I’m unable to completely disable mouse acceleration on the latest version of kde bundled with manjaro. I have tried the following remedies Mouse acceleration - ArchWiki and double checked that it’s using libinput, however despite using the flat profile i still appear to have some acceleration, how do i verify if that’s really the case and if so, how do i disable it for good? Thanks.
I had a similar problem where on every reboot mouse acceleration came back. If I opened the mouse settings and moved the acceleration one tick, applied it and put back to the default middle position, it was gone again. So in the end I had to use an autostart script like suggested in the wiki.
You could post the output of your xinput properties.
xinput list-props 11
Device 'Logitech Gaming Mouse G400':
Device Enabled (146): 1
Coordinate Transformation Matrix (148): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
libinput Natural Scrolling Enabled (286): 0
libinput Natural Scrolling Enabled Default (287): 0
libinput Scroll Methods Available (419): 0, 0, 1
libinput Scroll Method Enabled (420): 0, 0, 0
libinput Scroll Method Enabled Default (421): 0, 0, 0
libinput Button Scrolling Button (422): 2
libinput Button Scrolling Button Default (423): 2
libinput Button Scrolling Button Lock Enabled (424): 0
libinput Button Scrolling Button Lock Enabled Default (425): 0
libinput Middle Emulation Enabled (426): 0
libinput Middle Emulation Enabled Default (427): 0
libinput Accel Speed (428): 0.000000
libinput Accel Speed Default (429): 0.000000
libinput Accel Profiles Available (430): 1, 1
libinput Accel Profile Enabled (431): 0, 1
libinput Accel Profile Enabled Default (432): 1, 0
libinput Left Handed Enabled (433): 0
libinput Left Handed Enabled Default (434): 0
libinput Send Events Modes Available (269): 1, 0
libinput Send Events Mode Enabled (270): 0, 0
libinput Send Events Mode Enabled Default (271): 0, 0
Device Node (272): "/dev/input/event9"
Device Product ID (273): 1133, 49733
libinput Drag Lock Buttons (288): <no items>
libinput Horizontal Scroll Enabled (289): 1
With mouse acceleration enabled the only difference for me was:
libinput Accel Profile Enabled (431): 1, 0
