mvozza
January 30, 2023, 11:31am
1
Hi all I have an hp probook and recently installed manjaro, but I can’t connect to Wi-Fi. The particularly strange thing is that the output of inxi -Nxz, returns me N/A drivers on what should be the wifi device.
Below is the output of inxi -Nxz and mhwd-kernel -li
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 01:00.0
Device-2: Realtek vendor: Hewlett-Packard driver: N/A port: 2000
bus-ID: 02:00.0
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 2-1.2.1:5
* linux515
Is there a physical switch on this computer that enables or disables wifi? Please post output of
rfkill list
When you right click on network manager icon in tray is “Enable wifi” checked?
mvozza
January 30, 2023, 1:59pm
3
The wifi when i right-click on network manager icon does not appear, although I have installed the package.
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Is Secure Boot disabled in UEFI/BIOS? Is wifi disabled in BIOS?
What is output of lspci and lsusb?
Are you dual booting Windows?
Have you tried a different kernel, 6.0 or 6.1? Is the system fully updated? Can you post a full inxi output as specified here:
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to this tutorial, so if you’re reading this in response to a question, please click the link above this text to bring you to the full and unabridged text of the tutorial…
Difficulty: ★☆☆☆☆
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to follow three major points.
Provide context
Simply signaling an issue is rarely enough to understand how it occurred. It is thus important to provide details on how it happened:
Detail prior actions leading to the issue.
List solutions and guides you already tried, with links when…
inxi -Naxz
could provide more useful information about the wifi device in order to identify what driver might drive it
and/or one of the sections in:
lspci -v
