(0): Config Options in the README.
[ 9.502] (II) NVIDIA(0): Setting mode "NULL"
[ 9.530] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 9.530] (==) NVIDIA(0): Backing store enabled
[ 9.530] (==) NVIDIA(0): Silken mouse enabled
[ 9.530] (**) NVIDIA(0): DPMS enabled
[ 9.530] (WW) NVIDIA(0): Option "NoLogo" is not used
[ 9.530] (II) Loading sub module "dri2"
[ 9.530] (II) LoadModule: "dri2"
[ 9.530] (II) Module "dri2" already built-in
[ 9.530] (II) NVIDIA(0): [DRI2] Setup complete
[ 9.530] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 9.530] (II) Initializing extension Generic Event Extension
[ 9.530] (II) Initializing extension SHAPE
[ 9.530] (II) Initializing extension MIT-SHM
[ 9.530] (II) Initializing extension XInputExtension
[ 9.530] (II) Initializing extension XTEST
[ 9.530] (II) Initializing extension BIG-REQUESTS
[ 9.530] (II) Initializing extension SYNC
[ 9.530] (II) Initializing extension XKEYBOARD
[ 9.530] (II) Initializing extension XC-MISC
[ 9.530] (II) Initializing extension SECURITY
[ 9.531] (II) Initializing extension XFIXES
[ 9.531] (II) Initializing extension RENDER
[ 9.531] (II) Initializing extension RANDR
[ 9.531] (II) Initializing extension COMPOSITE
[ 9.531] (II) Initializing extension DAMAGE
[ 9.531] (II) Initializing extension MIT-SCREEN-SAVER
[ 9.531] (II) Initializing extension DOUBLE-BUFFER
[ 9.531] (II) Initializing extension RECORD
[ 9.531] (II) Initializing extension DPMS
[ 9.531] (II) Initializing extension Present
[ 9.531] (II) Initializing extension DRI3
[ 9.531] (II) Initializing extension X-Resource
[ 9.531] (II) Initializing extension XVideo
[ 9.531] (II) Initializing extension XVideo-MotionCompensation
[ 9.531] (II) Initializing extension GLX
[ 9.532] (II) Initializing extension GLX
[ 9.532] (II) Indirect GLX disabled.
[ 9.532] (II) GLX: Another vendor is already registered for screen 0
[ 9.532] (II) Initializing extension XFree86-VidModeExtension
[ 9.532] (II) Initializing extension XFree86-DGA
[ 9.532] (II) Initializing extension XFree86-DRI
[ 9.532] (II) Initializing extension DRI2
[ 9.532] (II) Initializing extension NV-GLX
[ 9.532] (II) Initializing extension NV-CONTROL
[ 9.578] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 9.578] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 9.578] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 9.578] (**) Power Button: Applying InputClass "system-keyboard"
[ 9.578] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 9.578] (II) LoadModule: "libinput"
[ 9.578] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 9.583] (II) Module libinput: vendor="X.Org Foundation"
[ 9.583] compiled for 1.21.1, module version = 1.2.0
[ 9.583] Module class: X.Org XInput Driver
[ 9.583] ABI class: X.Org XInput driver, version 24.4
[ 9.583] (II) Using input driver 'libinput' for 'Power Button'
[ 9.583] (**) Power Button: always reports core events
[ 9.584] (**) Option "Device" "/dev/input/event1"
[ 9.584] (**) Option "_source" "server/udev"
[ 9.587] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 9.587] (II) event1 - Power Button: device is a keyboard
[ 9.587] (II) event1 - Power Button: device removed
[ 9.610] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 9.610] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 9.610] (**) Option "xkb_model" "pc105"
[ 9.610] (**) Option "xkb_layout" "be"
[ 9.610] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 9.632] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 9.632] (II) event1 - Power Button: device is a keyboard
[ 9.633] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 9.634] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 9.634] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 9.634] (**) Power Button: Applying InputClass "system-keyboard"
[ 9.634] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 9.634] (II) Using input driver 'libinput' for 'Power Button'
[ 9.634] (**) Power Button: always reports core events
[ 9.634] (**) Option "Device" "/dev/input/event0"
[ 9.634] (**) Option "_source" "server/udev"
[ 9.635] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 9.635] (II) event0 - Power Button: device is a keyboard
[ 9.635] (II) event0 - Power Button: device removed
