sudo dmesg | egrep -i '(snd|sound|sof|alsa|hda)'
returns
[ 0.582271] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.772196] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.772197] software IO TLB: mapped [mem 0xb798b000-0xbb98b000] (64MB)
[ 4.518582] snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
[ 4.518970] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 4.519030] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 4.519038] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 4.698938] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC898: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[ 4.698942] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.698944] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 4.698945] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 4.698947] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x11/0x1e
[ 4.698948] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 4.698951] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 4.698953] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 4.698955] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 4.699000] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input10
[ 4.699078] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input11
[ 4.699150] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input12
[ 4.699226] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input13
[ 4.699297] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input14
[ 4.699366] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input15
[ 4.699438] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input16
[ 4.772155] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input17
[ 4.772199] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input18
[ 4.772237] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input19
[ 4.772274] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input20
[ 4.772315] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input21
[ 4.772350] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input22
[ 4.772391] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input23
pa-info gives this (3000 lines, surely worth grepping?)
________________
> pulseaudio_ps_do
root 15836 0.0 0.0 3144 780 pts/0 S+ 20:09 0:00 grep pulseaudio
________________
> which pulseaudio
/usr/bin/pulseaudio
________________
> pidof pulseaudio
________________
> pulseaudio --version
pulseaudio 14.0-13-g00bd8
________________
> pactl info
________________
> pactl list
________________
> cat /etc/pulse/daemon.conf
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out. Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; remixing-produce-lfe = no
; remixing-consume-lfe = no
; lfe-crossover-freq = 0
flat-volumes = no
; flat-volumes = no
; rescue-streams = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
________________
> cat /etc/pulse/client.conf
## Configuration file for PulseAudio clients. See pulse-client.conf(5) for
## commenting.
; default-sink =
; default-source =
; default-server =
; default-dbus-server =
autospawn = no
; autospawn = yes
; daemon-binary = /usr/bin/pulseaudio
; extra-arguments = --log-target=syslog
; cookie-file =
; enable-shm = yes
; auto-connect-localhost = no
; auto-connect-display = no
________________
> cat /etc/pulse/default.pa
#!/usr/bin/pulseaudio -nF
# PulseAudio is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# This startup script is used only if PulseAudio is started per-user
# (i.e. not in system mode)
.fail
### Automatically restore the volume of streams and devices
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
### Automatically augment property information from .desktop files
### stored in /usr/share/application
load-module module-augment-properties
### Should be after module-*-restore but before module-*-detect
load-module module-switch-on-port-available
### Load audio drivers statically
### (it's probably better to not load these drivers manually, but instead
### use module-udev-detect -- see below -- for doing this automatically)
#load-module module-alsa-sink
#load-module module-alsa-source device=hw:1,0
#load-module module-oss device="/dev/dsp" sink_name=output source_name=input
#load-module module-oss-mmap device="/dev/dsp" sink_name=output source_name=input
#load-module module-null-sink
#load-module module-pipe-sink
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
### Automatically connect sink and source if JACK server is present
.ifexists module-jackdbus-detect.so
.nofail
load-module module-jackdbus-detect channels=2
.fail
.endif
### Automatically load driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
.endif
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
.endif
### Load several protocols
load-module module-dbus-protocol
.ifexists module-esound-protocol-unix.so
load-module module-esound-protocol-unix
.endif
load-module module-native-protocol-unix
### Network access (may be configured with paprefs, so leave this commented
### here if you plan to use paprefs)
#load-module module-esound-protocol-tcp
#load-module module-native-protocol-tcp
#load-module module-zeroconf-publish
### Load the RTP receiver module (also configured via paprefs, see above)
#load-module module-rtp-recv
### Load the RTP sender module (also configured via paprefs, see above)
#load-module module-null-sink sink_name=rtp format=s16be channels=2 rate=44100 sink_properties="device.description='RTP Multicast Sink'"
