Hello,
For the past few weeks, I have been unable to connect to the internet using a wired connection on my Lenovo T14s (1st gen).
I have tried everything: Using the previous LTS kernel (5.15 I believe), changing from r8169 to r8168, rebooting, etc.
I checked with other computers in my office, so it certainly is a problem of mine. I can access the internet through Wifi.
The output of inxi --admin --verbosity=7 --filter --width
is:
Kernel: 6.1.23-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=4c594364-3723-4619-8c4b-9b5d98de1bfa ro quiet
resume=UUID=e2f61f5b-3c12-46f8-975c-5694c2c07c43 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20UH000HUS v: ThinkPad T14s Gen 1
Mobo: LENOVO model: 20UH000HUS v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: R1CET73W(1.42 ) date: 12/09/2022
ID-1: BAT0 charge: 46.3 Wh (98.5%) condition: 47.0/57.0 Wh (82.4%)
volts: 12.8 min: 11.5 model: Celxpert 5B10W139 type: Li-poly serial: <filter>
status: not charging cycles: 239
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Device-2: hidpp_battery_0 model: Logitech M705 serial: <filter> charge: 60%
rechargeable: yes status: discharging
RAM: total: 6.99 GiB used: 3.4 GiB (48.6%)
Info: model: AMD Ryzen 5 PRO 4650U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1457 high: 2100 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2100 2: 1400
3: 1400 4: 1397 5: 1400 6: 1397 7: 1400 8: 1397 9: 1397 10: 1400 11: 1400
12: 1400 bogomips: 50322
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: DP-1,eDP-1
empty: DP-2,HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:1636 class-ID: 0300
temp: 44.0 C
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 2-2:2 chip-ID: 04f2:b6d9 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3199x1080 s-dpi: 96 s-size: 844x285mm (33.23x11.22")
s-diag: 891mm (35.07")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left model: Dell 1907FP
serial: <filter> built: 2006 res: 1280x1024 hz: 60 dpi: 86 gamma: 1.2
size: 376x301mm (14.8x11.85") diag: 482mm (19") ratio: 5:4 modes:
max: 1280x1024 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: right model: AU Optronics 0x403d
built: 2018 res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2
size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.23-1-MANJARO) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.23-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.68 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: pulseaudio-jack
type: module tools: pacat,pactl
vendor: Lenovo driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2400 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Device-3: ASIX AX88179 Gigabit Ethernet type: USB driver: cdc_ncm
bus-ID: 5-1.1:5 chip-ID: 0b95:1790 class-ID: 0a00 serial: <filter>
IF: enp6s0f3u1u1c2 state: down mac: <filter>
IF-ID-1: enp6s0f4u2c4i2 state: up speed: N/A duplex: N/A mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 6-4:4
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 931.51 GiB used: 329.96 GiB (35.4%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
used: 329.96 GiB (36.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 4c594364-3723-4619-8c4b-9b5d98de1bfa
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: A86A-251E
ID-1: swap-1 type: partition size: 8.8 GiB used: 2.5 MiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: e2f61f5b-3c12-46f8-975c-5694c2c07c43
Hub-1: 1-0:1 info: Full speed or root hub ports: 1 rev: 2.0 speed: 480 Mb/s
Hub-2: 2-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 2-2:2 info: Chicony Integrated Camera type: Video
Hub-3: 3-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-4: 4-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-5: 4-1:8 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Hub-6: 4-1.2:9 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 4-1.2.3:10 info: Keychron K8 Pro type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 3434:0283 class-ID: 0300
Device-2: 4-1.2.4:11 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-3: 4-1.5:12 info: VIA Labs USB Billboard Device type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 2109:8817 class-ID: 1100 serial: <filter>
Hub-7: 5-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-8: 5-1:4 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Device-1: 5-1.1:5 info: ASIX AX88179 Gigabit Ethernet
type: Communication,CDC-Data driver: cdc_ncm interfaces: 2 rev: 3.2
speed: 5 Gb/s power: 184mA chip-ID: 0b95:1790 class-ID: 0a00
serial: <filter>
Hub-9: 5-1.2:6 info: Genesys Logic Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0626 class-ID: 0900
Device-1: 5-1.3:7 info: Genesys Logic SD Card Reader and Writer
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s
power: 896mA chip-ID: 05e3:0749 class-ID: 0806 serial: <filter>
Hub-10: 6-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 6-2:6 info: Apple iPhone 5/5C/5S/6/SE/7/8/X type: Still Imaging
driver: ipheth,usbfs interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 05ac:12a8 class-ID: 0601 serial: <filter>
Device-2: 6-3:2 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Device-3: 6-4:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-11: 7-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 55.0 C mobo: N/A gpu: amdgpu temp: 43.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 304 Uptime: 41m wakeups: 7 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 2143 libs: 388 tools: pamac,yay Shell: Zsh v: 5.9 running-in: yakuake
inxi: 3.3.26
Please help.