[ 9.676] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 9.676] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 9.676] (**) Option "xkb_model" "pc105"
[ 9.676] (**) Option "xkb_layout" "be"
[ 9.676] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 9.678] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 9.678] (II) event0 - Power Button: device is a keyboard
[ 9.679] (II) config/udev: Adding input device NOVATEK USB Keyboard (/dev/input/event2)
[ 9.679] (**) NOVATEK USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 9.679] (**) NOVATEK USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 9.679] (**) NOVATEK USB Keyboard: Applying InputClass "system-keyboard"
[ 9.679] (**) NOVATEK USB Keyboard: Applying InputClass "Keyboard Defaults"
[ 9.679] (II) Using input driver 'libinput' for 'NOVATEK USB Keyboard'
[ 9.679] (**) NOVATEK USB Keyboard: always reports core events
[ 9.679] (**) Option "Device" "/dev/input/event2"
[ 9.679] (**) Option "_source" "server/udev"
[ 9.682] (II) event2 - NOVATEK USB Keyboard: is tagged by udev as: Keyboard
[ 9.682] (II) event2 - NOVATEK USB Keyboard: device is a keyboard
[ 9.682] (II) event2 - NOVATEK USB Keyboard: device removed
[ 9.716] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-8/1-8:1.0/0003:0461:0010.0003/input/input2/event2"
[ 9.716] (II) XINPUT: Adding extended input device "NOVATEK USB Keyboard" (type: KEYBOARD, id 8)
[ 9.716] (**) Option "xkb_model" "pc105"
[ 9.716] (**) Option "xkb_layout" "be"
[ 9.716] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 9.719] (II) event2 - NOVATEK USB Keyboard: is tagged by udev as: Keyboard
[ 9.719] (II) event2 - NOVATEK USB Keyboard: device is a keyboard
[ 9.720] (II) config/udev: Adding input device NOVATEK USB Keyboard System Control (/dev/input/event3)
[ 9.720] (**) NOVATEK USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 9.720] (**) NOVATEK USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 9.721] (**) NOVATEK USB Keyboard System Control: Applying InputClass "system-keyboard"
[ 9.721] (**) NOVATEK USB Keyboard System Control: Applying InputClass "Keyboard Defaults"
[ 9.721] (II) Using input driver 'libinput' for 'NOVATEK USB Keyboard System Control'
[ 9.721] (**) NOVATEK USB Keyboard System Control: always reports core events
[ 9.721] (**) Option "Device" "/dev/input/event3"
[ 9.721] (**) Option "_source" "server/udev"
[ 9.723] (II) event3 - NOVATEK USB Keyboard System Control: is tagged by udev as: Keyboard
[ 9.723] (II) event3 - NOVATEK USB Keyboard System Control: device is a keyboard
[ 9.723] (II) event3 - NOVATEK USB Keyboard System Control: device removed
[ 9.756] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-8/1-8:1.1/0003:0461:0010.0004/input/input3/event3"
[ 9.756] (II) XINPUT: Adding extended input device "NOVATEK USB Keyboard System Control" (type: KEYBOARD, id 9)
[ 9.756] (**) Option "xkb_model" "pc105"
[ 9.756] (**) Option "xkb_layout" "be"
[ 9.756] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 9.759] (II) event3 - NOVATEK USB Keyboard System Control: is tagged by udev as: Keyboard
[ 9.759] (II) event3 - NOVATEK USB Keyboard System Control: device is a keyboard
[ 9.760] (II) config/udev: Adding input device NOVATEK USB Keyboard Consumer Control (/dev/input/event4)
[ 9.760] (**) NOVATEK USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 9.760] (**) NOVATEK USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 9.760] (**) NOVATEK USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 9.760] (**) NOVATEK USB Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[ 9.760] (II) Using input driver 'libinput' for 'NOVATEK USB Keyboard Consumer Control'
[ 9.760] (**) NOVATEK USB Keyboard Consumer Control: always reports core events
[ 9.760] (**) Option "Device" "/dev/input/event4"
[ 9.760] (**) Option "_source" "server/udev"
[ 9.762] (II) event4 - NOVATEK USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 9.763] (II) event4 - NOVATEK USB Keyboard Consumer Control: device is a keyboard
[ 9.763] (II) event4 - NOVATEK USB Keyboard Consumer Control: device removed
[ 9.823] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-8/1-8:1.1/0003:0461:0010.0004/input/input4/event4"
[ 9.823] (II) XINPUT: Adding extended input device "NOVATEK USB Keyboard Consumer Control" (type: KEYBOARD, id 10)
[ 9.823] (**) Option "xkb_model" "pc105"