#load-module module-rtp-send source=rtp.monitor
### Load additional modules from GSettings. This can be configured with the paprefs tool.
### Please keep in mind that the modules configured by paprefs might conflict with manually
### loaded modules.
.ifexists module-gsettings.so
.nofail
load-module module-gsettings
.fail
.endif
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
load-module module-default-device-restore
### Make sure we always have a sink around, even if it is a null sink.
load-module module-always-sink
### Honour intended role device property
load-module module-intended-roles
### Automatically suspend sinks/sources that become idle for too long
load-module module-suspend-on-idle
### If autoexit on idle is enabled we want to make sure we only quit
### when no local session needs us anymore.
.ifexists module-console-kit.so
load-module module-console-kit
.endif
.ifexists module-systemd-login.so
load-module module-systemd-login
.endif
### Enable positioned event sounds
load-module module-position-event-sounds
### Cork music/video streams when a phone stream is active
load-module module-role-cork
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
#set-default-sink output
#set-default-source input
### Allow including a default.pa.d directory, which if present, can be used
### for additional configuration snippets.
.nofail
.include /etc/pulse/default.pa.d
________________
> cat /etc/pulse/system.pa
# This startup script is used only if PulseAudio is started in system
# mode.
.else
### Use the static hardware detection module (for systems that lack udev/hal support)
.endif
.endif
### during runtime
### Allow including a system.pa.d directory, which if present, can be used
.nofail
.include /etc/pulse/system.pa.d
________________
> ls -alt /dev/snd/*
crw-rw----+ 1 root audio 116, 11 Nov 25 20:09 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116, 16 Nov 25 19:51 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 15 Nov 25 19:51 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 12 Nov 25 19:51 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116, 13 Nov 25 19:51 /dev/snd/pcmC0D1p
crw-rw----+ 1 root audio 116, 14 Nov 25 19:51 /dev/snd/pcmC0D2c
crw-rw----+ 1 root audio 116, 10 Nov 25 19:51 /dev/snd/controlC1
crw-rw----+ 1 root audio 116, 9 Nov 25 19:51 /dev/snd/hwC1D0
crw-rw----+ 1 root audio 116, 6 Nov 25 19:51 /dev/snd/pcmC1D10p
crw-rw----+ 1 root audio 116, 7 Nov 25 19:51 /dev/snd/pcmC1D11p
crw-rw----+ 1 root audio 116, 8 Nov 25 19:51 /dev/snd/pcmC1D12p
crw-rw----+ 1 root audio 116, 2 Nov 25 19:51 /dev/snd/pcmC1D3p
crw-rw----+ 1 root audio 116, 3 Nov 25 19:51 /dev/snd/pcmC1D7p
crw-rw----+ 1 root audio 116, 4 Nov 25 19:51 /dev/snd/pcmC1D8p
crw-rw----+ 1 root audio 116, 5 Nov 25 19:51 /dev/snd/pcmC1D9p
crw-rw----+ 1 root audio 116, 33 Nov 25 19:51 /dev/snd/timer
crw-rw----+ 1 root audio 116, 1 Nov 25 19:51 /dev/snd/seq
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 80 Nov 25 19:51 .
lrwxrwxrwx 1 root root 12 Nov 25 19:51 pci-0000:00:1b.0 -> ../controlC0
drwxr-xr-x 3 root root 400 Nov 25 19:51 ..
