I created a simple script as shown below, and named it “keyboard_backlight.sh”
#!/bin/bash
echo '3-12' |sudo tee /sys/bus/usb/drivers/usb/unbind
To give executable permissions, I executed the command below.
sudo chmod 775 keyboard_backlight.sh
In order to execute the script (keyboard_backlight.sh) at boot-up, I ran the command below.
crontab -e
And entered the command below in crontab
@reboot /home/bizdik/keyboard_backlight.sh
But the script (keyboard_backlight.sh) doesn’t get executed at boot-up. When I manually execute the script in terminal, it works fine! I don’t understand why it doesn’t work at boot-up. Any idea?
Doesn’t crontab in Manjaro support “@reboot” entry (function)? Just wondering!!?
Thank you so much for your help, dmt! The systemd service did the trick! Thank you for the service file and also for making things so easy to understand.
After a long struggle and months of research, the keyboard backlight of my laptop (MSI GS76) finally works with Manjaro! And with your help, I was able to run the script at boot-up to automatically turn on the keyboard backlight.