[ 9.823] (**) Option "xkb_layout" "be"
[ 9.823] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 9.825] (II) event4 - NOVATEK USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 9.825] (II) event4 - NOVATEK USB Keyboard Consumer Control: device is a keyboard
[ 9.827] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/event5)
[ 9.827] (**) USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[ 9.827] (**) USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[ 9.827] (II) Using input driver 'libinput' for 'USB Optical Mouse'
[ 9.827] (**) USB Optical Mouse: always reports core events
[ 9.827] (**) Option "Device" "/dev/input/event5"
[ 9.827] (**) Option "_source" "server/udev"
[ 9.885] (II) event5 - USB Optical Mouse: is tagged by udev as: Mouse
[ 9.885] (II) event5 - USB Optical Mouse: device is a pointer
[ 9.885] (II) event5 - USB Optical Mouse: device removed
[ 9.943] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-9/1-9:1.0/0003:1BCF:0007.0005/input/input5/event5"
[ 9.943] (II) XINPUT: Adding extended input device "USB Optical Mouse" (type: MOUSE, id 11)
[ 9.943] (**) Option "AccelerationScheme" "none"
[ 9.943] (**) USB Optical Mouse: (accel) selected scheme none/0
[ 9.943] (**) USB Optical Mouse: (accel) acceleration factor: 2.000
[ 9.943] (**) USB Optical Mouse: (accel) acceleration threshold: 4
[ 10.002] (II) event5 - USB Optical Mouse: is tagged by udev as: Mouse
[ 10.002] (II) event5 - USB Optical Mouse: device is a pointer
[ 10.004] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/mouse0)
[ 10.004] (II) No input driver specified, ignoring this device.
[ 10.004] (II) This device may have been added with another device file.
[ 10.005] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/event6)
[ 10.005] (II) No input driver specified, ignoring this device.
[ 10.005] (II) This device may have been added with another device file.
[ 10.006] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event16)
[ 10.006] (II) No input driver specified, ignoring this device.
[ 10.006] (II) This device may have been added with another device file.
[ 10.006] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event17)
[ 10.007] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event18)
[ 10.007] (II) No input driver specified, ignoring this device.
[ 10.007] (II) This device may have been added with another device file.
[ 10.007] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event19)
[ 10.008] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event10)
[ 10.008] (II) No input driver specified, ignoring this device.
[ 10.008] (II) This device may have been added with another device file.
[ 10.009] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event11)
[ 10.009] (II) No input driver specified, ignoring this device.
[ 10.009] (II) This device may have been added with another device file.
[ 10.009] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event12)
[ 10.010] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event13)
[ 10.010] (II) No input driver specified, ignoring this device.
[ 10.010] (II) This device may have been added with another device file.
[ 10.010] (II) config/udev: Adding input device HD-Audio Generic Line Out Side (/dev/input/event14)
[ 10.011] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event15)
[ 10.011] (II) No input driver specified, ignoring this device.
[ 10.011] (II) This device may have been added with another device file.
[ 10.011] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event8)
[ 10.012] (II) No input driver specified, ignoring this device.
[ 10.012] (II) This device may have been added with another device file.
[ 10.012] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event9)
[ 10.013] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[ 10.013] (II) No input driver specified, ignoring this device.
[ 10.013] (II) This device may have been added with another device file.
[ 37.041] (II) event1 - Power Button: device removed
[ 37.070] (II) event0 - Power Button: device removed
[ 37.110] (II) event2 - NOVATEK USB Keyboard: device removed
[ 37.148] (II) event3 - NOVATEK USB Keyboard System Control: device removed
[ 37.195] (II) event4 - NOVATEK USB Keyboard Consumer Control: device removed
[ 37.259] (II) event5 - USB Optical Mouse: device removed