lrwxrwxrwx 1 root root 12 Nov 25 19:51 pci-0000:01:00.1 -> ../controlC1
________________
> lsof /dev/snd/*
________________
> jacks_do
card=0
numid=44,iface=CARD,name='Front Headphone Jack'
; type=BOOLEAN,access=r-------,values=1
: values=off
numid=38,iface=CARD,name='Front Mic Jack'
: values=off
numid=40,iface=CARD,name='Line Jack'
: values=off
numid=43,iface=CARD,name='Line Out CLFE Jack'
: values=off
numid=41,iface=CARD,name='Line Out Front Jack'
: values=off
numid=42,iface=CARD,name='Line Out Surround Jack'
: values=off
numid=39,iface=CARD,name='Rear Mic Jack'
: values=off
numid=45,iface=CARD,name='SPDIF Phantom Jack'
: values=on
numid=46,iface=CARD,name='SPDIF Phantom Jack',index=1
: values=on
card=1
numid=25,iface=CARD,name='HDMI/DP,pcm=10 Jack'
: values=off
numid=31,iface=CARD,name='HDMI/DP,pcm=11 Jack'
: values=off
numid=37,iface=CARD,name='HDMI/DP,pcm=12 Jack'
: values=off
numid=1,iface=CARD,name='HDMI/DP,pcm=3 Jack'
: values=off
numid=7,iface=CARD,name='HDMI/DP,pcm=7 Jack'
: values=off
numid=13,iface=CARD,name='HDMI/DP,pcm=8 Jack'
: values=on
numid=19,iface=CARD,name='HDMI/DP,pcm=9 Jack'
: values=off
________________
> aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
sysdefault:CARD=PCH
HDA Intel PCH, ALC898 Analog
Default Audio Device
front:CARD=PCH,DEV=0
Front output / input
surround21:CARD=PCH,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=PCH,DEV=0
HDA Intel PCH, ALC898 Digital
IEC958 (S/PDIF) Digital Audio Output
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
hdmi:CARD=NVidia,DEV=0
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
HDA NVidia, HDMI 1
HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
HDA NVidia, HDMI 2
HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
HDA NVidia, HDMI 3
HDMI Audio Output
hdmi:CARD=NVidia,DEV=4
HDA NVidia, HDMI 4
HDMI Audio Output
hdmi:CARD=NVidia,DEV=5
HDA NVidia, HDMI 5
HDMI Audio Output
hdmi:CARD=NVidia,DEV=6
HDA NVidia, HDMI 6
HDMI Audio Output
usbstream:CARD=NVidia
HDA NVidia
USB Stream Output
________________
> arecord -L
null
samplerate
speexrate
jack
oss
Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
sysdefault:CARD=PCH
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
HDA NVidia
USB Stream Output
________________
> alsa_info_do
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.65
!!Script ran on: Wed Nov 25 20:09:50 UTC 2020
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: System manufacturer
Product Name: System Product Name
Product Version: System Version
Firmware Version: 4901
System SKU: SKU
Board Vendor: ASUSTeK COMPUTER INC.
Board Name: RAMPAGE IV EXTREME
!!ACPI Device Status Information
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/LNXCPU:00/status 15
/sys/bus/acpi/devices/LNXCPU:01/status 15
/sys/bus/acpi/devices/LNXCPU:02/status 15
/sys/bus/acpi/devices/LNXCPU:03/status 15
/sys/bus/acpi/devices/LNXCPU:04/status 15
/sys/bus/acpi/devices/LNXCPU:05/status 15
/sys/bus/acpi/devices/LNXCPU:06/status 15
/sys/bus/acpi/devices/LNXCPU:07/status 15
/sys/bus/acpi/devices/LNXCPU:08/status 15
/sys/bus/acpi/devices/LNXCPU:09/status 15
/sys/bus/acpi/devices/LNXCPU:0a/status 15
/sys/bus/acpi/devices/LNXCPU:0b/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0A03:00/status 15
/sys/bus/acpi/devices/PNP0A08:00/status 15
/sys/bus/acpi/devices/PNP0C01:01/status 15
/sys/bus/acpi/devices/PNP0C0C:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 9
/sys/bus/acpi/devices/PNP0C0F:01/status 9
/sys/bus/acpi/devices/PNP0C0F:02/status 9
/sys/bus/acpi/devices/PNP0C0F:03/status 9
/sys/bus/acpi/devices/PNP0C0F:04/status 9
/sys/bus/acpi/devices/PNP0C0F:05/status 9
/sys/bus/acpi/devices/PNP0C0F:06/status 9
/sys/bus/acpi/devices/PNP0C0F:07/status 9
!!Kernel Information
Kernel release: 5.9.10-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.9.10-1-MANJARO
Library version: 1.2.4
Utilities version: 1.2.4
!!Loaded ALSA modules
snd_hda_intel
snd_hda_intel
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - No
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xf9120000 irq 98
1 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xf9080000 irq 99
!!PCI Soundcards installed in the system
00:1b.0 Audio device [0403]: Intel Corporation C600/X79 series chipset High Definition Audio Controller [8086:1d20] (rev 06)
Subsystem: ASUSTeK Computer Inc. Device [1043:84f8]
01:00.1 Audio device [0403]: NVIDIA Corporation GK104 HDMI Audio Controller [10de:0e0a] (rev a1)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:3542]
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 0
