I’ve just bought a new smart tv and connected to my mediacenter, powered by manjaro. This was working with my old tv but now the new TV TCL is not able to detect any signal.
Any idea what to test?
System: Kernel: 5.11.22-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Console: pty pts/0 DM: GDM 40.1
Machine: Type: Desktop System: Gigabyte product: A320M-S2H v: N/A serial: <filter>
Mobo: Gigabyte model: A320M-S2H-CF v: x.x serial: <filter> UEFI-[Legacy]: American Megatrends v: F23
date: 08/08/2018
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400 Plus serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
CPU: Info: Quad Core model: AMD Ryzen 3 2200G with Radeon Vega Graphics bits: 64 type: MCP arch: Zen rev: 0 cache:
L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 27958
Speed: 1418 MHz min/max: 1600/3500 MHz boost: enabled Core speeds (MHz): 1: 1418 2: 1421 3: 1422 4: 1421
Graphics: Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] vendor: Gigabyte driver: amdgpu
v: kernel bus-ID: 07:00.0 chip-ID: 1002:15dd class-ID: 0300
Display: server: X.org 1.20.13 compositor: gnome-shell driver: loaded: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa tty: 168x37
Message: Advanced graphics data unavailable in console. Try -G --display
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 07:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.11.22-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-0871cb99936b state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Drives: Local Storage: total: 3.86 TiB used: 634.23 GiB (16.1%)
ID-1: /dev/sda vendor: Kingston model: SA400S37240G size: 223.57 GiB speed: 6.0 Gb/s type: SSD serial: <filter>
rev: B1E1 scheme: MBR
ID-2: /dev/sdb vendor: Seagate model: ST4000DM004-2CV104 size: 3.64 TiB speed: 6.0 Gb/s type: HDD rpm: 5425
serial: <filter> rev: 0001 scheme: GPT
Partition: ID-1: / size: 47.81 GiB used: 27.99 GiB (58.5%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 511 MiB used: 292 KiB (0.1%) fs: vfat dev: /dev/sda1
ID-3: /home size: 81.61 GiB used: 11.88 GiB (14.6%) fs: ext4 dev: /dev/sda6
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 29.6 C mobo: N/A gpu: amdgpu temp: 29.0 C
Info: Processes: 227 Uptime: 50m wakeups: 15 Memory: 6.8 GiB used: 982.8 MiB (14.1%) Init: systemd v: 249 Compilers:
gcc: N/A Packages: pacman: 1440 Shell: Bash v: 5.1.8 running-in: pty pts/0 (SSH) inxi: 3.3.08
