Unable to create io-slave. klauncher said: Error loading '/usr/lib/qt/plugins/kf5/kio/file.so'
Hi, I’m getting this error when trying to browse my files after an update. I don’t know what’s wrong or how to fix it. :confused:
[totte@Linux ~]$ dolphin
kf5.kio.core: Refilling KProtocolInfoFactory cache in the hope to find "stash"
qt.accessibility.core: Cannot create accessible child interface for object:  PlacesView(0x2801e60)  index:  17
Attempted to re-run an already running session.
kf5.kio.core: couldn't create slave: "klauncher said: Error loading '/usr/lib/qt/plugins/kf5/kio/file.so'."
kf5.kio.core: couldn't create slave: "klauncher said: Error loading '/usr/lib/qt/plugins/kf5/kio/trash.so'."
kf5.kio.core: "Unable to create io-slave. klauncher said: Error loading '/usr/lib/qt/plugins/kf5/kio/trash.so'."
QXcbConnection: XCB error: 8 (BadMatch), sequence: 2854, resource id: 136315010, major code: 130 (Unknown), minor code: 3
QXcbConnection: XCB error: 8 (BadMatch), sequence: 2869, resource id: 136315010, major code: 130 (Unknown), minor code: 3
QXcbConnection: XCB error: 8 (BadMatch), sequence: 2872, resource id: 136315010, major code: 130 (Unknown), minor code: 3
I literally solved it 1 minute after making the post, by running dbus-launch dolphin
Can’t find a way to delete my post.
just restart (logout+login). That happens because Qt(Dolphin) loads this plugin, then you do an update and Qt conflicts the loadup of the new version, because its still holding the old version in RAM.