power_save_controller : N
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 0
single_cmd : -1
snoop : -1
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC898
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0899
Subsystem Id: 0x104384f8
Revision Id: 0x100003
No Modem Function Group found
Default PCM:
rates [0x5f0]: 32000 44100 48000 88200 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x411: Stereo
Device: name="ALC898 Analog", type="Audio", device=0
Converter: stream=5, channel=0
PCM:
rates [0x5e0]: 44100 48000 88200 96000 192000
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x411: Stereo
PCM:
formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x411: Stereo
PCM:
formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x411: Stereo
PCM:
formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
formats [0x1]: PCM
Node 0x07 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
Amp-In vals: [0x27 0x27]
Converter: stream=0, channel=0
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x24
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=1, device=0
Control: name="Capture Switch", index=1, device=0
Device: name="ALC898 Alt Analog", type="Audio", device=2
Amp-In vals: [0x80 0x80]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=2, device=0
Control: name="Capture Switch", index=2, device=0
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Audio Input] wcaps 0x100791: Stereo Digital
SDI-Select: 0
Digital:
PCM:
rates [0x570]: 32000 44100 48000 96000 192000
formats [0x1]: PCM
Unsolicited: tag=00, enabled=0
Connection: 1
0x1f
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="Front Mic Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=1, ofs=0
Control: name="Front Mic Playback Switch", index=0, device=0
Control: name="Rear Mic Playback Volume", index=0, device=0
Control: name="Rear Mic Playback Switch", index=0, device=0
Control: name="Line Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
Control: name="Line Playback Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 10
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name="Front Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x80 0x80]
Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
Amp-Out vals: [0x3c 0x3c]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name="Surround Playback Volume", index=0, device=0
Connection: 2
0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name="Center Playback Volume", index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name="LFE Playback Volume", index=0, device=0
ControlAmp: chs=2, dir=Out, idx=0, ofs=0
Connection: 2
0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name="Headphone Playback Volume", index=0, device=0
Connection: 2
0x05 0x0b
Node 0x10 [Audio Output] wcaps 0x611: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=0, device=0
Control: name="IEC958 Playback Pro Mask", index=0, device=0
Control: name="IEC958 Playback Default", index=0, device=0
Control: name="IEC958 Playback Switch", index=0, device=0
Control: name="IEC958 Default PCM Playback Switch", index=0, device=0
Device: name="ALC898 Digital", type="SPDIF", device=1
Digital:
PCM:
formats [0x1]: PCM
Node 0x11 [Pin Complex] wcaps 0x400701: Stereo Digital
Pincap 0x00000010: OUT
Pin Default 0x90460120: [Fixed] SPDIF Out at Int N/A
Conn = Digital, Color = Unknown
DefAssociation = 0x2, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x10
Node 0x12 [Pin Complex] wcaps 0x400401: Stereo
Pincap 0x00000020: IN
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Front Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x0001003c: IN OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x01014410: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Green
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x40: OUT
Unsolicited: tag=05, enabled=1
Connection: 5
0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Surround Playback Switch", index=0, device=0
Pincap 0x0000003c: IN OUT HP Detect
Pin Default 0x01011012: [Jack] Line Out at Ext Rear
DefAssociation = 0x1, Sequence = 0x2
Pin-ctls: 0x40: OUT
Unsolicited: tag=06, enabled=1
Connection: 5
0x0c 0x0d* 0x0e 0x0f 0x26
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Center Playback Switch", index=0, device=0
Control: name="LFE Playback Switch", index=0, device=0
Pin Default 0x01016011: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Orange
DefAssociation = 0x1, Sequence = 0x1
Pin-ctls: 0x40: OUT
Unsolicited: tag=07, enabled=1
Connection: 5
0x0c 0x0d 0x0e* 0x0f 0x26
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Amp-Out vals: [0x80 0x80]
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Connection: 5
0x0c 0x0d 0x0e 0x0f* 0x26
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Rear Mic Boost Volume", index=0, device=0
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Pincap 0x0000373c: IN OUT HP Detect
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x01a19840: [Jack] Mic at Ext Rear
Conn = 1/8, Color = Pink
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0x21: IN VREF_50
Unsolicited: tag=03, enabled=1
Connection: 5
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Front Mic Boost Volume", index=0, device=0
Pin Default 0x02a19c50: [Jack] Mic at Ext Front
DefAssociation = 0x5, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=02, enabled=1
Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Line Boost Volume", index=0, device=0
Pin Default 0x0181344f: [Jack] Line In at Ext Rear
Conn = 1/8, Color = Blue
DefAssociation = 0x4, Sequence = 0xf
Pin-ctls: 0x20: IN VREF_HIZ
Unsolicited: tag=04, enabled=1
Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Pincap 0x0001373c: IN OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x02214c1f: [Jack] HP Out at Ext Front
DefAssociation = 0x1, Sequence = 0xf
Pin-ctls: 0xc0: OUT HP VREF_HIZ
Unsolicited: tag=01, enabled=1
Connection: 5
Node 0x1c [Pin Complex] wcaps 0x400481: Stereo
Pincap 0x00000024: IN Detect
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x4007e629: [N/A] Line Out at Ext N/A
Conn = Analog, Color = White
DefAssociation = 0x2, Sequence = 0x9
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400701: Stereo Digital
Pin Default 0x01451130: [Jack] SPDIF Out at Ext Rear
Conn = Optical, Color = Black
DefAssociation = 0x3, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Pin Complex] wcaps 0x400681: Stereo Digital
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=28
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 11
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 11
Node 0x24 [Audio Selector] wcaps 0x300101: Stereo
Connection: 12
0x18 0x19* 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b 0x12
Node 0x25 [Audio Output] wcaps 0x411: Stereo
PCM:
formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Amp-Out vals: [0x57 0x57]
Connection: 2
0x25 0x0b
Codec: Nvidia GPU 40 HDMI/DP
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x10de0040
Subsystem Id: 0x14583542
Revision Id: 0x100100
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x04 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pincap 0x09000094: OUT Detect HBR HDMI DP
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Pin-ctls: 0x00:
Devices: 4
Dev 00: PD = 0, ELDV = 0, IA = 0
Dev 01: PD = 0, ELDV = 0, IA = 0
Dev 02: PD = 0, ELDV = 0, IA = 0
*Dev 03: PD = 0, ELDV = 0, IA = 0
Connection: 4
0x08* 0x09 0x0a 0x0b
Node 0x05 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Devices: 4
Connection: 4
Node 0x06 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=09, enabled=1
Devices: 4
*Dev 00: PD = 1, ELDV = 1, IA = 0
Connection: 4
Node 0x07 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=0d, enabled=1
Devices: 4
Connection: 4
Node 0x08 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
formats [0x5]: PCM AC3
Node 0x09 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0a [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0b [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
--endcollapse--
!!ALSA Device nodes
/dev/snd/by-path:
total 0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC898 Analog [ALC898 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC898 Digital [ALC898 Digital]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 12: HDMI 6 [HDMI 6]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 2: ALC898 Alt Analog [ALC898 Alt Analog]
Subdevices: 2/2
Subdevice #1: subdevice #1
!!Amixer output
!!-------Mixer controls for card PCH
Card hw:0 'PCH'/'HDA Intel PCH at 0xf9120000 irq 98'
Mixer name : 'Realtek ALC898'
Components : 'HDA:10ec0899,104384f8,00100003'
Controls : 52
Simple ctrls : 23
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 60 [69%] [-20.25dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
Mono:
Simple mixer control 'Front Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Surround',0
Mono:
Simple mixer control 'Center',0
Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'LFE',0
Simple mixer control 'Line',0
Mono:
Simple mixer control 'Line Boost',0
Limits: 0 - 3
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 39 [62%] [12.00dB] [on]
Front Right: Capture 39 [62%] [12.00dB] [on]
Simple mixer control 'Capture',1
Front Left: Capture 0 [0%] [-17.25dB] [off]
Front Right: Capture 0 [0%] [-17.25dB] [off]
Simple mixer control 'Capture',2
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Input Source',0
Capabilities: cenum
Items: 'Front Mic' 'Rear Mic' 'Line'
Item0: 'Front Mic'
Simple mixer control 'Input Source',1
Capabilities: cenum
Item0: 'Front Mic'
Simple mixer control 'Input Source',2
Capabilities: cenum
Item0: 'Front Mic'
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
Mono:
Simple mixer control 'Rear Mic Boost',0
Limits: 0 - 3
!!-------Mixer controls for card NVidia
Card hw:1 'NVidia'/'HDA NVidia at 0xf9080000 irq 99'
Mixer name : 'Nvidia GPU 40 HDMI/DP'
Components : 'HDA:10de0040,14583542,00100100'
Controls : 49
Simple ctrls : 7
Simple mixer control 'IEC958',1
Simple mixer control 'IEC958',2
Simple mixer control 'IEC958',3
Simple mixer control 'IEC958',4
Simple mixer control 'IEC958',5
Simple mixer control 'IEC958',6
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
iface MIXER
name 'Front Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.2 {
iface MIXER
name 'Front Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Surround Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name 'Surround Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Center Playback Volume'
value 87
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
control.6 {
iface MIXER
name 'LFE Playback Volume'
value 87
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
control.7 {
iface MIXER
name 'Center Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.8 {
iface MIXER
name 'LFE Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.9 {
iface MIXER
name 'Headphone Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.10 {
iface MIXER
name 'Headphone Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.11 {
iface MIXER
name 'Loopback Mixing'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.12 {
iface MIXER
name 'Front Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.13 {
iface MIXER
name 'Front Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.14 {
iface MIXER
name 'Rear Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.15 {
iface MIXER
name 'Rear Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.16 {
iface MIXER
name 'Line Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.17 {
iface MIXER
name 'Line Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.18 {
iface MIXER
name 'Auto-Mute Mode'
value Enabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.19 {
iface MIXER
name 'Input Source'
value 'Front Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Front Mic'
item.1 'Rear Mic'
item.2 Line
control.20 {
iface MIXER
name 'Input Source'
index 1
value 'Front Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Front Mic'
item.1 'Rear Mic'
item.2 Line
control.21 {
iface MIXER
name 'Input Source'
index 2
value 'Front Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Front Mic'
item.1 'Rear Mic'
item.2 Line
control.22 {
iface MIXER
name 'Capture Volume'
value.0 39
value.1 39
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 1200
dbvalue.1 1200
control.23 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.24 {
iface MIXER
index 1
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 -1725
dbvalue.1 -1725
control.25 {
iface MIXER
index 1
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.26 {
iface MIXER
index 2
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 -1725
dbvalue.1 -1725
control.27 {
iface MIXER
index 2
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.28 {
iface MIXER
name 'Front Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.29 {
iface MIXER
name 'Rear Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.30 {
iface MIXER
name 'Line Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.31 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.32 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.34 {
iface MIXER
name 'IEC958 Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.35 {
iface MIXER
name 'IEC958 Default PCM Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.36 {
iface MIXER
name 'Master Playback Volume'
value 60
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -2025
control.37 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.38 {
iface CARD
name 'Front Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.39 {
iface CARD
name 'Rear Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.40 {
iface CARD
name 'Line Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.41 {
iface CARD
name 'Line Out Front Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.42 {
iface CARD
name 'Line Out Surround Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.43 {
iface CARD
name 'Line Out CLFE Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.44 {
iface CARD
name 'Front Headphone Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.45 {
iface CARD
name 'SPDIF Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.46 {
iface CARD
index 1
value true
comment {
access read
type BOOLEAN
count 1
control.47 {
iface PCM
name 'Playback Channel Map'
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
comment {
access read
type INTEGER
count 6
range '0 - 36'
control.48 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.49 {
iface PCM
device 1
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.50 {
iface PCM
device 2
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.51 {
iface PCM
device 2
index 1
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.52 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
state.NVidia {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.7 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value '100008006d14000100100000000000002462003544500a202020202020202020200f7f070000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
type BYTES
count 95
control.19 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 3
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
index 4
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.31 {
iface CARD
name 'HDMI/DP,pcm=11 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
index 5
comment {
access 'read write'
type IEC958
count 1
control.35 {
iface MIXER
index 5
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.36 {
iface PCM
device 11
name ELD
value ''
comment {
type BYTES
count 0
control.37 {
iface CARD
name 'HDMI/DP,pcm=12 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.38 {
iface MIXER
index 6
comment {
access read
type IEC958
count 1
control.39 {
iface MIXER
index 6
comment {
access read
type IEC958
count 1
control.40 {
iface MIXER
index 6
comment {
access 'read write'
type IEC958
count 1
control.41 {
iface MIXER
index 6
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.42 {
iface PCM
device 12
name ELD
value ''
comment {
type BYTES
count 0
control.43 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.44 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.45 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.46 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.47 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.48 {
iface PCM
device 11
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.49 {
iface PCM
device 12
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
--endcollapse--
!!All Loaded Modules
aesni_intel
agpgart
asus_wmi
battery
cec
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
dca
drm
drm_kms_helper
e1000e
eeepc_wmi
ehci_hcd
ehci_pci
evdev
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
i2c_algo_bit
i2c_i801
i2c_smbus
iTCO_vendor_support
iTCO_wdt
igb
input_leds
intel_cstate
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_uncore
ip_tables
irqbypass
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
loop
lpc_ich
mac_hid
mbcache
mei
mei_me
mousedev
msr
mxm_wmi
nls_cp437
nls_iso8859_1
nvidia
nvidia_drm
nvidia_modeset
pcspkr
rapl
rc_core
rfkill
sg
snd
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_timer
soundcore
sparse_keymap
squashfs
syscopyarea
sysfillrect
sysimgblt
uinput
usbhid
vfat
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_hcd
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x11 0x90460120
0x12 0x411111f0
0x14 0x01014410
0x15 0x01011012
0x16 0x01016011
0x17 0x411111f0
0x18 0x01a19840
0x19 0x02a19c50
0x1a 0x0181344f
0x1b 0x02214c1f
0x1c 0x411111f0
0x1d 0x4007e629
0x1e 0x01451130
0x1f 0x411111f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x04 0x185600f0
0x05 0x185600f0
0x06 0x185600f0
0x07 0x185600f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
[ 0.354841] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.354842] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.354843] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 4.509847] cryptd: max_cpu_qlen set to 1000
[ 4.525433] AVX version of gcm_enc/dec engaged.
[ 4.639800] igb 0000:06:00.1: Using MSI-X interrupts. 8 rx queue(s), 8 tx queue(s)
[ 4.823169] igb 0000:07:00.0: added PHC on eth3
I checked in pavucontrol and my only output registering in port is S/PDIF
